Please Compare These Pistons... #623860
02/25/10 11:05 AM
02/25/10 11:05 AM
tboomer Offline OP
tboomer  Offline OP
Summit has a pretty good deal going on these pistons..The first is an SRP flat top..It has a comp. distance of 2.062 in. and piston head volume of + 6.00ccs...The Wiseco has a comp. distance of 2.050 in. and a piston head volume of + 4.00 ccs.. Both are flat tops and for a big block...Which would you choose and why?? Thanks!! Ted
Re: Please Compare These Pistons... [Re: tboomer] #623861
02/25/10 11:33 AM
02/25/10 11:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
For me it would be 2 factors... what compression I
was shooting for and then what the deck height is
Re: Please Compare These Pistons... [Re: MR_P_BODY] #623862
02/25/10 11:37 AM
02/25/10 11:37 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
You already know what I would say and why
Re: Please Compare These Pistons... [Re: WILD BILL] #623863
02/25/10 11:39 AM
02/25/10 11:39 AM
tboomer Offline OP
tboomer  Offline OP
Raff...I want the most compression I can get...My heads are 80cc but could be shaved to 75cc..Bill...I already know what you would...Errr are using!!
Re: Please Compare These Pistons... [Re: tboomer] #623864
02/25/10 11:55 AM
02/25/10 11:55 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I see they're both for a 1.094 wrist pin?
Are you going to use aftermarket rods or stock? Most aftermarket ones are .008" shorter than stock so that will play into it, if you're trying to keep any milling done to the block to a minimum.
Re: Please Compare These Pistons... [Re: ZIPPY] #623865
02/25/10 12:01 PM
02/25/10 12:01 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Re: Please Compare These Pistons... [Re: ZIPPY] #623866
02/25/10 12:06 PM
02/25/10 12:06 PM
tboomer Offline OP
tboomer  Offline OP
Rich...I have different rods...I will measure one...Never thought about that!! What are you whistling for,Bill.. Must be happy about something...
Re: Please Compare These Pistons... [Re: tboomer] #623867
02/25/10 12:09 PM
02/25/10 12:09 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
What heads are you using? We shaved my 84cc Eddys down .090 and got the chambers to 64 cc for a 12-1 CR
Re: Please Compare These Pistons... [Re: WILD BILL] #623868
02/25/10 12:11 PM
02/25/10 12:11 PM
tboomer Offline OP
tboomer  Offline OP
MP aluminum 383-440 street heads..80cc..
Re: Please Compare These Pistons... [Re: tboomer] #623869
02/25/10 01:38 PM
02/25/10 01:38 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I have the same heads as Ted and took .070 off them and I have dome pistons.I fly cut the pistons also.
Re: Please Compare These Pistons... [Re: VernMotor] #623870
02/25/10 02:07 PM
02/25/10 02:07 PM
tboomer Offline OP
tboomer  Offline OP
Vern...didn't you have TRW 2295s? That is what I have now...
Re: Please Compare These Pistons... [Re: tboomer] #623871
02/25/10 08:56 PM
02/25/10 08:56 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Ted,
Why don't you quit diddlin' around with flat tops and just put DOME pistons in it? These are Ross #99501, won't fit your rods though, .990 pins. You can use #99500.
Brian
Re: Please Compare These Pistons... [Re: tboomer] #623872
02/25/10 08:59 PM
02/25/10 08:59 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
yep thats what I got Ted. next build will better pistons... I had 3 new sets of these over the years and I keep useing them up..LOL On the last set now !!
Re: Please Compare These Pistons... [Re: tboomer] #623873
02/25/10 10:07 PM
02/25/10 10:07 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
ted it sounds like the wisco pistons you are looking at are the same ones that are in my 440 short block.my pistons are so posed to 0.012 down in the hole. with a 0.039 head gasket and a 74 cc Indy head i am so posed to only have 10.5 compression. but the Wallace engine calculator says i will have around 12.2. ted i would just buy some diamond 14cc dome pistons. they are so posed to be built to work with the edelbrock/ mopar aluminum heads. what happened to getting the the stoker kit?? Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Please Compare These Pistons... [Re: mopar65] #623874
02/27/10 12:01 PM
02/27/10 12:01 PM
tboomer Offline OP
tboomer  Offline OP
Brian...Nice pistons!! Vern...You must have got a good buy to have 3 sets of 2295s... Bobby...I didn't go with the stroker...I know it would make more power but I really don't want to go that fast...The car just needs to be consistant..I have been buying a few trinkets all winter...My last major purchase is the pistons...Talked to the body guy last night and as soon as it warms up a bit,it goes in for paint and the Hemi front end treatment...Should look pretty good!! Ted
Re: Please Compare These Pistons... [Re: tboomer] #623875
02/27/10 12:52 PM
02/27/10 12:52 PM
mopar65 Offline
mopar65  Offline
Sounds great ted. what color are you going to paint it? what is the Hemi front end treatment? Ted let me know if there is anything off my old motor you might need.thanks Bobby
Re: Please Compare These Pistons... [Re: mopar65] #623876
02/27/10 01:05 PM
02/27/10 01:05 PM
tboomer Offline OP
tboomer  Offline OP
It will be the same color,Bobby...Can't think of anything I need...Here is the Hemi front end treatment...
Re: Please Compare These Pistons... [Re: mopar65] #623877
02/27/10 01:11 PM
02/27/10 01:11 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Mpar65, FWIW, Scott did a CR calcutaion with my pistons sitting .010 in the hole, a 039 head gasket, and figured a 74 CC chamber and came up with 11.09-1. When we actually milled the heads they cc'd at 64.6 cc's and he racalculated and we now have 12.05-1.
I'm not sure how my Pro Tru pistons compare with yours as far as vavle releif volume but I would think your problably in the 11-1 range.
Re: Please Compare These Pistons... [Re: mopar65] #623878
02/27/10 01:12 PM
02/27/10 01:12 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Why are you changing pistons? Was there carnage? If your old TRWs are still good, I don't see what you are gaining?
Rem
Re: Please Compare These Pistons... [Re: RemCharger] #623879
02/27/10 01:14 PM
02/27/10 01:14 PM
tboomer Offline OP
tboomer  Offline OP
They have hundreds of passes on them...This engine has been together since 2001...The metal has to be fatigued!! I know I am!!
