Re: Please Compare These Pistons...
[Re: MR_P_BODY]
#623862
02/25/10 11:37 AM
02/25/10 11:37 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
You already know what I would say and why
[Re: ZIPPY]
#623865
02/25/10 12:01 PM
02/25/10 12:01 PM
WILD BILL
BROOK PARK, OH
[Re: tboomer]
#623867
02/25/10 12:09 PM
02/25/10 12:09 PM
WILD BILL
BROOK PARK, OH
What heads are you using? We shaved my 84cc Eddys down .090 and got the chambers to 64 cc for a 12-1 CR
[Re: tboomer]
#623871
02/25/10 08:56 PM
02/25/10 08:56 PM
Posts: 2,050 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Raff...I want the most compression I can get...My heads are 80cc but could be shaved to 75cc..Bill...I already know what you would...Errr are using!!
Ted, Why don't you quit diddlin' around with flat tops and just put DOME pistons in it? These are Ross #99501, won't fit your rods though, .990 pins. You can use #99500. Brian
[Re: tboomer]
#623873
02/25/10 10:07 PM
02/25/10 10:07 PM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
ted it sounds like the wisco pistons you are looking at are the same ones that are in my 440 short block.my pistons are so posed to 0.012 down in the hole. with a 0.039 head gasket and a 74 cc Indy head i am so posed to only have 10.5 compression. but the Wallace engine calculator says i will have around 12.2. ted i would just buy some diamond 14cc dome pistons. they are so posed to be built to work with the edelbrock/ mopar aluminum heads. what happened to getting the the stoker kit?? Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: mopar65]
#623874
02/27/10 12:01 PM
02/27/10 12:01 PM
Posts: 25,984 United Socialist States of Ame...
tboomer
Brian...Nice pistons!! Vern...You must have got a good buy to have 3 sets of 2295s... Bobby...I didn't go with the stroker...I know it would make more power but I really don't want to go that fast...The car just needs to be consistant..I have been buying a few trinkets all winter...My last major purchase is the pistons...Talked to the body guy last night and as soon as it warms up a bit,it goes in for paint and the Hemi front end treatment...Should look pretty good!! Ted
[Re: tboomer]
#623875
02/27/10 12:52 PM
02/27/10 12:52 PM
mopar65
Sounds great ted. what color are you going to paint it? what is the Hemi front end treatment? Ted let me know if there is anything off my old motor you might need.thanks Bobby
support our troops
[Re: mopar65]
#623877
02/27/10 01:11 PM
02/27/10 01:11 PM
WILD BILL
BROOK PARK, OH
Mpar65, FWIW, Scott did a CR calcutaion with my pistons sitting .010 in the hole, a 039 head gasket, and figured a 74 CC chamber and came up with 11.09-1. When we actually milled the heads they cc'd at 64.6 cc's and he racalculated and we now have 12.05-1.
I'm not sure how my Pro Tru pistons compare with yours as far as vavle releif volume but I would think your problably in the 11-1 range.
