Re: Don't use a toggle switch for your line loc?
[Re: 70HemiGTX]
#619692
02/26/10 06:42 AM
02/26/10 06:42 AM
Posts: 2,361 PA
70HemiGTX
PA
I guess I should clarify that I run a stick, so I have no way of holding the car at the line with out using a line lock. I assume you guys with toggle switches have a trans-brake in you car. If you look in the picture and see the red toggle switch, I have to turn that toggle switch on before I can use my line lock. If I have it in the off position I can't apply the line lock at the momentary switch on the shifter handle.
[Re: 70Cuda383]
#619694
02/26/10 09:38 AM
02/26/10 09:38 AM
Posts: 1,880 USA
Ron Silva
USA
wait...the master kill switches have to be push-pull now?
NO.
SRT DEMON ONE SEAT
[Re: BradH]
#619696
02/26/10 11:13 AM
02/26/10 11:13 AM
Posts: 1,613 Burlington,Ont.
77DragracerR/T
Burlington,Ont.
Sorry to change the topic. I haven't finished the wiring for my line lock, although the actual solenoid has been integrated into my braking system since 2008. The button supplied w/ the Hurst unit I have looks pretty "budget" and won't attach to my OEM Slap-Stik shifter very easily. Any recommendations (other than a toggle switch ) for a better part to use here?
For the longest time i had my line loc hooked up to my horn relay and just used the horn pad.Keeps the hands on the steering wheel and when you release your thumb from the horn it moves forward.That was good until my horn pad died and i installed a toggle switch with a red light to show it's on.Either one works well.
[Re: 77DragracerR/T]
#619697
02/26/10 03:05 PM
02/26/10 03:05 PM
Posts: 368 Detroit,MI
BADDART
Detroit,MI
I have a stick car and use a toggle and momentary switch.With toggle switch up(burnout mode)the 2-step is off.With the toggle down(race)the 2-step is on for launch. Next step is to take the momentary sw. off the shifter and put it on the clutch pedal. Chris
[Re: Thumperdart]
#619703
02/27/10 01:42 AM
02/27/10 01:42 AM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
How in the hell can you do a burnout w/the rear brakes locked out? I would think the only reason to lock out the rears would be for leaving the line kinda like a poor mans trans brake.....am I off base here?
I've used a setup in the rear and it works good. You hit the solenoid, and hammer the brakes (activating the front) and then you have manual control coming out of the box. Then you have to turn it off. The problem is if the solenoid is on down the track and it locks the rear.... thats the most dangerous situation.
