Page 2 of 7 1 2 3 4 5 6 7
Re: Once again "DON'T ASK ME HOW I KNOW" #616884
02/18/10 05:45 PM
02/18/10 05:45 PM
Az
Crizila Offline
Crizila  Offline
Az
Never lean over a carb on a running car to check and see if the accelerator pump is working when your neighbor installed the plug wires - and he has dyslexia!! Don't ask me how I know.
Fastest 300
Re: Once again "DON'T ASK ME HOW I KNOW" [Re: 23T Hemmee] #616885
02/18/10 05:45 PM
02/18/10 05:45 PM
NW PA
V10nacuda Offline
V10nacuda  Offline
NW PA
After using the trailer jack to tilt the trailer front up enought to load a low car. DOn't forget to retract it COMPLETLY
& then wonder why a friend going by you is pointing like a madman at the rear of the empty trailer.
Cause next time you use the trailer it wont go as high because the jack is a few inches shorter.
Re: Once again "DON'T ASK ME HOW I KNOW" #616886
02/18/10 05:51 PM
02/18/10 05:51 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Make sure your 5-speed manual tow vehicle is in gear before attempting to load your car on the open trailer after the race.
Re: Once again "DON'T ASK ME HOW I KNOW" [Re: dustergirl340] #616887
02/18/10 06:07 PM
02/18/10 06:07 PM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
Shotguns conduct electricity when touching an electric fence........don't ask me how I know
Post deleted by Defbob [Re: dc426] #616888
02/18/10 06:11 PM
02/18/10 06:11 PM
Anonymous OP
Anonymous OP
Re: Once again "DON'T ASK ME HOW I KNOW" [Re: dustergirl340] #616889
02/18/10 06:11 PM
02/18/10 06:11 PM
Missouri
galen Offline
galen  Offline
Missouri
If your paralyzed from the waste down don't start the race car which will start in gear until after you installed the hand controls.
Post deleted by Defbob [Re: galen] #616890
02/18/10 06:12 PM
02/18/10 06:12 PM
Anonymous OP
Anonymous OP
Re: Once again "DON'T ASK ME HOW I KNOW" [Re: Edge] #616891
02/18/10 06:20 PM
02/18/10 06:20 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Always remember to disconnect battery charger before heading to staging lanes, and good battery charger ends have quite a good grip
I was wondering why every one was waving to stop.
Re: Once again "DON'T ASK ME HOW I KNOW" [Re: rowin4] #616892
02/18/10 06:50 PM
02/18/10 06:50 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
When you're staging your bike and get waved off for problems downtrack, make sure to put it back in gear when you get waved back in. That way you don't look so ignorant when you leave at 10,000 RPM in neutral.
Re: Once again "DON'T ASK ME HOW I KNOW" [Re: slantzilla] #616893
02/18/10 07:06 PM
02/18/10 07:06 PM
Fort Worth, TX
DMax One Offline
DMax One  Offline
Fort Worth, TX
When you have a nitrous explosion in the intake on the launch, don't continue to drive on down the track scattering little pieces of a plastic airhat all the way down the track. "because it was still running"
Secondly, don't do it twice in the same weekend.
DAMHIK
68 Barracuda FB "Exploded View" ...still :-( 2008 Ram 2500 CTD 2007 H.D. Softail Custom 92 Jeep Cherokee
Re: Once again "DON'T ASK ME HOW I KNOW" [Re: slantzilla] #616894
02/18/10 07:26 PM
02/18/10 07:26 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
If you take a funnel and a long hose and put them together to use to fill a 833 from the engine compartment don't dump a half gallon of gear lube down the funnel before checking to see if the hose is still in the trans.......
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Once again "DON'T ASK ME HOW I KNOW" [Re: DMax One] #616895
02/18/10 07:33 PM
02/18/10 07:33 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
When you try to stage the car with the REAR tires, it helps to have a red helment. Then it kinda maches your face.
What I don't understand is how it seems like there are 300 people pointing and donkey laffing, but only sold 30 tickets!!??
Re: Once again "DON'T ASK ME HOW I KNOW" [Re: '72CudaRacer] #616896
02/18/10 08:05 PM
02/18/10 08:05 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
If using an old bath towel tie strapped under the trans to catch a small trans leak to get by one weekend, Don't forget to remove it after it is completely oil soaked, cause when you change the starter thinking you can do it while charging the battery and not arch the wire you may get a firey result, furthermore do not park next to a junior dragster that is warming up its engine when trying to holler to get someones attention to get a fire extinguisher. DAMHIK
Re: Once again "DON'T ASK ME HOW I KNOW" [Re: '72CudaRacer] #616897
02/18/10 08:08 PM
02/18/10 08:08 PM
PA
moparacer Offline
moparacer  Offline
PA
If your a box racer dont forget to change your opponents dial in before the next round....
Dont ask me how I know.....2 or 3 times at least....
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Once again "DON'T ASK ME HOW I KNOW" [Re: '72CudaRacer] #616898
02/18/10 08:10 PM
02/18/10 08:10 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
#1. If you grab a "spare" carb off the shelf to install on an engine,,make sure you didn't take the floats out of it for a buddy to use till his new ones come in the mail.
#2 If you have an engine 'full of fuel' and you remove the spark plugs to crank the engine over to keep from hydraulicing and bending a rod, make sure you have the spark plug wires away from the plug holes or the ignition off.
#3 Always have a fire extenguisher handy for any unexpected fires.
If you like drag racing, support your local track.
Re: Once again "DON'T ASK ME HOW I KNOW" #616899
02/18/10 08:15 PM
02/18/10 08:15 PM
Detroit Michigan
drbill Offline
drbill  Offline
Detroit Michigan
Where do you want me to start, cuts, burns or general stupid stuff
Never grab a brake drum by the center hole after you just used a torch to heat it up to be able to remove it from the axle.
Never use chlorinated brake clean to clean the throttle body on a running Mercedes Benz.
Never grab the fan shroud to stop your car from rolling into the fence because you forgot to set the parking brake while adjusting the idle mixture screws on the carb.
Re: Once again "DON'T ASK ME HOW I KNOW" [Re: CHAPPER] #616900
02/18/10 08:22 PM
02/18/10 08:22 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
When you use a shop rag in your intake plenum to keep debris from getting in don't forget to remove it before hastily installing your carb in a rush to get to the track.
Always test fire the car after you install the carb to make sure things are ok. If it sounds a little lame give it a few revs to clean it out It may be loaded up
"Gee Dad smell's like something's burning"
Re: Once again "DON'T ASK ME HOW I KNOW" [Re: drbill] #616901
02/18/10 08:28 PM
02/18/10 08:28 PM
smalltyredart67 Offline
never do a dry hop on nitrous with 1400# of bottle pressure
smalltyredart
jeff r
Re: Once again "DON'T ASK ME HOW I KNOW" [Re: galen] #616902
02/18/10 08:33 PM
02/18/10 08:33 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
ALWAYS, and I mean ALWAYS, put the oil filter on before priming the oil pump of a new motor.
Funny thing is I've forgotten to do this twice, about 20 years apart.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: Once again "DON'T ASK ME HOW I KNOW" [Re: fasteddie] #616903
02/18/10 08:49 PM
02/18/10 08:49 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Don't continue driving your freshly built motor despite not knowing exactly where your coolant was going--thinking "it's ok, I'll just top it off every time I go for a ride". it is NOT "out of sight, out of mind"
**Photobucket sucks**
