Re: Once again "DON'T ASK ME HOW I KNOW"
[Re: 23T Hemmee]
#616885
02/18/10 05:45 PM
02/18/10 05:45 PM
Posts: 767 NW PA
V10nacuda
NW PA
After using the trailer jack to tilt the trailer front up enought to load a low car. DOn't forget to retract it COMPLETLY & then wonder why a friend going by you is pointing like a madman at the rear of the empty trailer. Cause next time you use the trailer it wont go as high because the jack is a few inches shorter.
Post deleted by Defbob
[Re: dc426]
#616888
02/18/10 06:11 PM
02/18/10 06:11 PM
[Re: galen]
#616890
02/18/10 06:12 PM
02/18/10 06:12 PM
[Re: slantzilla]
#616893
02/18/10 07:06 PM
02/18/10 07:06 PM
Posts: 140 Fort Worth, TX
DMax One
Fort Worth, TX
When you have a nitrous explosion in the intake on the launch, don't continue to drive on down the track scattering little pieces of a plastic airhat all the way down the track. "because it was still running" Secondly, don't do it twice in the same weekend. DAMHIK
68 Barracuda FB "Exploded View" ...still :-(
2008 Ram 2500 CTD
2007 H.D. Softail Custom
92 Jeep Cherokee
[Re: '72CudaRacer]
#616897
02/18/10 08:08 PM
02/18/10 08:08 PM
Posts: 2,510 PA
moparacer
PA
If your a box racer dont forget to change your opponents dial in before the next round....
Dont ask me how I know.....2 or 3 times at least....
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: '72CudaRacer]
#616898
02/18/10 08:10 PM
02/18/10 08:10 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
#1. If you grab a "spare" carb off the shelf to install on an engine,,make sure you didn't take the floats out of it for a buddy to use till his new ones come in the mail. #2 If you have an engine 'full of fuel' and you remove the spark plugs to crank the engine over to keep from hydraulicing and bending a rod, make sure you have the spark plug wires away from the plug holes or the ignition off. #3 Always have a fire extenguisher handy for any unexpected fires.
If you like drag racing, support your local track.
#616899
02/18/10 08:15 PM
02/18/10 08:15 PM
Posts: 3,789 Detroit Michigan
drbill
Detroit Michigan
Where do you want me to start, cuts, burns or general stupid stuff Never grab a brake drum by the center hole after you just used a torch to heat it up to be able to remove it from the axle. Never use chlorinated brake clean to clean the throttle body on a running Mercedes Benz. Never grab the fan shroud to stop your car from rolling into the fence because you forgot to set the parking brake while adjusting the idle mixture screws on the carb.
[Re: galen]
#616902
02/18/10 08:33 PM
02/18/10 08:33 PM
Posts: 549 Bristol, Va
fasteddie
Bristol, Va
ALWAYS, and I mean ALWAYS, put the oil filter on before priming the oil pump of a new motor.
Funny thing is I've forgotten to do this twice, about 20 years apart.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
