Re: distributor build question
[Re: Dodgem]
#611990
02/13/10 12:01 AM
02/13/10 12:01 AM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
You hooking the vacuum advance to the wrong port on the carb. needs to be on ported vacuum not manifold!
yup. ![](/ubbthreads/images/graemlins/iagree.gif)
Should be no vacuum on the port you use, at idle. Only at higher engine speeds.
[Re: Dusted_Ya]
#611995
02/14/10 12:26 PM
02/14/10 12:26 PM
Posts: 902 Seattle, WA
rss
Seattle, WA
Oh right, throttle blades! I'll check that in morning. I just rebuilt the carb and I'll bet I didn't get that set right.
Any good news to report back?
