distributor build question #611988
02/12/10 11:18 PM
02/12/10 11:18 PM
The Dalles, OR.
Dusted_Ya Offline OP
The Dalles, OR.
Okay on a stock 318 with initial timing set at say 7 btdc if I hook up the vacuum line to the distributor and the RPM's jump up and the timing as well what is wrong here? Vacuum pot bad? Springs too weak? Drinking too much???
Re: distributor build question [Re: Dusted_Ya] #611989
02/12/10 11:24 PM
02/12/10 11:24 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
You hooking the vacuum advance to the wrong port on the carb. needs to be on ported vacuum not manifold!
Re: distributor build question [Re: Dodgem] #611990
02/13/10 12:01 AM
02/13/10 12:01 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
yup.
Should be no vacuum on the port you use, at idle. Only at higher engine speeds.
Re: distributor build question [Re: dave571] #611991
02/13/10 12:35 AM
02/13/10 12:35 AM
The Dalles, OR.
The Dalles, OR.
It's a carter 2bbl and there is only 1 port on it beside the one for the PCV valve.
Re: distributor build question [Re: Dusted_Ya] #611992
02/13/10 03:07 AM
02/13/10 03:07 AM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
Sounds like you have the throttle blades open too far which is allowing to much vacuum pull on your vac. advance canister. Advanced timing and increased rpm makes sense since you are engaging the vacuum advance can.
Do you have a vacuum gauge to check vacuum level you are getting from carb port?
Re: distributor build question [Re: rss] #611993
02/13/10 03:44 AM
02/13/10 03:44 AM
The Dalles, OR.
The Dalles, OR.
Oh right, throttle blades! I'll check that in morning. I just rebuilt the carb and I'll bet I didn't get that set right. Thanks rss.
Re: distributor build question [Re: Dusted_Ya] #611994
02/13/10 01:39 PM
02/13/10 01:39 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Like this?
1968
Re: distributor build question [Re: Dusted_Ya] #611995
02/14/10 12:26 PM
02/14/10 12:26 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
Any good news to report back?
