Re: distributor build question
[Re: Dodgem]
#611990
02/13/10 12:01 AM
02/13/10 12:01 AM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
You hooking the vacuum advance to the wrong port on the carb. needs to be on ported vacuum not manifold!
yup.
Should be no vacuum on the port you use, at idle. Only at higher engine speeds.
[Re: Dusted_Ya]
#611995
02/14/10 12:26 PM
02/14/10 12:26 PM
Posts: 902 Seattle, WA
rss
Seattle, WA
Oh right, throttle blades! I'll check that in morning. I just rebuilt the carb and I'll bet I didn't get that set right.
Any good news to report back?
