To Girdle OR Not To Girdle, that is the question
#603548
02/04/10 01:33 PM
02/04/10 01:33 PM
Posts: 79 Texas
Steve Reynolds
Texas
Time to freshen up the 440 in the Demon. Specs.440+.030 12.5 Ross pistons, Eagle rods,440 steel crank,Eddy RPMs polished up, Comp roller,H.S. rockers. 727 mvb, 3800 convertor, 4.30 gear in an 8&3/4. 29 tall, 12 wide Hoosier slicks. Demon is fully dressed w/me in it weighs 3650lbs, w/my wife driving 130lbs less. Car had been running 10.30s until severe over fueling happened & slowed to 10.5s to 10.70s. Washed the rings out, I'm in the process of rebuilding & am in the need for more advice on a Girdle. Thanks, Steve
Re: To Girdle OR Not To Girdle, that is the question
[Re: Steve Reynolds]
#603549
02/04/10 02:03 PM
02/04/10 02:03 PM
Posts: 5,080 organ
maximum entropy
organ
i like my chenoweth girdle. simple install, and got rid of the cap walk i was plagued by.
[Re: maximum entropy]
#603550
02/04/10 02:14 PM
02/04/10 02:14 PM
Posts: 1,613 Deerfield, Ohio
70dusterjohn
Deerfield, Ohio
My Bottom end looks a lot better. Beware of knock offs. I don't think they work as well ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: joshking440]
#603554
02/04/10 03:15 PM
02/04/10 03:15 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
There are some minor drawbacks but with your combo I would use the girdle.
Leave the gun.......take the Cannoli's....Mike
#603555
02/04/10 05:17 PM
02/04/10 05:17 PM
Posts: 976 ontario canada
mac56
ontario canada
Stock caps?
#603557
02/04/10 06:15 PM
02/04/10 06:15 PM
Posts: 2,152 Fancy Farm Ky
wyoming
Fancy Farm Ky
I'm in the process of checking bearings ect in my motor, 493 CU, Indy SR home ported, make enough steam to run 10.4 at 4300' elevation 3740 lbs. Anyway motor was built 4 years ago, right at 300 passes, I insatlled a Chenoweth when building the motor, I had just a little sign of cap walk, on my old motor making about 100 less HP, I'd allways have a substancial amount of capwalk, quite a bit of metal transfer. I do believe the girdle has helped.
[Re: VernMotor]
#603561
02/04/10 07:34 PM
02/04/10 07:34 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
I like my chenoweth girdle. simple install, and slow down most of the cap walk I had. stock caps also.
X2 but i was making800+HP.
[Re: mac56]
#603565
02/04/10 10:02 PM
02/04/10 10:02 PM
Posts: 79 Texas
Steve Reynolds
Texas
Yes, stock caps & bolts & some signs of cap walk. Steve
[Re: AndyF]
#603566
02/04/10 10:06 PM
02/04/10 10:06 PM
Posts: 79 Texas
Steve Reynolds
Texas
Is it a race only engine? If so, you might consider aluminum rods rather than the girdle. And maybe increase the compression ratio. If you're already buying race gas might as well step up to 14:1 or something like that.
Had aluminum rods years ago don't like changing them after 100 passes or less, but the rods were in an 8500-9000 rpm engine & 4 speed Steve
[Re: rowin4]
#603567
02/04/10 10:08 PM
02/04/10 10:08 PM
Posts: 79 Texas
Steve Reynolds
Texas
BCR girdle with aluminum cap kit is the only way to go. Looked so good I hated to put on the oil pan.
I thought I read where BCR is out of business? Steve
