To Girdle OR Not To Girdle, that is the question #603548
02/04/10 01:33 PM
02/04/10 01:33 PM
Texas
Steve Reynolds Offline OP
Texas
Time to freshen up the 440 in the Demon.
Specs.440+.030 12.5 Ross pistons, Eagle rods,440 steel crank,Eddy RPMs polished up, Comp roller,H.S. rockers. 727 mvb, 3800 convertor, 4.30 gear in an 8&3/4. 29 tall, 12 wide Hoosier slicks. Demon is fully dressed w/me in it weighs 3650lbs, w/my wife driving 130lbs less. Car had been running 10.30s until severe over fueling happened & slowed to 10.5s to 10.70s. Washed the rings out, I'm in the process of rebuilding & am in the need for more advice on a Girdle.
Thanks, Steve
Re: To Girdle OR Not To Girdle, that is the question [Re: Steve Reynolds] #603549
02/04/10 02:03 PM
02/04/10 02:03 PM
organ
maximum entropy Offline
organ
i like my chenoweth girdle. simple install, and got rid of the cap walk i was plagued by.
Re: To Girdle OR Not To Girdle, that is the question [Re: maximum entropy] #603550
02/04/10 02:14 PM
02/04/10 02:14 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
My Bottom end looks a lot better. Beware of knock offs. I don't think they work as well
Re: To Girdle OR Not To Girdle, that is the question [Re: 70dusterjohn] #603551
02/04/10 02:42 PM
02/04/10 02:42 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
Do these do anything for a hemi, or are they a waste of time?
Re: To Girdle OR Not To Girdle, that is the question [Re: Steve Reynolds] #603552
02/04/10 02:47 PM
02/04/10 02:47 PM
AndyF Offline
AndyF  Offline
Is it a race only engine? If so, you might consider aluminum rods rather than the girdle. And maybe increase the compression ratio. If you're already buying race gas might as well step up to 14:1 or something like that.
Re: To Girdle OR Not To Girdle, that is the question [Re: AndyF] #603553
02/04/10 03:01 PM
02/04/10 03:01 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I played it as safe as I could with my motor... Aluminum rods BCR girdle and aluminum caps. I couldnt afford a heavy duty KB or INDY lowdeck, and were gonna try to keep it together above 1000hp....
Re: To Girdle OR Not To Girdle, that is the question [Re: joshking440] #603554
02/04/10 03:15 PM
02/04/10 03:15 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
There are some minor drawbacks but with your combo I would use the girdle.
Leave the gun.......take the Cannoli's....Mike
Re: To Girdle OR Not To Girdle, that is the question [Re: maximum entropy] #603555
02/04/10 05:17 PM
02/04/10 05:17 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Stock caps?
Re: To Girdle OR Not To Girdle, that is the question [Re: mac56] #603556
02/04/10 05:33 PM
02/04/10 05:33 PM
organ
organ
yup
Re: To Girdle OR Not To Girdle, that is the question [Re: maximum entropy] #603557
02/04/10 06:15 PM
02/04/10 06:15 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
I'm in the process of checking bearings ect in my motor, 493 CU, Indy SR home ported, make enough steam to run 10.4 at 4300' elevation 3740 lbs. Anyway motor was built 4 years ago, right at 300 passes, I insatlled a Chenoweth when building the motor, I had just a little sign of cap walk, on my old motor making about 100 less HP, I'd allways have a substancial amount of capwalk, quite a bit of metal transfer. I do believe the girdle has helped.
Re: To Girdle OR Not To Girdle, that is the question [Re: wyoming] #603558
02/04/10 07:10 PM
02/04/10 07:10 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
I've got a Chenoweth girdle as well Come to think of it, I got a rack full of them
Re: To Girdle OR Not To Girdle, that is the question [Re: CRE2004] #603559
02/04/10 07:14 PM
02/04/10 07:14 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I ran a chenowith in my old challenger
Mopar Performance
Re: To Girdle OR Not To Girdle, that is the question [Re: moparniac] #603560
02/04/10 07:25 PM
02/04/10 07:25 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I like my chenoweth girdle. simple install, and slow down most of the cap walk I had. stock caps also.
Re: To Girdle OR Not To Girdle, that is the question [Re: VernMotor] #603561
02/04/10 07:34 PM
02/04/10 07:34 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
X2 but i was making800+HP.
Re: To Girdle OR Not To Girdle, that is the question [Re: blownzoom440] #603562
02/04/10 08:05 PM
02/04/10 08:05 PM
Chicago, IL
blownEFI Offline
blownEFI  Offline
Chicago, IL
X3
"These go to eleven", Nigel Tufnel
Re: To Girdle OR Not To Girdle, that is the question [Re: blownEFI] #603563
02/04/10 08:18 PM
02/04/10 08:18 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
BCR girdle with aluminum cap kit is the only way to go.
Looked so good I hated to put on the oil pan.
Re: To Girdle OR Not To Girdle, that is the question [Re: AndyF] #603564
02/04/10 09:58 PM
02/04/10 09:58 PM
Texas
Texas
Just reread my specs compression is 13.5
sorry, yes race fuel only
Steve
Re: To Girdle OR Not To Girdle, that is the question [Re: mac56] #603565
02/04/10 10:02 PM
02/04/10 10:02 PM
Texas
Texas
Yes, stock caps & bolts & some signs of cap walk.
Steve
Re: To Girdle OR Not To Girdle, that is the question [Re: AndyF] #603566
02/04/10 10:06 PM
02/04/10 10:06 PM
Texas
Texas
Had aluminum rods years ago don't like changing them after 100 passes or less, but the rods were in an 8500-9000 rpm engine & 4 speed
Steve
Re: To Girdle OR Not To Girdle, that is the question [Re: rowin4] #603567
02/04/10 10:08 PM
02/04/10 10:08 PM
Texas
Texas
I thought I read where BCR is out of business?
Steve
