1964 727 trans. to use later style Torque converters #584232
01/16/10 03:16 PM
01/16/10 03:16 PM
6T4 Polara Offline OP
I have a 1964 Dodge original 727 big block transmission and I would like to use a later style converter.What is needed to convert it to the 21 spline.I do not want to replace the transmission with a later style.
John
Re: 1964 727 trans. to use later style Torque converters [Re: 6T4 Polara] #584233
01/16/10 03:43 PM
01/16/10 03:43 PM
Chesapeake Va
BobK Offline
BobK  Offline
Chesapeake Va
The input shaft can be swapped out to the newer style.
1964 Plymouth Fury x 2
1964 Plymouth Sport Fury
Re: 1964 727 trans. to use later style Torque converters [Re: BobK] #584234
01/16/10 03:47 PM
01/16/10 03:47 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
There is a LITTLE more than just that ...... simplest thing to do is to find a later model donor trans and swap-out the guts.
Re: 1964 727 trans. to use later style Torque converters [Re: 6T4 Polara] #584235
01/16/10 04:01 PM
01/16/10 04:01 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The only parts needed are the input shaft and the reaction shaft support when using '67-'70 parts for the 24-spline upgrade, the front clutch drum is also needed when using the '71 and later parts.
Re: 1964 727 trans. to use later style Torque converters [Re: John_Kunkel] #584236
01/17/10 06:14 PM
01/17/10 06:14 PM
This is a new area for me any pictures and part numbers would be helpful.
thanks
John
Re: 1964 727 trans. to use later style Torque converters [Re: 6T4 Polara] #584237
01/17/10 06:21 PM
01/17/10 06:21 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You might be able to glean some useful info from my photo album:
http://good-times.webshots.com/album/563460286dArKFK
Re: 1964 727 trans. to use later style Torque converters [Re: John_Kunkel] #584238
01/18/10 08:55 AM
01/18/10 08:55 AM
Thanks.
John
