Re: 1964 727 trans. to use later style Torque converters
[Re: 6T4 Polara]
#584233
01/16/10 03:43 PM
01/16/10 03:43 PM
Posts: 1,021 Chesapeake Va
BobK
Chesapeake Va
The input shaft can be swapped out to the newer style.
1964 Plymouth Fury x 2 1964 Plymouth Sport Fury
[Re: BobK]
#584234
01/16/10 03:47 PM
01/16/10 03:47 PM
Posts: 30,452 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
There is a LITTLE more than just that ...... simplest thing to do is to find a later model donor trans and swap-out the guts.
[Re: 6T4 Polara]
#584235
01/16/10 04:01 PM
01/16/10 04:01 PM
Posts: 25,885 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The only parts needed are the input shaft and the reaction shaft support when using '67-'70 parts for the 24-spline upgrade, the front clutch drum is also needed when using the '71 and later parts.
