Re: Thrust bearing clearance too tight HELP!!
[Re: 375inStroke]
#583338
01/15/10 05:05 PM
01/15/10 05:05 PM
Posts: 10,730 North Dakota
6PakBee
North Dakota
Before you get carried away sanding, set the insert in the cap, take a feeler gauge and make sure the flanges are tight against the cap. If not use a wood block and carefully massage the flanges to be tight against the cap. Do the same thing to the other bearing insert. The reason I mention all this is that I sanded a thrust for clearnace one time and near the end discovered the flanges had been 'cupped' at the edges.
[Re: 6PakBee]
#583339
01/15/10 06:00 PM
01/15/10 06:00 PM
RapidRobert
What he said a good visual for anything abnormal and when (if) you sand have someone hold the piece of fine sandpaper on a piece of glass so you have both hands free to hold both halves together & sand them in a figure 8 pattern.
[Re: draginmopars]
#583344
01/18/10 10:02 PM
01/18/10 10:02 PM
Posts: 8,879 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
take the material off the side toward the front of the block. leaving the T/C or flywheel to thrust toward the factory surface..
Not contradicting this but wondering the reason why.
[Re: Stanton]
#583345
01/18/10 10:17 PM
01/18/10 10:17 PM
Posts: 15,491 the boonies
aarcuda
the boonies
because when they wear, they wear that side- like the torque converter is pushing the crank forward
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
[Re: Stanton]
#583346
01/18/10 10:58 PM
01/18/10 10:58 PM
Posts: 704 USA
rftroy
USA
Are you measuring end play by moving the crank back and forth? If so, before you do ANYTHING check the clearances between the thrust and the crank with feeler gauges to be sure the bearing is the problem. Could be one of the other bearings is touching a filet and not letting the crank move as it should.
Reread the above. You need to first check the clearance out of the block.
Take the crank and put it on a workbench or table away from the block. Place the bearing caps, one at a time, on the #3 journal and measure the clearance with feeler gauges. If it is OK, then you have a problem that will not be fixed with sanding. Bob
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
[Re: ron-denny]
#583348
01/19/10 12:44 PM
01/19/10 12:44 PM
Posts: 7,506 Az
Crizila
Az
Some very good suggestions on this thread, but if all the suggested checks were made - and to answer his ORIGINAL question, wet sanding the thrust surfaces to gain clearance is ok to do - IMO.
Fastest 300
[Re: R/T1968R/T]
#583349
01/19/10 04:50 PM
01/19/10 04:50 PM
Posts: 2,431 USA
SSAAHemiFan
USA
I tried reinstalling an old bearing and there was .006 so I miked the over-all width and found the new bearing was indeed wider by almost .005 maybe the plating was too thick???
Check with the manufacturer to be sure your new bearing is in spec.. You just want to make sure your old bearing isn't worn and that's why there is a difference.
99% sure the problem will be with the new bearing tolerance but theres always a chance !
Once the width is the confirmed problem - sand away!
The figure 8 on a flat surface mentioned above is the best way.
