Thrust bearing clearance too tight HELP!! #583332
01/15/10 02:02 PM
01/15/10 02:02 PM
New York
R/T1968R/T Online happy OP
R/T1968R/T  Online Happy OP
New York
I installed the crank in a 440 set the thrust bearing then measured the end play and it came up too tight..002 I checked for interference and found none. Can I safely wet sand the thrust surfaces down to achieve.006???
Re: Thrust bearing clearance too tight HELP!! [Re: R/T1968R/T] #583333
01/15/10 02:07 PM
01/15/10 02:07 PM
Canada
RobR Offline
RobR  Offline
Canada
Give it a poink on the end of the crank snout a couple of times with a heavy dead blow hammer (hard) before you do anything...
Re: Thrust bearing clearance too tight HELP!! [Re: R/T1968R/T] #583334
01/15/10 02:18 PM
01/15/10 02:18 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
if your using ARP studs or bolts they'll reduce the movement of the #3 cap.
Re: Thrust bearing clearance too tight HELP!! [Re: R/T1968R/T] #583335
01/15/10 02:41 PM
01/15/10 02:41 PM
New York
New York
Im using stock bolts. I already tried the hammer method!! Still at .002
Re: Thrust bearing clearance too tight HELP!! [Re: R/T1968R/T] #583336
01/15/10 03:01 PM
01/15/10 03:01 PM
Az
Crizila Offline
Crizila  Offline
Az
Sand away. No problem.
Fastest 300
Re: Thrust bearing clearance too tight HELP!! [Re: Crizila] #583337
01/15/10 04:40 PM
01/15/10 04:40 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
Try hitting the crank in one direction, then the other while you pry on it. Then torque while prying.
Re: Thrust bearing clearance too tight HELP!! [Re: 375inStroke] #583338
01/15/10 05:05 PM
01/15/10 05:05 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Before you get carried away sanding, set the insert in the cap, take a feeler gauge and make sure the flanges are tight against the cap. If not use a wood block and carefully massage the flanges to be tight against the cap. Do the same thing to the other bearing insert. The reason I mention all this is that I sanded a thrust for clearnace one time and near the end discovered the flanges had been 'cupped' at the edges.
Re: Thrust bearing clearance too tight HELP!! [Re: 6PakBee] #583339
01/15/10 06:00 PM
01/15/10 06:00 PM
What he said a good visual for anything abnormal and when (if) you sand have someone hold the piece of fine sandpaper on a piece of glass so you have both hands free to hold both halves together & sand them in a figure 8 pattern.
Re: Thrust bearing clearance too tight HELP!! [Re: R/T1968R/T] #583340
01/15/10 06:29 PM
01/15/10 06:29 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Are you measuring end play by moving the crank back and forth? If so, before you do ANYTHING check the clearances between the thrust and the crank with feeler gauges to be sure the bearing is the problem. Could be one of the other bearings is touching a filet and not letting the crank move as it should.
Re: Thrust bearing clearance too tight HELP!! [Re: Stanton] #583341
01/15/10 07:15 PM
01/15/10 07:15 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Excellent suggestion.
Re: Thrust bearing clearance too tight HELP!! [Re: R/T1968R/T] #583342
01/15/10 08:02 PM
01/15/10 08:02 PM
New York
New York
I checked the end play with a dial indicator. I used 4 different areas to be safe. As far as the feeler gauge goes there was zero room. I put marking dye on the bearing ends to check against a filet rubbing...nothing.I then tried reinstalling an old bearing and there was .006 so I miked the over-all width and found the new bearing was indeed wider by almost .005 maybe the plating was too thick???
Re: Thrust bearing clearance too tight HELP!! [Re: R/T1968R/T] #583343
01/15/10 08:26 PM
01/15/10 08:26 PM
smyrna,tn
draginmopars Offline
smyrna,tn
If all parts aren't original to each other
take the thrust bearing out, make sure one of the other bearings isn't binding somewhere.
should have excessive clearance.
If you end up modding the thrust bearing, take the material off the side toward the front of the block. leaving the T/C or flywheel to thrust toward the factory surface..
Re: Thrust bearing clearance too tight HELP!! [Re: draginmopars] #583344
01/18/10 10:02 PM
01/18/10 10:02 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Not contradicting this but wondering the reason why.
Re: Thrust bearing clearance too tight HELP!! [Re: Stanton] #583345
01/18/10 10:17 PM
01/18/10 10:17 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
because when they wear, they wear that side- like the torque converter is pushing the crank forward
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: Thrust bearing clearance too tight HELP!! [Re: Stanton] #583346
01/18/10 10:58 PM
01/18/10 10:58 PM
USA
rftroy Offline
rftroy  Offline
USA
Reread the above. You need to first check the clearance out of the block.
Take the crank and put it on a workbench or table away from the block.
Place the bearing caps, one at a time, on the #3 journal and measure the clearance with feeler gauges. If it is OK, then you have a problem that will not be fixed with sanding.
Bob
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: Thrust bearing clearance too tight HELP!! [Re: rftroy] #583347
01/19/10 01:38 AM
01/19/10 01:38 AM
middleport ohio 45760
ron-denny Offline
ron-denny  Offline
i had same problem ,take bearing out of cap and seeif the cap has a champher on each side and that the bearing is fitting cap correct it may be spreading the bearing, may have to do some fileing on cap!
Re: Thrust bearing clearance too tight HELP!! [Re: ron-denny] #583348
01/19/10 12:44 PM
01/19/10 12:44 PM
Az
Crizila Offline
Crizila  Offline
Az
Some very good suggestions on this thread, but if all the suggested checks were made - and to answer his ORIGINAL question, wet sanding the thrust surfaces to gain clearance is ok to do - IMO.
Fastest 300
Re: Thrust bearing clearance too tight HELP!! [Re: R/T1968R/T] #583349
01/19/10 04:50 PM
01/19/10 04:50 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
I tried reinstalling an old bearing and there was .006 so I miked the over-all width and found the new bearing was indeed wider by almost .005 maybe the plating was too thick???
Check with the manufacturer to be sure your new bearing is in spec.. You just want to make sure your old bearing isn't worn and that's why there is a difference.
99% sure the problem will be with the new bearing tolerance but theres always a chance !
Once the width is the confirmed problem - sand away!
The figure 8 on a flat surface mentioned above is the best way.
Re: Thrust bearing clearance too tight HELP!! [Re: SSAAHemiFan] #583350
01/19/10 05:41 PM
01/19/10 05:41 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
You have to set the crank first hit it on the back and on the nose with a big ass rubber mallet! then re measure
