On my currant R3 W-9 I had all sorts of problems, first
it was a new block... I had a shop line bore the mains
and the cam tunnel (cam uses 50mm bearings). Well the
block sat for a couple of months while I waited for
more cash and parts... when I finally started the build
(after a good scrubbing of the block and parts) I
put the main bearings in and set the crank in...
well the crank wouldnt turn... pulled it out and
started measuring, found out that the machine shop
DIDNT line bore the mains(which I payed for). During
the couple of months that the block sat, the machine
shop moved... this is when I started dealing with
Best Machine... took the block to Chuck and had the
mains bored.... put the crank in and now it crashed
on the main webs... ground the clearance needed...
ok the crank turns fine... the main clearance was
fine at .003 every thing on the crank checked out
great,this is a 3.79 billet crank with chevy rod
journals... I weighed the rods, pistons and all that
was correct(I did all that stuff before I took it
to Chuck for a balance job)... Ok, now the rings
are all filed to fit... pistons, rods, rings are all
in.. spins like a dream(I use a torque wrench to
check the effort during building)... now the roller
cam... I had already put the 50mm bearings in the
block... go to slide the cam in... it wont fit in
the bearings... I guess the .0015 press fit was too
much.. I took the cam into work and had a buddy
grind the cam bearing journals .002( I made a plug
on my lathe to get the proper fit then mic'd the
plug)... after that it pretty much was a easy
go....
needless to say I had the engine torn down a good
6-8 times during the build.... FUN
Its one thing to build a engine that was at least
run before but this was the first NEW block I had
done.... now I have a NEW mega block B1 M/C that will
get put together pretty soon
I must commend Best Machine for their great quality work
I beat this little engine big time... has been as
high as 9600 rpm but normal is 8200 every pass
Sorry for the novel
