Lessons learned building engines. #579721
01/11/10 05:50 PM
01/11/10 05:50 PM
Northeast Georgia
47hudson Offline OP
47hudson  Offline OP
Northeast Georgia
We have had a lot of posts lately about stroker kits and lots of info and opinions were offered but also a lot of politics and some conflicts of interest. A lot of guys would love to learn more about what it takes to build an engine for there car but get overloaded and have a hard time sifting through all the BS to find good info. Lets have the novice engine builders offer up some of there personal experiences good or bad to help others out who want to try and build their own engines. No politics no second hand opinions just honest experience.
I'll start.
I have a 493" rb based engine and have been running it since 05. I have an Indy 440-1 head/topend kit. 1050 dom. carb. and run around 12-1 comp.
Heads: I was shocked at the OTB condition of the heads you could actually see a ridge exactly where the CNC machine stopped! I was prepared for this by reading posts here on Moparts so I had a friend clean them up and ck the valve job. Next shocker was after installation and engine breakin I found out my push rods were hitting the heads. Even though this was a package deal I still should have checked final fitment better fortunately I avoided any real damage.
Bottom end: My kit came unballance from 440source I took it to my machinist to have ballanced and checked out everything was ok and I installed the bottom end using narrow bearings and I used a stud girdle from Hughes. A lot of people don't beleave in girdles but I know I have less cap walk with this engine than with the previous 440.
Etc. The oil pickup was originally internal but I later switched to external and feel better about it but never had any real reason for the change. I found out after my favorite machinist retired that sometimes Mopar cam bearings are too tight and you either line bore the block or fit you cam bearings. I think a good machinist who knows Mopars is rare and probably worth a couple extra bucks.
Overall: Once all the bugs were worked out I have been very happy with my engine 9.96 so far in a heavy car.
I know there is a lot more guys out there with good info to share so lets have it!
Please!! personal stories/info only not politics no BS lets help some brothers out!!
Re: Lessons learned building engines. [Re: 47hudson] #579722
01/11/10 07:07 PM
01/11/10 07:07 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
I'll start.
The mechanics of putting building the engine is pretty straight forward. What sinks a lot of people is attention to detail and keeping everything clean.
I don't care who does the machine work, supplies the parts, etc. Check everything yourself. Mock everything up first. It might mean putting it together and taking it apart a few times, but believe me you'll be surprise how many "gotchas" you might find during the mock up. Do your piston to valve checks and cam degreeing before final assembly. Once the mock up is done, clean EVERYTHING.
Measure all your bearing clearances. Put the cam you are going to use and make sure it turns freely. If it binds, fix it. Take your time.
I know it's overkill but get some special tools. Dial bore gauges, tapered ring compressors all help to make things more fool proof.
Use the right stuff/Hylomar blue for sealing the oil, timing cover, intake, etc.
Use a good break in oil.
Re: Lessons learned building engines. [Re: torkrules] #579723
01/11/10 09:56 PM
01/11/10 09:56 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
Ill play this game.
When we were building one of the race motors,
we snapped a couple different piston rings.
The ring compressor was not on properly.
Lesson learned is dont be afraid to start over, dont force it.
We had been told about this great oil.
It is Joe Gibbs oil.
Well it is really nice oil, but they forgot to tell me to heat it.
We found out later that you have to run a pan heater.
They want there oil hot when you start the motor.
They also want the bearing clearances super tight.
Well i did not have either one of those,and i fried the motor in the break in process.
It had oil pressure but we checked the bearings,and they were fried.
We had to tear whole motor apart and fix everything.
Lesson learned is that the latest and greatest may not be the best thing for your application.
Re: Lessons learned building engines. [Re: HEMIDARTS] #579724
01/11/10 10:38 PM
01/11/10 10:38 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I have been building diesels for many years and race engines for just a few and all the race were for my sons and I, I found that honing to the proper finish challenging, too many years of diesels with pre honed liners, In my opinion cyl wall finish can make or brake a race engine
Re: Lessons learned building engines. [Re: HEMIDARTS] #579725
01/11/10 10:45 PM
01/11/10 10:45 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
OK
Today's lessons...
Dont purchase that oil, and dont listen to the people who want "super tight bearing clearances"...LOL
This is NOT a Joke
class dismissed LOL
Re: Lessons learned building engines. [Re: Bob_Coomer] #579726
01/11/10 11:12 PM
01/11/10 11:12 PM
pacific northwest
Stroker Scamp Online content
Stroker Scamp  Online Content
pacific northwest
i have one for ya, in highschool i rebuilt my 340, i had no clue what i was doing, so i figured take out the old parts and put in new, so i did new rings and bearings, didnt check anything clearance wise, ps i didnt have anyone helping me, so i put the new parts in and......well it was hard starting and shook alot drove it about 30 miles and then it finally siezed, so that being said from then on i read alot and ask many questions before starting a project,,,,,,,,i still cant believe the thing even ran
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Lessons learned building engines. [Re: Bob_Coomer] #579727
01/11/10 11:13 PM
01/11/10 11:13 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
OK
Today's lessons...
This is NOT a Joke
class dismissed LOL
i think the oil is great, when used in the proper application.
I still use the break in oil and some other stuff to coat my bearings.
Re: Lessons learned building engines. [Re: HEMIDARTS] #579728
01/12/10 12:57 AM
01/12/10 12:57 AM
MR_P_BODY Offline
MR_P_BODY  Offline
On my currant R3 W-9 I had all sorts of problems, first
it was a new block... I had a shop line bore the mains
and the cam tunnel (cam uses 50mm bearings). Well the
block sat for a couple of months while I waited for
more cash and parts... when I finally started the build
(after a good scrubbing of the block and parts) I
put the main bearings in and set the crank in...
well the crank wouldnt turn... pulled it out and
started measuring, found out that the machine shop
DIDNT line bore the mains(which I payed for). During
the couple of months that the block sat, the machine
shop moved... this is when I started dealing with
Best Machine... took the block to Chuck and had the
mains bored.... put the crank in and now it crashed
on the main webs... ground the clearance needed...
ok the crank turns fine... the main clearance was
fine at .003 every thing on the crank checked out
great,this is a 3.79 billet crank with chevy rod
journals... I weighed the rods, pistons and all that
was correct(I did all that stuff before I took it
to Chuck for a balance job)... Ok, now the rings
are all filed to fit... pistons, rods, rings are all
in.. spins like a dream(I use a torque wrench to
check the effort during building)... now the roller
cam... I had already put the 50mm bearings in the
block... go to slide the cam in... it wont fit in
the bearings... I guess the .0015 press fit was too
much.. I took the cam into work and had a buddy
grind the cam bearing journals .002( I made a plug
on my lathe to get the proper fit then mic'd the
plug)... after that it pretty much was a easy
go....
needless to say I had the engine torn down a good
6-8 times during the build.... FUN
Its one thing to build a engine that was at least
run before but this was the first NEW block I had
done.... now I have a NEW mega block B1 M/C that will
get put together pretty soon
I must commend Best Machine for their great quality work
I beat this little engine big time... has been as
high as 9600 rpm but normal is 8200 every pass
Sorry for the novel
Re: Lessons learned building engines. [Re: HEMIDARTS] #579729
01/12/10 01:50 AM
01/12/10 01:50 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
OK
Today's lessons...
This is NOT a Joke
class dismissed LOL
You know, they sell a 5w30 break in oil now. A bit on the thin side. I prefer the 30wt. I've broke in 10+ engines on their stuff running regular bearing clearances (.001" per inch of journal size).
Anyway, sorry if I got off topic.
Re: Lessons learned building engines. [Re: dodgeboy11] #579730
01/12/10 08:46 AM
01/12/10 08:46 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I always fit the cam 1st on any build. That way if you have the fit the bearings you can do it dry. A lot easier to re clean the block. My R-3 block did not clear my Stock 72 340 crank. The main webs needed clearancing. The one thing I missed during the build was the upper timing cover holes. They were present but in the wrong location. By this time the whole short block was assembled.
Doug
Re: Lessons learned building engines. [Re: dvw] #579731
01/12/10 08:58 AM
01/12/10 08:58 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
dont use a bathroom towel to clean the inside of your block. first off, the wife will be pissed. second of all, the lint from the towel will coat the inside of the block and will eventually get stuck on the oil pump pickup screen causing low oil pressure about 10 minutes into the break in. btw, if there is a coating of oil on the block, you wont even see the lint. trust me, use LINT FREE CLOTHS to clean your stuff
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: Lessons learned building engines. [Re: aarcuda] #579732
01/12/10 09:42 AM
01/12/10 09:42 AM
Peoples republic of clackamas ...
atoetly Offline
atoetly  Offline
Don't forget to use a torque wrench on the three cam bolts! Especially if your running a cloyes hex adjust timing set. You will end up with variable cam timing and eventually a worn out timing cover
Re: Lessons learned building engines. [Re: atoetly] #579733
01/12/10 10:02 AM
01/12/10 10:02 AM
Northeast Georgia
47hudson Offline OP
47hudson  Offline OP
Northeast Georgia
Another one. We have a flat bottom tap to run through the crank and torque conv. to clean the loctite out of the threads during reassembly. We also use 12 point bolts for the crank and converter on the flex plate. Clean the threads, use loctite and no more loose converter bolts.
Re: Lessons learned building engines. [Re: 47hudson] #579734
01/12/10 01:37 PM
01/12/10 01:37 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Yes! I'm not the only one that has experienced loose converter bolts!!!
Re: Lessons learned building engines. [Re: gsmopar] #579735
01/12/10 07:48 PM
01/12/10 07:48 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
Make sure to pay attention to detail. The one you overlook will bite your behind every time. That includes making sure the cam end play is correct. Ask me how I know.....
Re: Lessons learned building engines. [Re: Dartin] #579736
01/12/10 08:14 PM
01/12/10 08:14 PM
organ
maximum entropy Offline
organ
mock up, mock up, mock up. clean, clean, clean. the final assembly is about 1% of the total equation. it's the reward for weeks and weeks of mock up, mock up...
Re: Lessons learned building engines. [Re: maximum entropy] #579737
01/12/10 08:22 PM
01/12/10 08:22 PM
UK
602heavy Offline
602heavy  Offline
UK
Top & bottom main bearings fitted the right way round would be a good start.
Re: Lessons learned building engines. [Re: maximum entropy] #579738
01/12/10 08:28 PM
01/12/10 08:28 PM
Detroit, MI
RawnDart Offline
RawnDart  Offline
Detroit, MI
Never forget about the oil galley plugs in the block.
That was a hard lesson learned when I missed one on the lower RH side of the block.
Re: Lessons learned building engines. [Re: 602heavy] #579739
01/13/10 12:25 AM
01/13/10 12:25 AM
smyrna,tn
draginmopars Offline
smyrna,tn
some Rod bearings also have a upper and lower (one side is chamfered/beveled to help clear the radius on the crank)
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: Lessons learned building engines. [Re: draginmopars] #579740
01/13/10 12:59 AM
01/13/10 12:59 AM
Escondido, CA
64physhy Offline
64physhy  Offline
Escondido, CA
Come up with a plan and decide on the combo before you start buying parts. I don't know how much I wasted buying parts impulsively that I ended up not using, then selling for way less than they cost. Also, don't waste the money on a gasket kit (unless it's a stock or mild rebuild). Of the whole kit I bought, I only used a few out of it, the rest (head gaskets, intake gaskets, header gaskets, etc) were better than the ones in the standard kit.
