Page 4 of 6 1 2 3 4 5 6
Re: 440 source kit update part 2 [Re: moderncylinder] #576008
01/08/10 03:43 PM
01/08/10 03:43 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
Having bought these kits/parts before, this is what I would like to see...FWIW this would pertain to every kit manufacture.
1 - running list of issues found so that they don't get buried in the post.
2 - Typical cost to fix these issues weather or not you decide to pass that along to the customer.
3 - This kit was bought ballanced so after measuring the individual parts and calculating the bobweight, and spinning the crank in the machine, was it found to be correct ?
4 - was it worth buying the kit pre-ballanced since a lot of time was invested remeasuring and rechecking ? It seems like 50% of the work is repeated in rechecking stuff.
5 - Were any parts returned or unacceptable to use ?
6 - Were the parts exchanged and if so, how was customer survice ?
Would like to see these answered since I'm a Hobbiest that likes to assemble my own stuff and often buy budget parts.
Not asking for any comparisons to Callies, Winburg, Crower or anything like that.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: 440 source kit update part 2 [Re: 440Jim] #576009
01/08/10 04:00 PM
01/08/10 04:00 PM
NC
440Jim Offline
440Jim  Offline
NC
It appears you have different rods in your kit compared to the ones in mine (bought in 2007). I have 6.535", 2.200/0.990, I-beam, with ARP 8740 bolts.
I didn't see any bearings stickout or misaligned in my rods, but I only mocked up 2 so far.
I just finished checking these things on all 8 of my rods. I used 1 bearing pair that came out of one of my previous freshen-ups. The bearing tang location lined up the bearing shells nicely in all the rods.
I also did a check on the rod lengths. The only thing I can do at home is measure the bores with a mic (0.0001") and the distance between the holes with a caliper (0.0005" readout), then calculate the length. So it may not be perfect, but this is what I came up with FWIW:
6.5339
6.5343
6.5339
6.5344
6.5339
6.5334
6.5345
6.5346
6.5341 Average (at 55ºF). I think that set variation is fine, +.0005/-.0007
Re: 440 source kit update part 2 [Re: turbobitt] #576010
01/08/10 04:30 PM
01/08/10 04:30 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
With turbobitt, starting with a known problem crank was probably not he best thing to start a lets publish the facts on a new kit, not a second time around kit. We need the facts, nothing but the facts My source kit checked out within acceptable tolerances, it must have been correct as the machine shop ripped me a new #$%^& on the block prep. We need the facts , no commentary input from the peanut gallery . Got that, no other input!!!!!!!!!
Re: 440 source kit update part 2 [Re: rowin4] #576011
01/08/10 04:45 PM
01/08/10 04:45 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Why would a machine shop take a balanced assembly that was in spec and proceed to mess it up?
Re: 440 source kit update part 2 [Re: rowin4] #576012
01/08/10 04:48 PM
01/08/10 04:48 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I still say 10 different engine shops would have 10 different results... and I really dont think bob came on here to micro manage "440 source"... its just that well. 440 source stuff has been under the gun since day one I guess......
Have any of you guys seen The FAIL thread on Yellow Bullet.... all kinds of parts / brands going down tubes
Mopar Performance
Re: 440 source kit update part 2 [Re: moparniac] #576013
01/08/10 05:49 PM
01/08/10 05:49 PM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
Ok, I'll throw in my 2 cents. I don't know BG, but based on reading his posts over the last few yrs, he seems to be very knowledgeable. Even though his post on this stroker kit is intended to be a public service, it's not coming across in a very good light. I think it's completely unfair to evaluate someones products, when that product is used and has had machine work done on it. Look at it like this, what if I bought a used BGR motor off of someone, and that motor had been re-assembled and altered since it was first built. I then took it apart and posted what I found, just for informational purposes. I doubt BGR would appreciate it. If you want to evaluate an engine kit, buy a new one.
Re: 440 source kit update part 2 [Re: moparniac] #576014
01/08/10 05:52 PM
01/08/10 05:52 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My opinon is any body can have bad parts.Ive seen too many new parts that are bad and Ive been doing it as a pro for almost 30 years.This is a good thread so lets not screw it up.My Source heads impressed my machinist and he has been doing it for over 30 years and build it all from Packard 8s to blower motors.A few members here know him and he is very very fussy.So Bob keep plugging away at it and lets see the results.I for one appreciate it.Rocky
Chrysler Firepower
Re: 440 source kit update part 2 [Re: therocks] #576015
01/08/10 06:54 PM
01/08/10 06:54 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Stole Max's woobbie,feeling warm and fuzzy alittle damp to,I may have just peed myself All is good
Re: 440 source kit update part 2 [Re: Quicktree] #576016
01/08/10 07:06 PM
01/08/10 07:06 PM
Lehigh Acres, Florida
rickstershemi Offline
Gentelman, I do not see any more good coming from build post 1 so I locked it. All the players gave their and members have to decide on what is right for them. I say continue with the build and post what is found, (Others may as well) but please leave personal opinions about the products out, just the facts found, I think this is the way BG intended the build to be.
Ted
Ted don't rule from the bench if the threads break no rules I suggest letting them run their course. just my opinion for whats it's worth.
This is America.....Right
Rickster
Re: 440 source kit update part 2 [Re: Diego_Ted] #576017
01/08/10 07:09 PM
01/08/10 07:09 PM
What I would like to say is, I have no problems with facts found, I adjudicate claims for a living and live and die by the fact. I do have a problem with inuendo or pseudo facts (opinions) because they help no one, they are like #$@$% everyone has one. Everyone who has spent any amount of time on here knows what goes on in these types of posts, so to keep things civil, personal opinions about good, bad, ugly are just subjective. The only objective stuff is facts, so lets post facts and let the members decide who they want to spend their $$ with.
Diego
and that is your opinion Ted.... I for one like to see the Censorship kept to a minimum...
Rickster
Re: 440 source kit update part 2 [Re: rickstershemi] #576018
01/08/10 07:28 PM
01/08/10 07:28 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Diego
Rickster
no kidding, keep your opinions to yourself
Re: 440 source kit update part 2 [Re: Quicktree] #576019
01/08/10 07:35 PM
01/08/10 07:35 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Diego
Rickster
Any body wanna borrow my woobbie blankee(slightly damp)
Re: 440 source kit update part 2 [Re: B G Racing] #576020
01/08/10 08:07 PM
01/08/10 08:07 PM
somewhereintheswampsofjersey
1swingin Offline
1swingin  Offline
I love this thread. Iam getting ready to purchase a 470 low deck kit and its good to see the pros and cons of the source kits. Iam sure none of them are "drop it in and go racing" kits but iam learning alot about what to look for and checking everything 5 times. Iam a budget minded racer and was leaning towards the source kits but the more i read,the muscle motors kit is looking better and better. Thanks for all the info.
"I aint here on buisness baby,Iam only here for fun"
Re: 440 source kit update part 2 [Re: 1swingin] #576021
01/08/10 08:13 PM
01/08/10 08:13 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I know of several people you can buy a drop in kit from
Re: 440 source kit update part 2 [Re: Quicktree] #576022
01/08/10 09:03 PM
01/08/10 09:03 PM
Diego-Town, CA
Diego_Ted Offline
Diego_Ted  Offline
Diego-Town, CA
I have no issue if your posting facts, personal attacks will not be tolorated , this comes from the Boss not us mods.
Diego
Re: 440 source kit update part 2 [Re: Diego_Ted] #576023
01/09/10 12:09 AM
01/09/10 12:09 AM
Diego
Must have missed something Ted...didn't see any personal attacks...actually pretty impressed to see that also
Rickster
Re: 440 source kit update part 2 [Re: B G Racing] #576024
01/09/10 12:10 AM
01/09/10 12:10 AM
Diego
Rickster
No Thanks Bob....Wife got me my very own for Xmas
Rickster
Re: 440 source kit update part 2 [Re: B G Racing] #576025
01/09/10 05:08 AM
01/09/10 05:08 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
James,I'am not mad at anyone,Brandon nor Jeff,but if they want to contribute do so in an uncondenscending way.I have a good command of the English language and can interpert verbal usage quite well.
BG don't take this as a personal attack, just an observation. I respect you and what you're doing, but I feel this needs saying. Perhaps you need to go back and re-read your previous posts. You started out with the little remarks and attitude before brandon or jeff even chimed in. If I were in their shoes, I would have probably reacted in the same way. Don't try and tell us your pooh doesn't stink like eveyone else's. You buried your comments in there a little better, but the message still comes through loud and clear. I'm not defending or bashing anyone, but you didn't exactly take the high road either.
But thanks for doing what you did and addressing the issues. However like others have mentioned, this would have been more helpful on a current, previously untouched kit rather than an older one that's been monkeyed with already. Still very helpful though.
Re: 440 source kit update part 2 [Re: DaytonaTurbo] #576026
01/09/10 05:40 AM
01/09/10 05:40 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
TO THE MODS -
PLEASE.....JUST LET US HAVE ONE FREAKIN TOPIC WHERE WE CAN CONVERSE ON A POPULAR SUBJECT -----
NO ONE WILL BE HURT , NO ONE'S FEELINGS WILL BE HURT.
THIS IS A GREAT SUBJECT AND WE ALL WANT TO SEE RESULTS FROM A SHOP--- I DONT SEE ANY SERIOUS BASHING AND IF ANYONE HAS ANY COMMON SENSE THEY WILL DETECT ANY OBVIOUS BIAS .
I ENCOURAGE ANOTHER SHOP TO DO THE SAME THREAD WITH A EAGLE , SCAT , ETC... KIT NEXT MONTH.
THIS IS GREAT INFO WITH MEASUREMENTS AND PICTURES.
PLEASE.........MODS....LET US MAKE UP OUR OWN FREAKIN MINDS FOR ONCE !!!!
Re: 440 source kit update part 2 [Re: 493_DART] #576027
01/09/10 10:30 AM
01/09/10 10:30 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
TO THE MODS -
PLEASE STOP YELLING!!!!!!!!!!!!!!!
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
