Converting 1969 car to 1970+ Electronic Voltage Reg?
#564207
12/27/09 07:25 PM
12/27/09 07:25 PM
Posts: 249 Kahleefahwniah
69CopperCoronet
Kahleefahwniah
How do you convert a mopar with a 1969-down engine wiring harness to a 1970+ electronic voltage regulator (i.e. this one: http://www.summitracing.com/parts/DCC-4529794/)What is the field and ground wire connection on this regulator? Also, I am having issues with proper voltage regulation, even with a brand new regulator installed. The alternator is constantly putting out around 14+ volts. What should I troubleshoot to fix this? Thanks for the help!
Re: Converting 1969 car to 1970+ Electronic Voltage Reg?
[Re: 69CopperCoronet]
#564209
12/27/09 07:30 PM
12/27/09 07:30 PM
Posts: 415 Indiana
Pentastar440
Indiana
Here's the wiring diagram :
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
[Re: OzHemi]
#564212
12/27/09 08:25 PM
12/27/09 08:25 PM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
There is another alternative..Thanks to E-Booger. Go to Autozone,get a 25.00 VR704 electronic voltage regulator... Pop off both the new and old covers from the regulators.... Install the oldd cover over the new regulator and with no wire cutting-no alternator swapping,just install back into its stock location and enjoy modern techno;ogy and still look factory stock..
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
#564214
12/27/09 09:56 PM
12/27/09 09:56 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
How do you convert a mopar with a 1969-down engine wiring harness to a 1970+ electronic voltage regulator (i.e. this one: http://www.summitracing.com/parts/DCC-4529794/) What is the field and ground wire connection on this regulator?
As said 14 plus is fine. No real need to worry till you get into the 15's.
Most likely cause of an overcharge(if there was one present, which it doesn't seem there is) is a voltage drop in the wire on IGN lead to the voltage reg. I have seen this wire show only 12.5 volts when the battery was over 15. Regulator thinks there is not enough charge, so it gives the alternator more field current. More amperage is the result, so up goes the voltage.
Here's some random info on the dual field myth No need to wire in the newer style regulator
[Re: 68Cbarge]
#564215
12/27/09 10:18 PM
12/27/09 10:18 PM
Posts: 1,271 Vista, California
67Satty
Vista, California
I've got something like this from FBO when converting my '67 Satellite to pointless and dual feed alternator. Does that mean I can just plug it in like stock and not have to run and splice a wire from one of the feeds on the alternator back to the voltage regulator with this kind?
[Re: 67Satty]
#564217
12/28/09 12:20 AM
12/28/09 12:20 AM
Andrewh
you are going to have to try again. that didn't make sense. Either you have a duel field alt or you don't. The pictured vr is the single field.
[Re: Pentastar440]
#564219
12/28/09 01:44 PM
12/28/09 01:44 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
I made an upgrade diagram based on that:
[Re: NachoRT74]
#564220
12/28/09 01:47 PM
12/28/09 01:47 PM
NachoRT74
Valencia, España
or if you preffers this view
[Re: NachoRT74]
#564221
12/28/09 01:49 PM
12/28/09 01:49 PM
NachoRT74
Valencia, España
then, about the electronic unit to one field wired alt... I have had some different opinions about those units, being some bad, some good.
about the dual field myth... he is right all alt have dual field since you need both fields to create magnetism inside the alt.
The diff is being when both are wired from a diff alt source or one wired and the other one directly grounded to alt. Thats maybe the reason to the single and dual field alts denomination.
