Converting 1969 car to 1970+ Electronic Voltage Reg? #564207
12/27/09 07:25 PM
12/27/09 07:25 PM
Kahleefahwniah
69CopperCoronet Offline OP
Kahleefahwniah
How do you convert a mopar with a 1969-down engine wiring harness to a 1970+ electronic voltage regulator (i.e. this one: http://www.summitracing.com/parts/DCC-4529794/)
What is the field and ground wire connection on this regulator?
Also, I am having issues with proper voltage regulation, even with a brand new regulator installed. The alternator is constantly putting out around 14+ volts. What should I troubleshoot to fix this?
Thanks for the help!
Re: Converting 1969 car to 1970+ Electronic Voltage Reg? [Re: 69CopperCoronet] #564208
12/27/09 07:29 PM
12/27/09 07:29 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
From the tech archives...simple to wire it up, just grab a plug for the new style regulator
Re: Converting 1969 car to 1970+ Electronic Voltage Reg? [Re: 69CopperCoronet] #564209
12/27/09 07:30 PM
12/27/09 07:30 PM
Indiana
P
Pentastar440 Offline
P
Indiana
Here's the wiring diagram :
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: Converting 1969 car to 1970+ Electronic Voltage Reg? [Re: 69CopperCoronet] #564210
12/27/09 07:31 PM
12/27/09 07:31 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Oh, and 14 volts is just fine... 13.8 - 14.4 is what you want to see from memory.
Re: Converting 1969 car to 1970+ Electronic Voltage Reg? [Re: 69CopperCoronet] #564211
12/27/09 08:13 PM
12/27/09 08:13 PM
Starting w the battery & working outward from both terminals I'd check the voltage drops on ALL of your connections at a fast idle w accessories on. Some of those connections have not been disturbed for 4 decades & most likely are in need of cleaning.
Re: Converting 1969 car to 1970+ Electronic Voltage Reg? [Re: OzHemi] #564212
12/27/09 08:25 PM
12/27/09 08:25 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
There is another alternative..Thanks to E-Booger.
Go to Autozone,get a 25.00 VR704 electronic voltage regulator...
Pop off both the new and old covers from the regulators....
Install the oldd cover over the new regulator and with no wire cutting-no alternator swapping,just install back into its stock location and enjoy modern techno;ogy and still look factory stock..
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: Converting 1969 car to 1970+ Electronic Voltage Reg? [Re: 68Cbarge] #564213
12/27/09 08:29 PM
12/27/09 08:29 PM
Andrewh Online content
Andrewh  Online Content
I agree, there is no reason to go with the newer type when they make an electronic 1 field wire one.
Also I agree 14.5 is fine.
Make sure it holds around that when you rev the engine up as well, and you are good to go.
If it goes higher, then start tracing back the sensing line to see where your voltage drop is, or make sure the vr is grounded.
But otherwise it sounds like it is working fine.
Re: Converting 1969 car to 1970+ Electronic Voltage Reg? [Re: 69CopperCoronet] #564214
12/27/09 09:56 PM
12/27/09 09:56 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
As said 14 plus is fine. No real need to worry till you get into the 15's.
Most likely cause of an overcharge(if there was one present, which it doesn't seem there is) is a voltage drop in the wire on IGN lead to the voltage reg. I have seen this wire show only 12.5 volts when the battery was over 15. Regulator thinks there is not enough charge, so it gives the alternator more field current. More amperage is the result, so up goes the voltage.
Here's some random info on the dual field myth No need to wire in the newer style regulator
Re: Converting 1969 car to 1970+ Electronic Voltage Reg [Re: 68Cbarge] #564215
12/27/09 10:18 PM
12/27/09 10:18 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
I've got something like this from FBO when converting my '67 Satellite to pointless and dual feed alternator. Does that mean I can just plug it in like stock and not have to run and splice a wire from one of the feeds on the alternator back to the voltage regulator with this kind?
Re: Converting 1969 car to 1970+ Electronic Voltage Reg? [Re: Andrewh] #564216
12/27/09 10:19 PM
12/27/09 10:19 PM
And with that regulator anytime in the future if you upgrade to a later higher amp common 2 field terminal alt you can easily ground one of the alt field terminals to the alt case w several inches of wire & 2 crimp on terminals.
Re: Converting 1969 car to 1970+ Electronic Voltage Reg [Re: 67Satty] #564217
12/28/09 12:20 AM
12/28/09 12:20 AM
you are going to have to try again. that didn't make sense. Either you have a duel field alt or you don't.
The pictured vr is the single field.
Re: Converting 1969 car to 1970+ Electronic Voltage Reg [Re: 67Satty] #564218
12/28/09 12:53 AM
12/28/09 12:53 AM
yes plug it in like stock & ground one of the alt male field terminals to ground in your 2 field terminal alt. The one in the Summitt pic functions identical (electronic) but it's a '70 up flat case style and is NOT needed but yes that one would require you to run the 2nd alt field terminal (thats currently grounded) back to the right hand side terminal in the VR triangle per the diagram earlier in this thread
Re: Converting 1969 car to 1970+ Electronic Voltage Reg? [Re: Pentastar440] #564219
12/28/09 01:44 PM
12/28/09 01:44 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I made an upgrade diagram based on that:
Re: Converting 1969 car to 1970+ Electronic Voltage Reg? [Re: NachoRT74] #564220
12/28/09 01:47 PM
12/28/09 01:47 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
or if you preffers this view
Re: Converting 1969 car to 1970+ Electronic Voltage Reg? [Re: NachoRT74] #564221
12/28/09 01:49 PM
12/28/09 01:49 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
then, about the electronic unit to one field wired alt... I have had some different opinions about those units, being some bad, some good.
about the dual field myth... he is right all alt have dual field since you need both fields to create magnetism inside the alt.
The diff is being when both are wired from a diff alt source or one wired and the other one directly grounded to alt. Thats maybe the reason to the single and dual field alts denomination.
