How do you convert a mopar with a 1969-down engine wiring harness to a 1970+ electronic voltage regulator (i.e. this one: http://www.summitracing.com/parts/DCC-4529794/) What is the field and ground wire connection on this regulator?
Also, I am having issues with proper voltage regulation, even with a brand new regulator installed. The alternator is constantly putting out around 14+ volts. What should I troubleshoot to fix this?
Thanks for the help!
Entire Thread
Subject
Posted By
Posted
Converting 1969 car to 1970+ Electronic Voltage Reg?
