727 Push Button Question #562340
12/25/09 05:19 PM
12/25/09 05:19 PM
North Carolina, USA
Husker1 Offline OP
Husker1  Offline OP
North Carolina, USA
i have two questions concerning my '65 b-body:
will a '64 727 pushbutton trans work in a '65? I know the '65 uses a different column than '66 and later.
does anybody make a adapter to connect a '65 column to a '66 and up 727?
thanks
Re: 727 Push Button Question [Re: Husker1] #562341
12/25/09 06:13 PM
12/25/09 06:13 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
If you are talking about the Shifter for a Push button transmission there is an aftermarket shifter for the push button Transmission. I do not remember who makes this but I see it in many a car at the drag strip. This shifter I believe is to relocate the location to the middle of the car,much like all other Chrysler cars.
1971 HEMI E BODY REGISTRY
Re: 727 Push Button Question [Re: hemicar1971] #562342
12/25/09 06:54 PM
12/25/09 06:54 PM
Piqua, Ohio
dodgeram440 Offline
Happy Birthday dodgeram440  Offline
Piqua, Ohio
I believe the 65 trans is a model all it's own. It is the last year for the push button shifter, but the first year for the slip yoke drive shaft. So to answer your first question, the 64 tranny won't work due to the differences in the drive shaft yoke. The 66 and up may work better for you, however, you'll need a different tranny mount and shifter. I swapped a newer 383/727 into a 65 Coronet 500 hardtop once many years ago. I used a B&M Megashifter and adapted it to the factory console and used a tranny crossmember from a 78 Cordoba to fit the tranny mount. The 65 mount was square and flat instead of the newer style, and I don't believe the old mount fit the new trannny. So I adapted.
Re: 727 Push Button Question [Re: Husker1] #562343
12/25/09 06:55 PM
12/25/09 06:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A '65 727 will work with the '64 pushbuttons but you'll have to change the valve body or install the PB roostercomb and manual valve in the '65 VB.
Imperial Services can convert your '64 pushbutton shifter to work on '66 and later transmissions.
http://www.imperialservices.net/Imperial%20Services%20-%20%2762-%2770%20B-Body%20Parts.htm
Re: 727 Push Button Question [Re: Husker1] #562344
12/25/09 07:00 PM
12/25/09 07:00 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Remember the 65 uses a slip yoke for the driveshaft, the 64 is ball and trunion.
Sheldon
Re: 727 Push Button Question [Re: Husker1] #562345
12/25/09 07:17 PM
12/25/09 07:17 PM
thanks
64 tranny in stock form has a ball and trunion tailshaft, most guys switch to a 65 slip tail shaft which is a one year only.
as far as bellhousings, 62-65 all will work, all use cable shift.
from what i have heard that conversion from imperial services suck,too many problems related to the conversion,id pass on that and get the 65 tailshaft housing and keep it stock.
Re: 727 Push Button Question [Re: Husker1] #562346
12/25/09 09:29 PM
12/25/09 09:29 PM
North Carolina, USA
Husker1 Offline OP
Husker1  Offline OP
North Carolina, USA
I should have given a better description to start with - sorry. i have a '65 ply belvedere with a '78 727 (freshly rebuilt), i have a cheap floor shifter in it now. i would like to convert it back to the column (still has stock '65 two cable type) but am not sure the best way to do so. a '64 push button 727 just came up for sale or i have thought of finding a column from a '66 and up car to use the current trans linkage.
thanks for the help.
Re: 727 Push Button Question [Re: Husker1] #562347
12/25/09 09:44 PM
12/25/09 09:44 PM
Per Kunkel's info the (stock pb vb)64 would not work w the shifter cable from your orig 65 column. Since you're up & running (w the 78 727) I'd find a 66 up col w the stock 66 up rod linkage and then you can lose the floor shifter.
Re: 727 Push Button Question [Re: RapidRobert] #562348
12/25/09 11:05 PM
12/25/09 11:05 PM
okla.
sam64 Offline
sam64  Offline
okla.
64 65 use same valve body,65 was a one year trans,also one year cable shift column.64 trunion,65 slip yoke.65 small block trans are more available and cheaper,take a 64 big block main case,65 sb tail housing assembly and you can still use your d-shaft.
Re: 727 Push Button Question [Re: sam64] #562349
12/26/09 12:49 AM
12/26/09 12:49 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Something to think-about and maybe digest ....
THINK about putting the complete push-button set-up IN the 65 B body.
I know of several people who have done-this ...and it does have a WOWfactor ..
Re: 727 Push Button Question [Re: sam64] #562350
12/26/09 01:00 AM
12/26/09 01:00 AM
64 only or will other years of BB main cases work? EDIT Did I misquote Kunkels info and a 64 PB trans (stock 64 VB) WILL in fact work w 65 column cable shifter?
Re: 727 Push Button Question [Re: RapidRobert] #562351
12/26/09 01:31 AM
12/26/09 01:31 AM
Piqua, Ohio
dodgeram440 Offline
Piqua, Ohio
I don't see why the 64 and 65 would be any different as far as the shift mechanism goes. They both have push button cable operated shifters. Although the original poster did mention his 65 is actually column shifted, I believe it still uses the cables. I know the 65 uses two cables: one to shift the gears, and one to control the park. The 64's should be the same. To the best of my limited knowledge, the ONLY difference between a 64 and 65 transmissions are the 64 has the ball and trunion tail and the 65 has a slip yoke. If the OP has both a 64 and a newer trans, he would just have to get the 64 rebuilt using the newer model tail shaft and housing. I only see two possible problems with this. I'm not sure if the park cable runs to the back of the actual case, or to the tail housing (it's been a long time since I've seen the set up). The second problem is the tranny mount. (On second thought, that is not actually a problem since that tranny is currently in the car. Never mind.)
Re: 727 Push Button Question [Re: dodgeram440] #562352
12/26/09 11:38 AM
12/26/09 11:38 AM
Pennsylvania
cantspel Offline
cantspel  Offline
Pennsylvania
The 64 has a rear pump, so you can't just swap the mainshaft, and tailhousing. For ease of installation a 65 trans is the way to go. That 64 would require some minor surgery involving 65 parts to make it happen. Is a 66 column a viable option?
Re: 727 Push Button Question [Re: cantspel] #562353
12/26/09 12:17 PM
12/26/09 12:17 PM
North Carolina, USA
Husker1 Offline OP
Husker1  Offline OP
North Carolina, USA
i can get a column out of '66 and up car. what would be a bolt in? i have a decent junkyard to go to if i know what i need.
in an earlier post someone said the conversion sold by imperial services was not any good, does anybody else have any experience with this kit?
i would like to keep my current trans since i just had it rebuilt, so if possible one of the above options would be prefered.
Re: 727 Push Button Question [Re: Husker1] #562354
12/26/09 12:37 PM
12/26/09 12:37 PM
Winlock, Wa
fshd4it Offline
fshd4it  Offline
Winlock, Wa
I bought one of imperial's kits for my '65 bel II with a later trans. The cable seems to be a bit long and not very flexible; not sure about routing issues yet as I haven't been able to find headers that will work in my car with the small block. It also took over 5 months ( and multiple phone calls) to get it from them after I ordered/purchased it
In order to know what you want, you'll probably have to find out what you don't want.
Re: 727 Push Button Question [Re: fshd4it] #562355
12/26/09 01:48 PM
12/26/09 01:48 PM
Minn
SportF Offline
SportF  Offline
Minn
I have been reading this post with interest. Not all 65's have the slip joint. All62-65 trans and the internals are interchangeable. I know someone will say the consul shifted models had a different rooster comb inside...but that has not been my experience the two times I have dealt with this. In addition, when you would order a manual valve body (when you could), they never asked whether consul or button, or column shifted, eh?
And, you can't mate the old with the new trans without alot of trouble, alot of trouble.
Re: 727 Push Button Question [Re: sam64] #562356
12/26/09 11:31 PM
12/26/09 11:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Well, yes and no. The '64 console shift uses the same VB as a '65 but the '64 PB uses a different VB. The difference is in the roostercomb and the cable adapter, the cable adapter must batch the width of the retaining groove at the end of the cable.
All pre-'66 tailshafts and tailhousings can be swapped as a pair. See pic below.
ALL '65 727's have the slip yoke.
Re: 727 Push Button Question [Re: John_Kunkel] #562357
12/27/09 12:32 AM
12/27/09 12:32 AM
Johm Kunkel do I have this correct: 64 pb vb is a diff vb than 64 console vb but 64 console vb is the same as 65 (console or column) vb ??. My 65 dart convertible had a b/t ujoint
Re: 727 Push Button Question [Re: RapidRobert] #562358
12/27/09 01:13 AM
12/27/09 01:13 AM
North Carolina, USA
Husker1 Offline OP
Husker1  Offline OP
North Carolina, USA
does anybody have any ideas on a bolt in column from a '66 and up car?
Re: 727 Push Button Question [Re: RapidRobert] #562359
12/27/09 01:34 AM
12/27/09 01:34 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes. The PB has only 5 gear positions with a separate Park lever, the console/column VB has the 6th position for Park.
Your Dart has a 904 trans, all pre-'66 904's had the B&T. My comment was about the 727.
