Re: 727 Push Button Question
[Re: Husker1]
#562341
12/25/09 06:13 PM
12/25/09 06:13 PM
Posts: 5,108 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
If you are talking about the Shifter for a Push button transmission there is an aftermarket shifter for the push button Transmission. I do not remember who makes this but I see it in many a car at the drag strip. This shifter I believe is to relocate the location to the middle of the car,much like all other Chrysler cars.
1971 HEMI E BODY REGISTRY
[Re: Husker1]
#562345
12/25/09 07:17 PM
12/25/09 07:17 PM
i have two questions concerning my '65 b-body:
will a '64 727 pushbutton trans work in a '65? I know the '65 uses a different column than '66 and later.
does anybody make a adapter to connect a '65 column to a '66 and up 727?
thanks
64 tranny in stock form has a ball and trunion tailshaft, most guys switch to a 65 slip tail shaft which is a one year only. as far as bellhousings, 62-65 all will work, all use cable shift.
from what i have heard that conversion from imperial services suck,too many problems related to the conversion,id pass on that and get the 65 tailshaft housing and keep it stock.
[Re: sam64]
#562349
12/26/09 12:49 AM
12/26/09 12:49 AM
Posts: 30,430 Florida STAYcation
BeEtLeJuIcE !
The village idiot's idiot
Florida STAYcation
Something to think-about and maybe digest .... THINK about putting the complete push-button set-up IN the 65 B body. I know of several people who have done-this ...and it does have a WOWfactor ..
[Re: RapidRobert]
#562351
12/26/09 01:31 AM
12/26/09 01:31 AM
Posts: 2,590 Piqua, Ohio
dodgeram440
Piqua, Ohio
I don't see why the 64 and 65 would be any different as far as the shift mechanism goes. They both have push button cable operated shifters. Although the original poster did mention his 65 is actually column shifted, I believe it still uses the cables. I know the 65 uses two cables: one to shift the gears, and one to control the park. The 64's should be the same. To the best of my limited knowledge, the ONLY difference between a 64 and 65 transmissions are the 64 has the ball and trunion tail and the 65 has a slip yoke. If the OP has both a 64 and a newer trans, he would just have to get the 64 rebuilt using the newer model tail shaft and housing. I only see two possible problems with this. I'm not sure if the park cable runs to the back of the actual case, or to the tail housing (it's been a long time since I've seen the set up). The second problem is the tranny mount. (On second thought, that is not actually a problem since that tranny is currently in the car. Never mind.)
[Re: dodgeram440]
#562352
12/26/09 11:38 AM
12/26/09 11:38 AM
Posts: 182 Pennsylvania
cantspel
Pennsylvania
The 64 has a rear pump, so you can't just swap the mainshaft, and tailhousing. For ease of installation a 65 trans is the way to go. That 64 would require some minor surgery involving 65 parts to make it happen. Is a 66 column a viable option?
[Re: sam64]
#562356
12/26/09 11:31 PM
12/26/09 11:31 PM
Posts: 25,808 Rio Linda, CA
John_Kunkel
Rio Linda, CA
64 65 use same valve body,
Well, yes and no. The '64 console shift uses the same VB as a '65 but the '64 PB uses a different VB. The difference is in the roostercomb and the cable adapter, the cable adapter must batch the width of the retaining groove at the end of the cable.
All pre-'66 tailshafts and tailhousings can be swapped as a pair. See pic below.
ALL '65 727's have the slip yoke.
[Re: John_Kunkel]
#562357
12/27/09 12:32 AM
12/27/09 12:32 AM
RapidRobert
Johm Kunkel do I have this correct: 64 pb vb is a diff vb than 64 console vb but 64 console vb is the same as 65 (console or column) vb ??. My 65 dart convertible had a b/t ujoint
