Re: TIG Welding Aluminum
[Re: S/ST 3040]
#545570
12/04/09 10:55 PM
12/04/09 10:55 PM
Posts: 383 Essex, Ont., Canada
Fishmarket
Essex, Ont., Canada
A stainless steel wire brush is fine as long as it is clean...maybe some alcohol to remove oils. A little trick is to put a piece of copper behind the hole when welding. The filler won't stick to it.
1972 Plymouth Cuda 340 4 speed
1971 Plymouth Road Runner 383 Auto
1970 Plymouth Duster /6 Auto
[Re: Fishmarket]
#545573
12/04/09 10:59 PM
12/04/09 10:59 PM
Posts: 52,972 Romeo MI
MR_P_BODY
... has to be a stainless brush.... dont sand blast it
[Re: S/ST 3040]
#545574
12/04/09 11:01 PM
12/04/09 11:01 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Slightly diluted "simple Green" ( it's slightly caustic) seems to draw out oils, soak for a few minutes, your biggest problem, followed by acetone or MEK, then alum only SS brush.
[Re: SuperStocker]
#545575
12/04/09 11:13 PM
12/04/09 11:13 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
Raised ports eh?
It was like that when I got it. Just a hack job. My sister could have done a better job. They had just patched over it with some flakey epoxy. There are several things that need fixed on this un-cut intake.
Thanks for all the responses. Looks like cleaning it will be cheap enough.
[Re: S/ST 3040]
#545576
12/04/09 11:18 PM
12/04/09 11:18 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
put a penny behind it when you weld,, it wont drip through or push out..a bigger hole. and wont stick to the copper cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: S/ST 3040]
#545577
12/04/09 11:19 PM
12/04/09 11:19 PM
don't ever glass bead aluminum if you plan to tig weld it. the glass can impregnate the aluminum and cause issues of porosity in the weld. MEK and then heat (after it evaporates) works well.
[Re: S/ST 3040]
#545579
12/04/09 11:25 PM
12/04/09 11:25 PM
MR_P_BODY
OK, somebody is going to have to tell me what MEK is.
Methyl ethyl chloride(dont know on the spelling)
[Re: MR_P_BODY]
#545582
12/04/09 11:31 PM
12/04/09 11:31 PM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
I have used a few things, but a new or clean stainless wire brush is the ticket. I also purchased some aluminum cleaner from the local welding shop expensive but it works great. It eats off the oxidation. But Easy off in the yellow can works just as good, and it is much cheaper. Make sure you buy the one that doesn't need you to preheat the oven. Oh and the stainless wire brush is a must. Aluminum will start oxidizing within a couple of hours. I always clean it off really well, then clean it again just before I do the welding.
-Dave
-Dave
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
[Re: Cab_Burge]
#545583
12/04/09 11:33 PM
12/04/09 11:33 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
acetone and a brand new stainless wire brush. make sure you wear rubber gloves while applying the acetone. Some of that stuff will KILL you.
[Re: Cab_Burge]
#545586
12/05/09 12:03 AM
12/05/09 12:03 AM
MR_P_BODY
Methel Ethel Keytone, you may have ahard time finding it now. Try a good paint or harware store that sells commercial paint products
Thats the stuff.... couldnt remember the last word
[Re: don miller]
#545587
12/05/09 12:06 AM
12/05/09 12:06 AM
Posts: 8,882 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
what ever you do, DO NOT use brakleen anywhere within about ten miles of where you are going to weld that.
Thanks, but you're a week late with that advice. Anyhow, tell me why. I'm guessing I was fortunate that nothing happened as a result.
[Re: Stanton]
#545589
12/05/09 12:09 AM
12/05/09 12:09 AM
oh, nothing too serious, only that the fumes could KILL you.
[Re: Stanton]
#545590
12/05/09 12:14 AM
12/05/09 12:14 AM
GTSDave
It's not so much about getting the oil out folks. Aluminum oxidizes and forms a thin layer of aluminum oxide. It melts at 2 to 3 times the temperature of aluminum.
Even if it looks shiny and brand new, it still has a layer on it. Cleaning it off is done with chemicals and the stainless wire brush. If you dont clean it off, once you have the heat high enough to melt it, the aluminum underneath will just run out like water.
Think of it like breaking the crust on a pie, once you get through the top layer everything underneath will be goo.
If you get that thin little layer off aluminum oxide off first, then you only need enough heat to form your puddle in the aluminum. And wont have the danger of melting away the good stuff.
If that makes any sense.
-Dave
[Re: GTSDave]
#545591
12/05/09 12:34 AM
12/05/09 12:34 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
IMO Just use a stainless wire brush and some heat... No matter what type of chemicals you put on it, when you hit it with some heat those impurities will boil to the top...Just apply a little heat and wire brush it. Also you can fill the intake runner with some air arch gouging rods and weld away...They will back up the puddle and the weld wont stick to it at all. Check this stuff out http://www.aluminumrepair.com/video_new.asp
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
#545593
12/05/09 02:17 AM
12/05/09 02:17 AM
Posts: 871 WA 98043
thecarfarmer
WA 98043
Depending on the formulation of brake cleaner you use, it can make phosgene gas when hit w/ a flame.
And it only takes the tiniest whiff of that to mess you up (seizure, nerve/brain damage, pancreas damage, erc) or kill you. Really, really bad stuff.
Maybe one of the few things that makes hydrazine look safe.
-Bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
#545597
12/06/09 12:24 AM
12/06/09 12:24 AM
cheapstreetdustr
or worse..youll be a walking Zombie...with no lung capacity..
[Re: MR_P_BODY]
#545598
12/06/09 01:05 AM
12/06/09 01:05 AM
Posts: 12,013 Finally a HUSKER again
Moparnut426
I agree dont blast it, it can imbed any impurities deeper in the aluminum. One thing that works great to clean it is John Deere 80% either, let it sit to completely dry out, Either will completely evaporate without leaving any residues. I have done this for many years on aluminum, cast iron, copper, and stainless. Use the brass behind it and it will fill up easier.
Kasey
