Re: TIG Welding Aluminum
[Re: S/ST 3040]
#545570
12/04/09 10:55 PM
12/04/09 10:55 PM
Posts: 383 Essex, Ont., Canada
Fishmarket
Essex, Ont., Canada
A stainless steel wire brush is fine as long as it is clean...maybe some alcohol to remove oils. A little trick is to put a piece of copper behind the hole when welding. The filler won't stick to it.
1972 Plymouth Cuda 340 4 speed
1971 Plymouth Road Runner 383 Auto
1970 Plymouth Duster /6 Auto
[Re: Fishmarket]
#545573
12/04/09 10:59 PM
12/04/09 10:59 PM
Posts: 52,972 Romeo MI
MR_P_BODY
... has to be a stainless brush.... dont sand blast it
[Re: S/ST 3040]
#545574
12/04/09 11:01 PM
12/04/09 11:01 PM
Posts: 22,697 Bitopia
jcc
Bitopia
Slightly diluted "simple Green" ( it's slightly caustic) seems to draw out oils, soak for a few minutes, your biggest problem, followed by acetone or MEK, then alum only SS brush.
[Re: SuperStocker]
#545575
12/04/09 11:13 PM
12/04/09 11:13 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
Raised ports eh?
It was like that when I got it. Just a hack job. My sister could have done a better job. They had just patched over it with some flakey epoxy. There are several things that need fixed on this un-cut intake.
Thanks for all the responses. Looks like cleaning it will be cheap enough.
[Re: S/ST 3040]
#545576
12/04/09 11:18 PM
12/04/09 11:18 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
put a penny behind it when you weld,, it wont drip through or push out..a bigger hole. and wont stick to the copper cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: S/ST 3040]
#545577
12/04/09 11:19 PM
12/04/09 11:19 PM
don't ever glass bead aluminum if you plan to tig weld it. the glass can impregnate the aluminum and cause issues of porosity in the weld. MEK and then heat (after it evaporates) works well.
[Re: S/ST 3040]
#545579
12/04/09 11:25 PM
12/04/09 11:25 PM
MR_P_BODY
OK, somebody is going to have to tell me what MEK is.
Methyl ethyl chloride(dont know on the spelling)
[Re: MR_P_BODY]
#545582
12/04/09 11:31 PM
12/04/09 11:31 PM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
I have used a few things, but a new or clean stainless wire brush is the ticket. I also purchased some aluminum cleaner from the local welding shop expensive but it works great. It eats off the oxidation. But Easy off in the yellow can works just as good, and it is much cheaper. Make sure you buy the one that doesn't need you to preheat the oven. Oh and the stainless wire brush is a must. Aluminum will start oxidizing within a couple of hours. I always clean it off really well, then clean it again just before I do the welding.
-Dave
-Dave
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
[Re: Cab_Burge]
#545583
12/04/09 11:33 PM
12/04/09 11:33 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
acetone and a brand new stainless wire brush. make sure you wear rubber gloves while applying the acetone. Some of that stuff will KILL you.
[Re: Cab_Burge]
#545586
12/05/09 12:03 AM
12/05/09 12:03 AM
MR_P_BODY
Methel Ethel Keytone, you may have ahard time finding it now. Try a good paint or harware store that sells commercial paint products
Thats the stuff.... couldnt remember the last word
[Re: don miller]
#545587
12/05/09 12:06 AM
12/05/09 12:06 AM
Posts: 8,902 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
what ever you do, DO NOT use brakleen anywhere within about ten miles of where you are going to weld that.
Thanks, but you're a week late with that advice. Anyhow, tell me why. I'm guessing I was fortunate that nothing happened as a result.
