TIG Welding Aluminum #545569
12/04/09 10:51 PM
12/04/09 10:51 PM
On the south side of Nowhere
S/ST 3040 Offline OP
Knowing it has to be clean to weld properly, what works best
to clean a used intake manifold for welding?
Somebody ground through the roof of this port while "port matching" it.
It's too thin to glass bead and I don't want to use epoxy.
Re: TIG Welding Aluminum [Re: S/ST 3040] #545570
12/04/09 10:55 PM
12/04/09 10:55 PM
Essex, Ont., Canada
Fishmarket Offline
Fishmarket  Offline
Essex, Ont., Canada
A stainless steel wire brush is fine as long as it is clean...maybe some alcohol to remove oils. A little trick is to put a piece of copper behind the hole when welding. The filler won't stick to it.
1972 Plymouth Cuda 340 4 speed 1971 Plymouth Road Runner 383 Auto 1970 Plymouth Duster /6 Auto
Re: TIG Welding Aluminum [Re: S/ST 3040] #545571
12/04/09 10:57 PM
12/04/09 10:57 PM
Btween a rock and a hard place
moparlulu Offline
moparlulu  Offline
I will run my tig across it and pull the crap to the top. Then I use a stainless wire wheel and go over it with that. I'll use the tig again and see if its still pulling junk. If not then I'll just fill the hole or crack.
Re: TIG Welding Aluminum [Re: S/ST 3040] #545572
12/04/09 10:59 PM
12/04/09 10:59 PM
Vacherie, Louisiana
SuperStocker Offline
super gas
super gas
Vacherie, Louisiana
Vic, bead-blast it lightly first both inside and out. An aluminum mig will do just fine too.
Raised ports eh?
Re: TIG Welding Aluminum [Re: Fishmarket] #545573
12/04/09 10:59 PM
12/04/09 10:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
... has to be a stainless brush.... dont
sand blast it
Re: TIG Welding Aluminum [Re: S/ST 3040] #545574
12/04/09 11:01 PM
12/04/09 11:01 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Slightly diluted "simple Green" ( it's slightly caustic) seems to draw out oils, soak for a few minutes, your biggest problem, followed by acetone or MEK, then alum only SS brush.
Re: TIG Welding Aluminum [Re: SuperStocker] #545575
12/04/09 11:13 PM
12/04/09 11:13 PM
Raised ports eh?
It was like that when I got it. Just a hack job. My sister
could have done a better job. They had just patched over
it with some flakey epoxy. There are several things that
need fixed on this un-cut intake.
Thanks for all the responses. Looks like cleaning it will be
cheap enough.
Re: TIG Welding Aluminum [Re: S/ST 3040] #545576
12/04/09 11:18 PM
12/04/09 11:18 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
put a penny behind it when you weld,,
it wont drip through or push out..a bigger hole.
and wont stick to the copper
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: TIG Welding Aluminum [Re: S/ST 3040] #545577
12/04/09 11:19 PM
12/04/09 11:19 PM
don't ever glass bead aluminum if you plan to tig weld it. the glass can impregnate the aluminum and cause issues of porosity in the weld. MEK and then heat (after it evaporates) works well.
Re: TIG Welding Aluminum #545578
12/04/09 11:23 PM
12/04/09 11:23 PM
OK, somebody is going to have to tell me what MEK is.
Re: TIG Welding Aluminum [Re: S/ST 3040] #545579
12/04/09 11:25 PM
12/04/09 11:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Methyl ethyl chloride(dont know on the spelling)
Re: TIG Welding Aluminum [Re: S/ST 3040] #545580
12/04/09 11:28 PM
12/04/09 11:28 PM
Methel Ethel Keytone, you may have ahard time finding it now. Try a good paint or harware store that sells commercial paint products
Re: TIG Welding Aluminum [Re: S/ST 3040] #545581
12/04/09 11:29 PM
12/04/09 11:29 PM
St.Clair Shores MI.
tilt Offline
tilt  Offline
St.Clair Shores MI.
Methyl ehthel ketone.(MEK)Home Depot
I agree with Dram (clean and then heated)and the other posters about the copper.I've just used a piece of copper plumbing tube.
68 CORONET R/T BEST MACHINE BUILT EFI'd TWIN TURBO(UP and RUNNING !!) 03 Mach1
Re: TIG Welding Aluminum [Re: MR_P_BODY] #545582
12/04/09 11:31 PM
12/04/09 11:31 PM
Richmond, Tx. (Houston)
GTSDave Offline
GTSDave  Offline
I have used a few things, but a new or clean stainless wire brush is the ticket. I also purchased some aluminum cleaner from the local welding shop expensive but it works great. It eats off the oxidation. But Easy off in the yellow can works just as good, and it is much cheaper. Make sure you buy the one that doesn't need you to preheat the oven. Oh and the stainless wire brush is a must. Aluminum will start oxidizing within a couple of hours. I always clean it off really well, then clean it again just before I do the welding.
-Dave
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: TIG Welding Aluminum [Re: Cab_Burge] #545583
12/04/09 11:33 PM
12/04/09 11:33 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
acetone and a brand new stainless wire brush. make sure you wear rubber gloves while applying the acetone. Some of that stuff will KILL you.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: TIG Welding Aluminum [Re: Cab_Burge] #545584
12/04/09 11:34 PM
12/04/09 11:34 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
after your normal degreasing I have always found that soaking in the laundry tube with powdered tide and super hot water will bring all the oils out of the pores. let it soak for an hour and you will see the oil slick on the surface of the water. Rinse after and then do another soak in just plain hot water. Rinse, heat, SS wire brush, then weld.
Re: TIG Welding Aluminum [Re: S/ST 3040] #545585
12/05/09 12:01 AM
12/05/09 12:01 AM
langley b.c. canada
don miller Offline
don miller  Offline
langley b.c. canada
what ever you do, DO NOT use brakleen anywhere within about ten miles of where you are going to weld that.
Re: TIG Welding Aluminum [Re: Cab_Burge] #545586
12/05/09 12:03 AM
12/05/09 12:03 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats the stuff.... couldnt remember the last word
Re: TIG Welding Aluminum [Re: don miller] #545587
12/05/09 12:06 AM
12/05/09 12:06 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Thanks, but you're a week late with that advice. Anyhow, tell me why. I'm guessing I was fortunate that nothing happened as a result.
Re: TIG Welding Aluminum [Re: tilt] #545588
12/05/09 12:09 AM
12/05/09 12:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I make up what we call a welders helper... a piece
of brass brazed to a rod with a file handle on the
end... the brass part is sorta pie shaped but I have
a few different shaped ones
