Re: TIG Welding Aluminum [Re: Stanton] #545589
12/05/09 12:09 AM
12/05/09 12:09 AM
what ever you do, DO NOT use brakleen anywhere within about ten miles of where you are going to weld that.
Thanks, but you're a week late with that advice. Anyhow, tell me why. I'm guessing I was fortunate that nothing happened as a result.
oh, nothing too serious, only that the fumes could KILL you.
Re: TIG Welding Aluminum [Re: Stanton] #545590
12/05/09 12:14 AM
12/05/09 12:14 AM
Richmond, Tx. (Houston)
GTSDave Offline
GTSDave  Offline
It's not so much about getting the oil out folks. Aluminum oxidizes and forms a thin layer of aluminum oxide. It melts at 2 to 3 times the temperature of aluminum.
Even if it looks shiny and brand new, it still has a layer on it. Cleaning it off is done with chemicals and the stainless wire brush. If you dont clean it off, once you have the heat high enough to melt it, the aluminum underneath will just run out like water.
Think of it like breaking the crust on a pie, once you get through the top layer everything underneath will be goo.
If you get that thin little layer off aluminum oxide off first, then you only need enough heat to form your puddle in the aluminum. And wont have the danger of melting away the good stuff.
If that makes any sense.
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: TIG Welding Aluminum [Re: GTSDave] #545591
12/05/09 12:34 AM
12/05/09 12:34 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
IMO
Just use a stainless wire brush and some heat...
No matter what type of chemicals you put on it, when you hit it with some heat those impurities will boil to the top...Just apply a little heat and wire brush it.
Also you can fill the intake runner with some air arch gouging rods and weld away...They will back up the puddle and the weld wont
stick to it at all.
Check this stuff out
http://www.aluminumrepair.com/video_new.asp
Re: TIG Welding Aluminum [Re: GTSDave] #545592
12/05/09 12:35 AM
12/05/09 12:35 AM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
Basically what everyone else has said, i have a few different aerosols that i use daily but the best for aluminum seems to be "NO FLASH" its made by LPS and works awesome. On thicker aluminum i use a heat plate to preheat everything (this also aids in getting oils out of the casting) spray and wire brush off and then weld. you will tell as soon as you strike an arc if its clean or not
Re: TIG Welding Aluminum #545593
12/05/09 02:17 AM
12/05/09 02:17 AM
WA 98043
thecarfarmer Offline
WA 98043
Depending on the formulation of brake cleaner you use, it can make phosgene gas when hit w/ a flame.
And it only takes the tiniest whiff of that to mess you up (seizure, nerve/brain damage, pancreas damage, erc) or kill you. Really, really bad stuff.
Maybe one of the few things that makes hydrazine look safe.
-Bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: TIG Welding Aluminum [Re: thecarfarmer] #545594
12/05/09 11:43 AM
12/05/09 11:43 AM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Here's a link to a story about brake clean.
http://www.brewracingframes.com/id75.htm
Re: TIG Welding Aluminum [Re: PC-CHARGER] #545595
12/05/09 04:38 PM
12/05/09 04:38 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Also- watch out pennies aren't copper anymore. They're copper plated pot metal or something. I often use coins to dress up the hardware when I make tattoo machines. I braze them onto the ends of screws to make handles so you don't need to get a wrench to tighten the tube vise etc.
Anyway, the new ones have a 'creamy center' and if you heat one up with an ox/a torch it will pop sending molten pot metal all over. To make a short story long, don't use new pennies as copper!
Re: TIG Welding Aluminum [Re: radar] #545596
12/05/09 05:52 PM
12/05/09 05:52 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
As Mr Coomer says heat it,clean it with a ss brush and preheat before welding.On a repair like that I would drill it out cut a aluminum dowel or slug,tap it in the hole and weld it.If you can weld it on the inside also,then grind it smooth with a diegrinder and tootsie roll it.
Re: TIG Welding Aluminum #545597
12/06/09 12:24 AM
12/06/09 12:24 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
or worse..youll be a walking Zombie...with no lung capacity..
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: TIG Welding Aluminum [Re: MR_P_BODY] #545598
12/06/09 01:05 AM
12/06/09 01:05 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
A stainless steel wire brush is fine as long as it is clean...maybe some alcohol to remove oils. A little trick is to put a piece of copper behind the hole when welding. The filler won't stick to it.
... has to be a stainless brush.... dont
sand blast it
I agree dont blast it, it can imbed any impurities deeper in the aluminum. One thing that works great to clean it is John Deere 80% either, let it sit to completely dry out, Either will completely evaporate without leaving any residues. I have done this for many years on aluminum, cast iron, copper, and stainless. Use the brass behind it and it will fill up easier.
Kasey
Re: TIG Welding Aluminum [Re: radar] #545599
12/07/09 04:31 AM
12/07/09 04:31 AM
IL
E
EchoSixMike Online content
EchoSixMike  Online Content
E
IL
Pennies have been zinc core for several decades. S/F...Ken M
