Re: Tricks Supporting Trans Changing Motor?
[Re: 3ddart]
#533185
11/22/09 08:29 AM
11/22/09 08:29 AM
Posts: 75,094 A Banana Republic near you.
JohnRR
a piece of 1/4"flat steel bar on edge with some holes in it to bolt to the front of the tranny case and made to lay on the frame rails will let you do want your wanting. dave
did basicly the same thing with a piece of 1/2 pipe , no drilling required , just put 2 long bolts into the lower holes that get the bolts that come in from the block side ...
[Re: 72challorange]
#533188
11/22/09 10:41 AM
11/22/09 10:41 AM
Posts: 15,487 Florida
scratchnfotraction
a tie strap run from frame rail to frame rail under the bell works a couple coat hangers wraped in the bolt holes and tied to the fire wall what they said all work also good luck ![](/ubbthreads/images/graemlins/thumbs.gif)
