Tricks Supporting Trans Changing Motor? #533183
11/22/09 07:35 AM
11/22/09 07:35 AM
SW Fla.
CYACOP Offline OP
CYACOP  Offline OP
SW Fla.
I am doing an engine swap and painting engine bay on my 71 Road Runner and was wondering if there were any tricks in holding up the transmission from the top? I will want to move the car around during this time and don't want to support the auto trans from the bottom. I also need clearance to paint under the hood.
Thanks in advance
Re: Tricks Supporting Trans Changing Motor? [Re: CYACOP] #533184
11/22/09 08:27 AM
11/22/09 08:27 AM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
a piece of 1/4"flat steel bar on edge with some holes in it to bolt to the front of the tranny case and made to lay on the frame rails will let you do want your wanting. dave
Re: Tricks Supporting Trans Changing Motor? [Re: 3ddart] #533185
11/22/09 08:29 AM
11/22/09 08:29 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
did basicly the same thing with a piece of 1/2 pipe , no drilling required , just put 2 long bolts into the lower holes that get the bolts that come in from the block side ...
Re: Tricks Supporting Trans Changing Motor? [Re: CYACOP] #533186
11/22/09 08:58 AM
11/22/09 08:58 AM
SW Fla.
CYACOP Offline OP
CYACOP  Offline OP
SW Fla.
That's the missing concept I was looking for.
Thanks a lot.
Re: Tricks Supporting Trans Changing Motor? [Re: CYACOP] #533187
11/22/09 10:33 AM
11/22/09 10:33 AM
NH
72challorange Offline
He's Game
He's Game
NH
Some 3/4x3/4 angle aluminum worked well for me.
Tom
Re: Tricks Supporting Trans Changing Motor? [Re: 72challorange] #533188
11/22/09 10:41 AM
11/22/09 10:41 AM
scratchnfotraction Offline
a tie strap run from frame rail to frame rail under the bell works
a couple coat hangers wraped in the bolt holes and tied to the fire wall
what they said all work also
good luck
Re: Tricks Supporting Trans Changing Motor? [Re: scratchnfotraction] #533189
11/22/09 10:47 AM
11/22/09 10:47 AM
SW Fla.
CYACOP Offline OP
CYACOP  Offline OP
SW Fla.
Thanks for the responses.
Im off to do my swap.
Re: Tricks Supporting Trans Changing Motor? [Re: CYACOP] #533190
11/22/09 02:40 PM
11/22/09 02:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A half-inch pipe and two bolts works for me.
