Re: Shifting Point
[Re: 72 RR DUDE]
#475739
09/21/09 11:05 PM
09/21/09 11:05 PM
RapidRobert
It doesn't shift crisp, the rpm flares when it goes to shift?
Re: Shifting Point
[Re: 72 RR DUDE]
#475740
09/22/09 12:42 AM
09/22/09 12:42 AM
Posts: 2,001 s. e. pa.
calrobb2000
s. e. pa.
hi 1. check your fluid level in N on the level 2. does itdo this in both shifts ? 1-2, 2-3 ? 3. 1-2 may be a band adj ? 2-3 low fluid level , preasure loss from bad seal , burnt clutch pack ? what fluid , and is it fresh , also a cloged filter ? 4. valve body kit incorectly installed , kickdown linkage improperly adjusted . let us know .
Re: Shifting Point
[Re: 72 RR DUDE]
#475741
09/22/09 03:56 PM
09/22/09 03:56 PM
Posts: 25,852 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The lack of a neck-jerking shift can be attributed to lots of things like converter, axle ratio, vehicle weight, etc.
The high rpm shifting might be the throttle pressure linkage adjustment, try backing it off a little to seee if it will shift at the desired rpm.
Re: Shifting Point
[Re: 72 RR DUDE]
#475743
09/22/09 06:25 PM
09/22/09 06:25 PM
John_Kunkel
Rio Linda, CA
If it has 3-piece linkage just shorten the top rod by threading the slotted end into the rod, this will make it shift sooner.
Re: Shifting Point
[Re: John_Kunkel]
#475744
09/22/09 07:14 PM
09/22/09 07:14 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
He's not worried about the shift RPM, he's worried about how it takes so long to shift, and is such a soft shift, I don't think the "kick-down linkage" is the issue, I think it's something internal to the trans...as said--bands, clutches, fluid, etc.
**Photobucket sucks**
Re: Shifting Point
[Re: 72 RR DUDE]
#475746
09/22/09 11:07 PM
09/22/09 11:07 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
Maybe I didn't explain it right. When I take it through the gears shifting it by hand is when I don't get the hard shift and when I shift it at 4500 rpm's it goes into the next gear at about 6000rpm's. I'm used to moving the lever and it shift's to the next gear right away.
Then it sounds like throttle pressure..
