Shifting Point #475738
09/21/09 08:00 PM
09/21/09 08:00 PM
Hamburg, Pa.
72 RR DUDE Offline OP
Hamburg, Pa.
I have a strong 440 - 6 pack with a hemi stall converter and the trans is rebuilt and has a shift kit in it. My question is that it doesn't have a hard neck jerking shift and if I want it to shift at say 6000 rpm's I have to move the shifter at about 4500 rpm's or it goes higher in the rpm's. What is the problem? I don't understand the high rpm difference.
Re: Shifting Point [Re: 72 RR DUDE] #475739
09/21/09 11:05 PM
09/21/09 11:05 PM
It doesn't shift crisp, the rpm flares when it goes to shift?
Re: Shifting Point [Re: 72 RR DUDE] #475740
09/22/09 12:42 AM
09/22/09 12:42 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
1. check your fluid level in N on the level
2. does itdo this in both shifts ? 1-2, 2-3 ?
3. 1-2 may be a band adj ?
2-3 low fluid level , preasure loss from bad seal , burnt clutch pack ?
what fluid , and is it fresh , also a cloged filter ?
4. valve body kit incorectly installed , kickdown linkage improperly adjusted .
let us know .
Re: Shifting Point [Re: 72 RR DUDE] #475741
09/22/09 03:56 PM
09/22/09 03:56 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The lack of a neck-jerking shift can be attributed to lots of things like converter, axle ratio, vehicle weight, etc.
The high rpm shifting might be the throttle pressure linkage adjustment, try backing it off a little to seee if it will shift at the desired rpm.
Re: Shifting Point [Re: John_Kunkel] #475742
09/22/09 05:22 PM
09/22/09 05:22 PM
Hamburg, Pa.
Hamburg, Pa.
What is the best way to adjust the linkage I've heard different ways of doing it. It has a Hemi street converter with 410 rear gears in a 3800 lb 72 RR
Re: Shifting Point [Re: 72 RR DUDE] #475743
09/22/09 06:25 PM
09/22/09 06:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If it has 3-piece linkage just shorten the top rod by threading the slotted end into the rod, this will make it shift sooner.
Re: Shifting Point [Re: John_Kunkel] #475744
09/22/09 07:14 PM
09/22/09 07:14 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
He's not worried about the shift RPM, he's worried about how it takes so long to shift, and is such a soft shift, I don't think the "kick-down linkage" is the issue, I think it's something internal to the trans...as said--bands, clutches, fluid, etc.
**Photobucket sucks**
Re: Shifting Point [Re: 70Cuda383] #475745
09/22/09 08:41 PM
09/22/09 08:41 PM
Hamburg, Pa.
Hamburg, Pa.
Maybe I didn't explain it right. When I take it through the gears shifting it by hand is when I don't get the hard shift and when I shift it at 4500 rpm's it goes into the next gear at about 6000rpm's. I'm used to moving the lever and it shift's to the next gear right away.
Re: Shifting Point [Re: 72 RR DUDE] #475746
09/22/09 11:07 PM
09/22/09 11:07 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Then it sounds like throttle pressure..
