Re: Who here run caltracs?
[Re: hemi_doug]
#464058
09/10/09 08:48 PM
09/10/09 08:48 PM
I have some questions.....how does the suspension react to adding/removing preload on the springs? I have tried both upper and lower holes so far and can feel the difference in tire hit, but there must be more tuning in the preload other then getting the car to go straight right?
doug, i called you but went to voicemail, i can get your car to leave like this.
[Re: hemi_doug]
#464060
09/10/09 09:19 PM
09/10/09 09:19 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Been great,missed ya at MUSCLEPALOOOOSER!
Yeah, I missed you guys as well....but it was a good reason...I got to play on Tuesday at a track rental...I can't go into detals but it will all come out sometime in the future....
Chris...You going to Island any time soon? The track stuff is still on the car.... ...I REALLY want that 11 second time slip.....
I thought that might have been YOU!! You were a very busy boy fer sure.My friend Tim belongs to the the 68 dart that now has air conditioning Let us know when ,,,,,YOU KNOW
[Re: hemi_doug]
#464061
09/10/09 09:23 PM
09/10/09 09:23 PM
not this weekend, lebanon valley saturday but in 2 weeks island, ill get your car 60 footing, you need to listen to SSR. call me buddy.
[Re: hemi-itis]
#464062
09/10/09 09:28 PM
09/10/09 09:28 PM
Posts: 3,443 Northern N.J.
hemi_doug
Northern N.J.
Yep...he "craped" the bed right in front of me...I was just about to do my burnout...And yes, I was a very busy boy...still a little wore out. I just wish I had more time to tune....it wasn't all there out of the box. to bad, 'cause I think there is another .5 sec in the suspension...
71 440-6 4spd & 69 Hemi 4spd
#464063
09/10/09 09:29 PM
09/10/09 09:29 PM
hemi-itis
SUPERSTOCKRACER can get it up for ya
[Re: hemi-itis]
#464064
09/10/09 09:34 PM
09/10/09 09:34 PM
perv!
[Re: BradH]
#464066
09/13/09 10:40 AM
09/13/09 10:40 AM
Posts: 3,527 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
I found this an a non-Mopar site:
CAL-TRAC SETTINGS Top hole – Hardest Hit (start here)
Bottom hole – Softer Hit, moves IC forward
More Pre-load, Softer Hit
Less Pre-load, air gap, harder hit
If car pulls to the right add a quarter turn of pre-load to the right bar and visa versa.
Set front shocks soft
Set rear shocks on #5, if car wants to porpoise go to 6 or 7 (harder).
If car spins, needs harder hit
Too much wheel stand…. Softer hit, restrict front travel
I think I posted these on classracer.com as well as here a few times. These were the instructions that John gave me over the phone in early in 2003 when I got mine.
However everybody's car is going to be different in the end.
Bill
[Re: B1KILLER]
#464068
09/13/09 01:33 PM
09/13/09 01:33 PM
hemi_doug
Northern N.J.
I could tell the difference...maybe because of the weight (4k)...the upper hole hits the tire harder and I got more rise out of the front...I think a different tire would make a difference for me...
[Re: Mr71Bee]
#464070
09/14/09 08:31 AM
09/14/09 08:31 AM
BradH
Anyone run the caltracs on the street? How are they?
Stiff, because I just leave 'em set up for the track and drive it that way all the time.
[Re: hemi_doug]
#464071
09/14/09 02:35 PM
09/14/09 02:35 PM
Posts: 226 lino lakes,MN
onebaddakota
lino lakes,MN
Mine is the same way.Everyone seems to like the top hole. My truck likes the to hole-a lot.I run drag springs and the new calvert 90/10s up front. It's critical for me to get a good weight transfer going. I assume this is because of the inherent forward weight bias most trucks have. I can also tell you guys from experience that changing ride height via shackles and hangers directly effects the angle of the bar and thus instant center Tom
10.56 at 125.6, with a 1.43 60 ft.
E85, Hyd. Roller 410 magnum,full exhaust, 3500 race weight.
