Who here run caltracs?
#464037
09/09/09 06:09 PM
09/09/09 06:09 PM
Posts: 3,443 Northern N.J.
hemi_doug
Northern N.J.
I have some questions.....how does the suspension react to adding/removing preload on the springs? I have tried both upper and lower holes so far and can feel the difference in tire hit, but there must be more tuning in the preload other then getting the car to go straight right?
71 440-6 4spd & 69 Hemi 4spd
Re: Who here run caltracs?
[Re: hemi_doug]
#464038
09/09/09 09:56 PM
09/09/09 09:56 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
Well I've only had mine out twice so my experience is not that good. 1st time out with the bar in the lower hole and an 1/8" gap between the spring and the top bolt and the shocks set at 5. Car ran in the 10.6's with a best pass of 10.59. 60's were 1.48 to 1.54 with an average of 1.52. My sig pic is from the 1st outing. 2nd time out I put 2 flats of preload in left side and 4 in the right. 60's were almost identical. The weather was worse so the car slowed about .1. The car left like this. http://www.erikandersondesigns.com/images/2009/06-13-MokanAllOut/0008/imagepages/image13.html Jim
Post deleted by Defbob
[Re: hemi_doug]
#464039
09/09/09 10:05 PM
09/09/09 10:05 PM
[Re: 70blackfish]
#464042
09/10/09 08:43 AM
09/10/09 08:43 AM
Posts: 902 Mopar Lane,Mississippi
67HEMI
I run the calvert monoleafs and set the bars just like the instructions said. It has been a 1.419 60 foot and 1.42's consistently. Ranchos set on 7.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: Kevins493]
#464043
09/10/09 08:54 AM
09/10/09 08:54 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
set bars just touching, if car goes right, add preload to right bar till it goes straight
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#464044
09/10/09 09:10 AM
09/10/09 09:10 AM
Posts: 769 Europa, Estonia
Georg
Europa, Estonia
I had bars on lower hole, left side bar just touching and right was 1/2 turn preload. Rancho shock was at 7 position
Outlaw Plymouth Valiant
R5/P7 Powered by Liuzzo Racing
COMP Performance Group dealer in Baltic
Premium Performance
[Re: BradH]
#464047
09/10/09 12:47 PM
09/10/09 12:47 PM
hemi_doug
Northern N.J.
Thanks for some great info Brad....I guess I just need to continue tuning/testing. I see some settings I need to change based on your info but my question is "when is too much preload too much?"......and how does preload affect the hit on the tire...does more preload hit harder and less softer? Would you make adjustments to the preload for track condition or just play with tire pressures and just leave adjustabilty for "bite" to that alone?
[Re: BradH]
#464049
09/10/09 02:11 PM
09/10/09 02:11 PM
Posts: 1,832 Fort Morgan
1OFNONE
Has been a member for quite a few years, so relax.
Fort Morgan
Dont forget to set them with the driver in the car. Or something of equal weight in the drivers seat. That made a big difference for me.
So the bartender says to the horse " Gee, Why the long face?"
[Re: hemi_doug]
#464052
09/10/09 03:15 PM
09/10/09 03:15 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
I have mine in the bottom hole,,,,
Rear shocks on 7 ( works best for me )
(any higher,,,8,9, etc,,,and the car SPINS)
Front shocks (for me) are QA-1 set on 3 (soft),,,it doesnt like one as much
I set mine so both bars just touch,,,and then add a 1/2 turn of preload on the passenger side,,, ( ps,,i do this without someone being in the car,,driver seat,,etc),,actually this is what i was told by Calvert,,,that it was ok to set it this way without the driver weight...
I think your rear shock setting it too high,,,,i would go for 5-7 and see what it does...
I know everyone runs their front end real loose,,,mine doesnt seem to like it as much,,,
[Re: 69CHARGERMD]
#464053
09/10/09 05:49 PM
09/10/09 05:49 PM
Posts: 4,027 Dearborn Hts, MI
Sledge_57
Dearborn Hts, MI
I have very little experience with them also, however without them my best 60' was ~ 1.80 and with them I made 2 passes, both were 1.64 60' My car is as heavy as yours, runs a bit less mph and has gone 11.67. Mine are set; bottom hole, both just touching, 1 extra flat in the pass side without weight in the seat (I can't find 3 people to sit on each other in my seat ) Rancho's set to 5 or 6 (don't remember), Calvert front shocks and MT 275-60 ET Street Radials. Car went straight on both passes (and nothing broke ) The big question in my mind is the 4k launch, heavy car & small tire, you might need to to leave softer....
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
