Re: How to remove distributor intermediate shaft?
[Re: Blue69Charger]
#439326
08/16/09 12:18 AM
08/16/09 12:18 AM
RapidRobert
fashion 2 "L" shaped pieces of metal to hook it on each side opposite each other, dont know if coat hanger would be stiff enough but it'd be easy to make/try. I'd try a parts house or MP for the pump base gasket or cut/punch your own in a sheet of gasket material.
[Re: moparsquid]
#439329
08/16/09 02:13 AM
08/16/09 02:13 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
I simply used a flat screwdriver to make it turn clockwise, that will unengage from cam gear, and will be closer to be removed by any regular plyer.
[Re: NachoRT74]
#439331
08/16/09 09:19 AM
08/16/09 09:19 AM
Posts: 15,491 the boonies
aarcuda
the boonies
and try truning the engine backwards. it will tend to unscrew the shaft out of the block
