How to remove distributor intermediate shaft? #439325
08/16/09 12:04 AM
08/16/09 12:04 AM
San Jose, CA
Blue69Charger Offline OP
San Jose, CA
I tried installing my intermediate shaft in my hemi today and it fit snug. I think the bushing wasn't burnished properly. The slot is not parallel with the crank. What is the best way to get it out? I tried turning it counter-clockwise with a screwdriver and it didn't work. The oil pump and intake manifold are already installed. If I do have to remove the oil pump to tap the shaft up, where can I find another gasket?
Re: How to remove distributor intermediate shaft? [Re: Blue69Charger] #439326
08/16/09 12:18 AM
08/16/09 12:18 AM
fashion 2 "L" shaped pieces of metal to hook it on each side opposite each other, dont know if coat hanger would be stiff enough but it'd be easy to make/try. I'd try a parts house or MP for the pump base gasket or cut/punch your own in a sheet of gasket material.
Re: How to remove distributor intermediate shaft? [Re: Blue69Charger] #439327
08/16/09 12:46 AM
08/16/09 12:46 AM
MNobody Offline
MNobody  Offline
I used to use snap ring pliers.
Re: How to remove distributor intermediate shaft? [Re: Blue69Charger] #439328
08/16/09 12:59 AM
08/16/09 12:59 AM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
i used a slide hammer and an l shaped bracket on the end.
Re: How to remove distributor intermediate shaft? [Re: moparsquid] #439329
08/16/09 02:13 AM
08/16/09 02:13 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I simply used a flat screwdriver to make it turn clockwise, that will unengage from cam gear, and will be closer to be removed by any regular plyer.
Re: How to remove distributor intermediate shaft? [Re: NachoRT74] #439330
08/16/09 08:55 AM
08/16/09 08:55 AM
N.E Indiana
repad Offline
super street
repad  Offline
super street
N.E Indiana
I take mine out using my wifes cooking tongs. (when she is not looking of course)
Re: How to remove distributor intermediate shaft? [Re: NachoRT74] #439331
08/16/09 09:19 AM
08/16/09 09:19 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
and try truning the engine backwards. it will tend to unscrew the shaft out of the block
Re: How to remove distributor intermediate shaft? [Re: aarcuda] #439332
08/16/09 10:06 AM
08/16/09 10:06 AM
Mass
dgc333 Offline
dgc333  Offline
Mass
Put two large flat blade screw drivers in the slot and squeeze the handles together. Creates a nice tight wedge and allows you to pull it right out.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: How to remove distributor intermediate shaft? [Re: dgc333] #439333
08/16/09 12:45 PM
08/16/09 12:45 PM
San Jose, CA
San Jose, CA
Thanks for the great suggestions. I will try them out.
Re: How to remove distributor intermediate shaft? [Re: aarcuda] #439334
08/16/09 01:38 PM
08/16/09 01:38 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
well I think on clockwise because was thinking on big Block. I guess COUNTERCLOCKWISE on Small Blocks. The fact is spining with a long flat screwdriver in the dist opposite direction will raise the shaft on top of cam ( closer to opening ) and you will be able to pull out the shaft easilly straight, without spin anymore with any long nose plyers
Re: How to remove distributor intermediate shaft? [Re: NachoRT74] #439335
08/16/09 03:05 PM
08/16/09 03:05 PM
San Jose, CA
San Jose, CA
Thanks guys. Turning the engine backwards did the trick. It goes in and out freely with a screwdriver now.
