Re: Does output shaft on 833 4spd spin while in neutral?
[Re: Blakcharger440]
#374483
07/13/09 10:11 PM
07/13/09 10:11 PM
Posts: 1,184 clarks summit pa
73cuda340
clarks summit pa
I was wondering the same thing because on my car if it is jacked up the back wheels will spin when in neutral but if its on the ground they wont.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
[Re: 73cuda340]
#374484
07/13/09 10:25 PM
07/13/09 10:25 PM
Depends on what lube you run, and temp. "It likely will"
[Re: SomeCarGuy]
#374487
07/14/09 09:02 AM
07/14/09 09:02 AM
Posts: 75,089 A Banana Republic near you.
JohnRR
Yep they do that. Put it on the ground and it will stop unless you have other issues.
he has no driveshaft so that won't work, but if it was in it would stop the output shaft from spinning. The input shaft and the cluster gear is spinning whenever the engine is running and the clutch is engagedbecause its attached to the turning crankshft , the oil is causing it the spin .
I wonder if ATF would be less likely to make it spin ?
[Re: Jim_Lusk]
#374489
07/14/09 11:42 AM
07/14/09 11:42 AM
Posts: 10,232 Someplace you aren't
SomeCarGuy
I run 85-140 in mine, works great hot and cold. ATF and Passion lube made it almost unbearable to shift and led to grinding.
I want my fair share
