Does output shaft on 833 4spd spin while in neutral? #374481
07/13/09 09:54 PM
07/13/09 09:54 PM
Wichita,KS
Blakcharger440 Offline OP
Wichita,KS
I am wondering if the output shaft on a 833 4speed trans is supposed to be spinning while it is in neutral?
Re: Does output shaft on 833 4spd spin while in neutral? [Re: Blakcharger440] #374482
07/13/09 10:10 PM
07/13/09 10:10 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
If it is out of the car and spinning when turned by hand it can just be drag from lube in the trans. If you can't hold it from turning with your other hand you probably have issues inside.
Re: Does output shaft on 833 4spd spin while in neutral? [Re: Blakcharger440] #374483
07/13/09 10:11 PM
07/13/09 10:11 PM
clarks summit pa
73cuda340 Offline
73cuda340  Offline
clarks summit pa
I was wondering the same thing because on my car if it is jacked up the back wheels will spin when in neutral but if its on the ground they wont.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Does output shaft on 833 4spd spin while in neutral? [Re: 73cuda340] #374484
07/13/09 10:25 PM
07/13/09 10:25 PM
Depends on what lube you run, and temp. "It likely will"
Re: Does output shaft on 833 4spd spin while in neutral? #374485
07/13/09 11:07 PM
07/13/09 11:07 PM
Wichita,KS
Wichita,KS
I started the car and shifted the trans to neutral. I do not have the driveshaft in yet.
I am running a 85-140wt lube and I had the car running for about a couple of minutes so that I could "check" the trans before putting the driveshaft in.
Re: Does output shaft on 833 4spd spin while in neutral? [Re: Blakcharger440] #374486
07/14/09 02:01 AM
07/14/09 02:01 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Yep they do that. Put it on the ground and it will stop unless you have other issues.
I want my fair share
Re: Does output shaft on 833 4spd spin while in neutral? [Re: SomeCarGuy] #374487
07/14/09 09:02 AM
07/14/09 09:02 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
he has no driveshaft so that won't work, but if it was in it would stop the output shaft from spinning. The input shaft and the cluster gear is spinning whenever the engine is running and the clutch is engagedbecause its attached to the turning crankshft , the oil is causing it the spin .
I wonder if ATF would be less likely to make it spin ?
Re: Does output shaft on 833 4spd spin while in neutral? [Re: JohnRR] #374488
07/14/09 10:23 AM
07/14/09 10:23 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I suspect with that weight oil it will be hard to shift, too. Especially when it's cold. I have 85-90 in my son's hemi four speed.
And yes, the output shaft will spin with no load in nuetral.
Re: Does output shaft on 833 4spd spin while in neutral? [Re: Jim_Lusk] #374489
07/14/09 11:42 AM
07/14/09 11:42 AM
SomeCarGuy Offline
SomeCarGuy  Offline
I run 85-140 in mine, works great hot and cold. ATF and Passion lube made it almost unbearable to shift and led to grinding.
