Re: Time for ALUMINUM heads! But which ones?!? HELP!!!
[Re: mopower76]
#371809
07/10/09 07:06 PM
07/10/09 07:06 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I think the Edelbrock 84 cc heads and some mild porting would be just what you need.
[Re: mopower76]
#371811
07/10/09 08:26 PM
07/10/09 08:26 PM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
Hey all, I am ready to upgrade my 1970 Challenger to aluminum heads. With all of the after-market heads out there now I’m running in circles with what to go with. So I am looking toward the Mopowed knowledge of you all on the Moparts web board for the correct parts the first time.
I also want to run a roller camshaft and roller valve train. So I am also asking for input on what to run there also.
The current set-up is as follows –
Motor – - 1969 HP 440 block w/stock steel crank - 452 heads (gasket matched) with stock valve train - M1 intake - Hooker Headers (3 ½ collectors) - Main stud girdle & windage tray - Demon 880 carburetor - Holley Volu-Max fuel pump
Car – - 1970 Challenger - Dana 60 w/4:10 gear - Mini tubbed - Stock suspension with 90/10 front - slightly too long in the rear - 29x12.5x15 Hoosier quick time pros – 3.5’s up front - Box tube sub frame connectors - 6 cylinder torsion bars
The car was on a RW Dyno and made 398hp and 486lbs with a 750 Holley The best pass on the street tires and full exhaust was 11.89 @ 120 with a 1.61 short time.
I believe that covers everything, any and all help and opinion would be greatly appreciated!
Thanks, and remember . . . Do it in a MOPAR!!!
What cam are you running with the 11.89 at 120 combo? The 120 is a good speed to maybe hit the mid to high 10's.
You say opinion, so this is what I think. No need for a roller set up unless you want to spend the money. A solid cam will make very good power at a better cost than a roller. I also think the 440source CNC'd Stealth heads will do the trick with simple Iron ductil adjustable rockers.
I had a combo close to you. Demon 825 Race carb, M-1 intake, 452 iron (full ported) heads, Hooker super comp headers. I had the Ultradyn .613 solid cam. In a 4000 lb. car it ran 11.16 on Hoosier QTP's. All in a little 440.
Snap your neck, mega G-force launch, is all I want!
[Re: 64Post]
#371814
07/11/09 07:01 AM
07/11/09 07:01 AM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
Any out of te box head will need checked.I spent like 500 on the upgrades for my Stealths that I would have done to the Eddys also.Its pretty much a matter of choice.Rocky
Chrysler Firepower
[Re: therocks]
#371815
07/11/09 11:40 AM
07/11/09 11:40 AM
Chris2581
Jacksonville, FL
Only reason I didn't mention the Stealth heads is that I've never seen a set or used them,and usually there is a big -discussion about them.But the Stealth heads would work great too.
[Re: Chris2581]
#371816
07/11/09 03:54 PM
07/11/09 03:54 PM
therocks
Niles , Ohio
My stealths have been on 2 years.No problesm and they make noticably more power.Rocky
Chrysler Firepower
[Re: therocks]
#371817
07/11/09 11:21 PM
07/11/09 11:21 PM
DaytonaTurbo
Manitoba, Canada
I bought a set of 440source stealth heads for mine on their first production run. I just bolted them on for the first time this week and have not run them yet. I know, I know, took me forever to get around to this project. If I had to do it over again I would run stock heads and try a centrifugal supercharger with a mild hydraulic cam, but that's ansering a question you didn't ask, lol. One thing I like about the stealths is after I painted the motor, at a casual glance they look like stock heads. Get up close and you can tell they're not stock because the casting lines and machined surfaces are too crisp.
