Time for ALUMINUM heads! But which ones?!? HELP!!! #371808
07/10/09 06:40 PM
07/10/09 06:40 PM
Champaign, Illinois
mopower76 Offline OP
Champaign, Illinois
Hey all,
I am ready to upgrade my 1970 Challenger to aluminum heads.
With all of the after-market heads out there now I’m running in circles with what to go with.
So I am looking toward the Mopowed knowledge of you all on the Moparts web board for the correct parts the first time.
I also want to run a roller camshaft and roller valve train. So I am also asking for input on what to run there also.
The current set-up is as follows –
Motor –
- 1969 HP 440 block w/stock steel crank
- 452 heads (gasket matched) with stock valve train
- M1 intake
- Hooker Headers (3 ½ collectors)
- Main stud girdle & windage tray
- Demon 880 carburetor
- Holley Volu-Max fuel pump
Car –
- 1970 Challenger
- Dana 60 w/4:10 gear
- Mini tubbed
- Stock suspension with 90/10 front - slightly too long in the rear
- 29x12.5x15 Hoosier quick time pros – 3.5’s up front
- Box tube sub frame connectors
- 6 cylinder torsion bars
The car was on a RW Dyno and made 398hp and 486lbs with a 750 Holley
The best pass on the street tires and full exhaust was 11.89 @ 120 with a 1.61 short time.
I believe that covers everything, any and all help and opinion would be greatly appreciated!
Thanks, and remember . . . Do it in a MOPAR!!!
Re: Time for ALUMINUM heads! But which ones?!? HELP!!! [Re: mopower76] #371809
07/10/09 07:06 PM
07/10/09 07:06 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I think the Edelbrock 84 cc heads and some mild porting would be just what you need.
Nautilus Racing-
Re: Time for ALUMINUM heads! But which ones?!? HELP!!! [Re: Chris2581] #371810
07/10/09 07:14 PM
07/10/09 07:14 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
Those are good, but if you want an extra $500 to put towards your roller valve train then consider the 440Source units. I'm running them (1st production run) and while they needed a bit of 'tweeking' I'm very happy with them for the money I spent ($899 loaded). I also used a roller setup and went with the Comp Cams retro hydraulic roller.
Re: Time for ALUMINUM heads! But which ones?!? HELP!!! [Re: mopower76] #371811
07/10/09 08:26 PM
07/10/09 08:26 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Hey all,
Motor –
- M1 intake
Car –
- 1970 Challenger
- Mini tubbed
What cam are you running with the 11.89 at 120
combo? The 120 is a good speed to maybe hit
the mid to high 10's.
You say opinion, so this is what I think. No need
for a roller set up unless you want to spend the money.
A solid cam will make very good power at
a better cost than a roller. I also think the
440source CNC'd Stealth heads will do the trick
with simple Iron ductil adjustable rockers.
I had a combo close to you. Demon 825 Race carb,
M-1 intake, 452 iron (full ported) heads, Hooker
super comp headers. I had the Ultradyn .613 solid
cam. In a 4000 lb. car it ran 11.16 on Hoosier
QTP's. All in a little 440.
Snap your neck, mega G-force launch, is all I want!
Re: Time for ALUMINUM heads! But which ones?!? HELP!!! [Re: BDS871Cuda] #371812
07/10/09 11:03 PM
07/10/09 11:03 PM
IN
ahy Offline
ahy  Offline
IN
Agree the 84cc Edlebrocks or stealth equivalents would work great. With either one, a good shop should at least "prep" the heads meaning check valve to guide clearance, do a good valve job and clean up the ports and bowls. Muscle Motors, Hughes and others offer this service. CNC porting would be better but not needed in your application.
I'm running prepped and pocket ported Edelbrocks with an agressive mechanical flat tappet cam on a 496 and love the combo. I run diesel oil plus STP to deal with the zinc issue with no problems so far. If you go roller, make sure you work with somebody who knows how to set it up in a 440. Cam end play needs to be set with a thrust button and special care may be needed to set up oiling correctly.
Re: Time for ALUMINUM heads! But which ones?!? HELP!! [Re: mopower76] #371813
07/11/09 12:11 AM
07/11/09 12:11 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Cleaned up and checked 440 source heads is all you need. I would strongly advise spending a few bucks for EDM lifters if you're going with a solid cam.
Re: Time for ALUMINUM heads! But which ones?!? HELP!! [Re: 64Post] #371814
07/11/09 07:01 AM
07/11/09 07:01 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Any out of te box head will need checked.I spent like 500 on the upgrades for my Stealths that I would have done to the Eddys also.Its pretty much a matter of choice.Rocky
Chrysler Firepower
Re: Time for ALUMINUM heads! But which ones?!? HELP!! [Re: therocks] #371815
07/11/09 11:40 AM
07/11/09 11:40 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Only reason I didn't mention the Stealth heads is that I've never seen a set or used them,and usually there is a big -discussion about them.But the Stealth heads would work great too.
Nautilus Racing-
Re: Time for ALUMINUM heads! But which ones?!? HELP!! [Re: Chris2581] #371816
07/11/09 03:54 PM
07/11/09 03:54 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My stealths have been on 2 years.No problesm and they make noticably more power.Rocky
Chrysler Firepower
Re: Time for ALUMINUM heads! But which ones?!? HELP!! [Re: therocks] #371817
07/11/09 11:21 PM
07/11/09 11:21 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I bought a set of 440source stealth heads for mine on their first production run. I just bolted them on for the first time this week and have not run them yet. I know, I know, took me forever to get around to this project. If I had to do it over again I would run stock heads and try a centrifugal supercharger with a mild hydraulic cam, but that's ansering a question you didn't ask, lol.
One thing I like about the stealths is after I painted the motor, at a casual glance they look like stock heads. Get up close and you can tell they're not stock because the casting lines and machined surfaces are too crisp.
Re: Time for ALUMINUM heads! But which ones?!? HELP!! [Re: DaytonaTurbo] #371818
07/11/09 11:55 PM
07/11/09 11:55 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
Go with Edelbrock victors or Indy SRs, ether one of these heads with also work better with that Roller cam you want to use. Good heads and a good camshaft is where the horse power is at.
