Re: Paint wet sanding question
[Re: calimoparguy]
#326307
05/23/09 07:19 PM
05/23/09 07:19 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I find those foam block leave to many "waves" in the clear/topcoat leaving you with the "water ripple" effect in your final finish, esp, dark colors, rather than a "flat mirror" reflection,........heres's a car that I wet sanded out using a hard rubber 3"X5"X1/2" pad/block,(avaiable at most automotive paint suppliers) and the true and tried paint stick( local hardware store, mixing/stiring sticks).....started with 1000, then 1500, then 2000, finihed with 3000 grit.....minimal amount of machine polishing needed afterwards
[Re: calimoparguy]
#326308
05/23/09 07:29 PM
05/23/09 07:29 PM
Posts: 12,405 Southern, Ca.
69DartGT
moparts member
moparts member
Southern, Ca.
really, harbor freight has them??
Sorry I misread your post wrong blocks at Harbor Freight. Try Eastwood though.
[Re: elitecustombody]
#326310
05/24/09 08:34 AM
05/24/09 08:34 AM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
That is what I use too, a 3 x 5 hard rubber sanding block, starting with 1200 grit, 1500 and 2000....mirror like results!
For Big, flat surfaces, I use the bigger 4x8 block with hard orange plastic top with 1/4 inch rubber pad underneath
Daniel
[Re: Wedgeman]
#326311
05/24/09 02:57 PM
05/24/09 02:57 PM
Posts: 6,516 Santa Cruz, California
Lefty
Daniel
Thanks, good info. I have to redo my Coronet because of over spray and was wondering what block/pad was best for color sanding. I assume you use the paint stick in the close quarter areas and the hard rubber pad on everything else?
[Re: Lefty]
#326312
05/24/09 04:16 PM
05/24/09 04:16 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Correct,.....never let your "fingers do the walking", or a soft surface behind paper, or those "sanding blocks" for delicate finial surface work,.....I know there's times of nooks and crannys that you have no choice, but for the open expanses of sheetmetal, you want a resilant surface under your paper, to produce a "flat finish".....good luck on your project!
#326314
05/24/09 06:55 PM
05/24/09 06:55 PM
Posts: 1,175 NC
DARTSPORT340
super gas
super gas
NC
I agree with DAYCLONA, use the best,most effective and the cheapest, paint mixing stick, it doesn't fail, foam blocks will only smooth out the orangepeel and you still end up with waves, I wrap mixing stick a few times with 2" masking tape than wrap the paper around it and go at it
I have sanded many many vehicles with a foam block and never had ripples or waves....Believe me if I did our uber picky customers would be throwing a fit.
