Paint wet sanding question #326300
05/23/09 01:22 PM
05/23/09 01:22 PM
so cal,cali
calimoparguy Offline OP
so cal,cali
Who sells those foam sanding blocks used for color sanding cars?
Re: Paint wet sanding question [Re: calimoparguy] #326301
05/23/09 01:24 PM
05/23/09 01:24 PM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
Summit & Harbor Freight for one.
Re: Paint wet sanding question [Re: 69DartGT] #326302
05/23/09 01:42 PM
05/23/09 01:42 PM
so cal,cali
so cal,cali
really, harbor freight has them??
Re: Paint wet sanding question [Re: calimoparguy] #326303
05/23/09 01:46 PM
05/23/09 01:46 PM
Medford OR
FrankenScamp Offline
Medford OR
I have a foam block I bought @ NAPA. The paper side of the block has holes and the block is kind of arched to contour to the sanding surface.
Is that what your looking for??
Re: Paint wet sanding question [Re: FrankenScamp] #326304
05/23/09 02:09 PM
05/23/09 02:09 PM
Flint, MI
Gusteve Offline
I Love the Unicorn Song!!
Gusteve  Offline
Flint, MI
My local hardware store had them. There were probably around 600 grit, but i just wrapped them in higher grit paper.
Re: Paint wet sanding question [Re: calimoparguy] #326305
05/23/09 06:56 PM
05/23/09 06:56 PM
Az
Crizila Offline
Crizila  Offline
Az
Don't think I would be color sanding with anything less than a 1000. Maybe even 1500.
Fastest 300
Re: Paint wet sanding question [Re: Crizila] #326306
05/23/09 07:15 PM
05/23/09 07:15 PM
NC
DARTSPORT340 Offline
super gas
super gas
NC
DuraBlock makes nice flexable blocks in various sizes and hardnesses. I got all mine at the local paint store they arent cheap but they do a great job.
Re: Paint wet sanding question [Re: calimoparguy] #326307
05/23/09 07:19 PM
05/23/09 07:19 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I find those foam block leave to many "waves" in the clear/topcoat leaving you with the "water ripple" effect in your final finish, esp, dark colors, rather than a "flat mirror" reflection,........heres's a car that I wet sanded out using a hard rubber 3"X5"X1/2" pad/block,(avaiable at most automotive paint suppliers) and the true and tried paint stick( local hardware store, mixing/stiring sticks).....started with 1000, then 1500, then 2000, finihed with 3000 grit.....minimal amount of machine polishing needed afterwards
Re: Paint wet sanding question [Re: calimoparguy] #326308
05/23/09 07:29 PM
05/23/09 07:29 PM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
Sorry I misread your post wrong blocks at Harbor Freight.
Try Eastwood though.
Re: Paint wet sanding question [Re: calimoparguy] #326309
05/23/09 08:28 PM
05/23/09 08:28 PM
Jacksonville Florida
elitecustombody Offline
I agree with DAYCLONA, use the best,most effective and the cheapest, paint mixing stick, it doesn't fail, foam blocks will only smooth out the orangepeel and you still end up with waves, I wrap mixing stick a few times with 2" masking tape than wrap the paper around it and go at it
Re: Paint wet sanding question [Re: elitecustombody] #326310
05/24/09 08:34 AM
05/24/09 08:34 AM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
That is what I use too, a 3 x 5 hard rubber sanding block, starting with 1200 grit, 1500 and 2000....mirror like results!
For Big, flat surfaces, I use the bigger 4x8 block with hard orange plastic top with 1/4 inch rubber pad underneath
Daniel
Re: Paint wet sanding question [Re: Wedgeman] #326311
05/24/09 02:57 PM
05/24/09 02:57 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Daniel
Thanks, good info. I have to redo my Coronet because of over spray and was wondering what block/pad was best for color sanding. I assume you use the paint stick in the close quarter areas and the hard rubber pad on everything else?
Re: Paint wet sanding question [Re: Lefty] #326312
05/24/09 04:16 PM
05/24/09 04:16 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Correct,.....never let your "fingers do the walking", or a soft surface behind paper, or those "sanding blocks" for delicate finial surface work,.....I know there's times of nooks and crannys that you have no choice, but for the open expanses of sheetmetal, you want a resilant surface under your paper, to produce a "flat finish".....good luck on your project!
Re: Paint wet sanding question [Re: DAYCLONA] #326313
05/24/09 06:50 PM
05/24/09 06:50 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
A length of rubber hose works well for contoured areas. I prefer the softer 3M pads over the hard arched blocks. Your local auto paint store should have a good selection.
I can't imagine being able to sand waves into a car with 1500 or 2000, or for that matter even 600, unless the person is either using their fingers, or the bodywork wasn't right and is revealed by blocking. Wetsanding should not be aggressive.
Re: Paint wet sanding question [Re: elitecustombody] #326314
05/24/09 06:55 PM
05/24/09 06:55 PM
NC
super gas
super gas
NC
I have sanded many many vehicles with a foam block and never had ripples or waves....Believe me if I did our uber picky customers would be throwing a fit.
