I agree with DAYCLONA, use the best,most effective and the cheapest, paint mixing stick, it doesn't fail, foam blocks will only smooth out the orangepeel and you still end up with waves, I wrap mixing stick a few times with 2" masking tape than wrap the paper around it and go at it
