Electric pump w/o thermostat #324621
05/21/09 10:32 AM
05/21/09 10:32 AM
Odessa, Tx.
cudarex Offline OP
cudarex  Offline OP
Odessa, Tx.
How many of you are running electric pump w/o thermostat? I pulled the radiator cap off last night and notice the flow was so much that it was actually trying to slosh out the opening making me think the flow is too much without the thermostat. Thinking of gutting a thermostat and trying that to slow down the flow. This is a street/strip car mostly strip. What's your thoughts?
Re: Electric pump w/o thermostat [Re: cudarex] #324622
05/21/09 10:37 AM
05/21/09 10:37 AM
an8sec70cuda Offline
No thermostat here w/ the "drop-in" Meziere pump. It doesn't try to slosh water out the radiator like you're describing. Works good enough that it's sitting out in the parking lot here at the office. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Electric pump w/o thermostat [Re: an8sec70cuda] #324623
05/21/09 11:00 AM
05/21/09 11:00 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I gutted my thermostat.....
Mopar Performance
Re: Electric pump w/o thermostat [Re: moparniac] #324624
05/21/09 11:14 AM
05/21/09 11:14 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
no stat no problems
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Electric pump w/o thermostat [Re: moparniac] #324625
05/21/09 11:18 AM
05/21/09 11:18 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Too much water flow is not possible imho(unless we are dealing with over cooling). That is a common misconception and does not coincide with the laws of Thermodynamics.
Even if the water flows faster and has less time to transfer heat to the radiator...it also has less time to absorb heat in every pass through the engine....so thats a wash. Also, now the water flows through the radiator many more times per hour. Thats my belief anyways.
I still use a stat with my electric pump to help it warm up faster as I have it wired by a relay connected to the ignition switch.
Re: Electric pump w/o thermostat [Re: moparniac] #324626
05/21/09 12:11 PM
05/21/09 12:11 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
same here no issues.
Re: Electric pump w/o thermostat [Re: Quicksilver440] #324627
05/21/09 12:15 PM
05/21/09 12:15 PM
AndyF Online content
AndyF  Online Content
That is correct, the more flow the better. I'd think with an electric pump there wouldn't be any reason for a thermostat. Just keep the pump off until you see the needle on the temp gauge start to move up and then flip the switch.
Re: Electric pump w/o thermostat [Re: AndyF] #324628
05/21/09 12:24 PM
05/21/09 12:24 PM
Odessa, Tx.
cudarex Offline OP
cudarex  Offline OP
Odessa, Tx.
Hate to keep it off too long in the fact that thermocouple being in the wp housing inlieu of the heads (hottest spot).
Experimented with that the other day when I started car without pump on and watched gauge. After about 1 min. turned on pump and gauge jumped a good 50 degrees. Don't know why head mfg. don't put a conn. in the head for that.
Re: Electric pump w/o thermostat [Re: cudarex] #324629
05/22/09 11:38 AM
05/22/09 11:38 AM
Odessa, Tx.
cudarex Offline OP
cudarex  Offline OP
Odessa, Tx.
For the next day crowd.
