Re: Electric pump w/o thermostat
[Re: cudarex]
#324622
05/21/09 10:37 AM
05/21/09 10:37 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
No thermostat here w/ the "drop-in" Meziere pump. It doesn't try to slosh water out the radiator like you're describing. Works good enough that it's sitting out in the parking lot here at the office. CHIP
[Re: an8sec70cuda]
#324623
05/21/09 11:00 AM
05/21/09 11:00 AM
Posts: 6,295 U.S.
moparniac
U.S.
I gutted my thermostat.....
Mopar Performance
[Re: moparniac]
#324626
05/21/09 12:11 PM
05/21/09 12:11 PM
Posts: 1,775 Keymar, MD
DusterKid
Keymar, MD
same here no issues.
[Re: AndyF]
#324628
05/21/09 12:24 PM
05/21/09 12:24 PM
Posts: 2,930 Odessa, Tx.
cudarex
Odessa, Tx.
That is correct, the more flow the better. I'd think with an electric pump there wouldn't be any reason for a thermostat. Just keep the pump off until you see the needle on the temp gauge start to move up and then flip the switch.
Hate to keep it off too long in the fact that thermocouple being in the wp housing inlieu of the heads (hottest spot). Experimented with that the other day when I started car without pump on and watched gauge. After about 1 min. turned on pump and gauge jumped a good 50 degrees. Don't know why head mfg. don't put a conn. in the head for that.
