For Sale - Small Block Engine - 1st Quarter
#3202068
01/03/24 08:45 PM
01/03/24 08:45 PM
Posts: 15,550 Norwich CT USA
moparts
Norwich CT USA
Re: For Sale - Small Block Engine - 1st Quarter
[Re: moparts]
#3202098
01/03/24 10:17 PM
01/03/24 10:17 PM
Posts: 5,615 Detroit area
6PAX
Detroit area
70 B-body voltage regulator mounting bracket. $15
New chrome coil cover & coil mounting bracket. $20
NOS Cal Custom chrome radiator cap. $20
NOS Cal Custom chrome battery hold down. $25
Four new extra wide chrome valve cover hold down clamps. $10 for the set
New exhaust manifold heat stove to air cleaner flexible hose. $20
NOS fan clutch 3769614 for 1974 all V-8 engines. $100
Factory warning light type oil pressure sending unit. $10
Gauge type oil pressure sending unit. $20
Vintage Cal Custom 14" finned aluminum air cleaner with filter. $100
1970 Style single nipple oil breather with hose. $30
New 12" oval 4 barrel finned aluminum air cleaner with filter. It measures 12" L x 8 1/4" W x 3" H and has a 5 1/8" carb opening. $55
New Mopar Performance chrome water neck. Was bolted on an engine but then taken back off before the engine was ran. $10
AC alternator bracket from a mid 70s 360. $10
New Mr. Gasket chrome oil filter cover. $15
9 Chrome t-handle valve cover bolts. $10
Factory starter, part/casting #3755259. This came off of my Dart about 10 years ago. Worked fine then, been sitting on a shelf ever since. $40
Two 318 driver side spool motor mounts pt#3642811. One is used and one is NOS. $20 for the used. $35 for the NOS.
Edelbrock Elite small block valve covers EDL-4295 with bolts, breather & PCV valve. Very nice condition. $200
NOS Cal Custom chrome dagger dipstick handle. $25
New Mopar Performance 5 blade radiator fan and clutch. $100
Pioneer Automotive cylinder head dowel pins. 21 pieces 1/4" x 5/8". $10
Howard's solid flat tappet cam for Mopar big blocks, part number CL722322-08. See links below for specifications. I bought this cam for my engine with the intention of taking the car to the track when the car was finished being restored along with the engine being built but I have changed my mind about racing the car and decided to go with a milder hydraulic cam instead. I had this cam installed in my engine on the engine stand only (engine is still on the stand) so it has never been run and is essentially new. $375
New set of COMP Cams 973-16 - Inner Valve Springs. $45
2 used Holley 450 cfm carbs, part number 9776, for dual quad set-ups. Carbs are in nice shape and worked fine the last time they were used. The only thing wrong with them is on one of them the small vacuum fitting that sticks out the side needs replacing as the tube broke off. $450 for the pair.
Chrome single groove alternator pulley. $15
1975 Date coded alternator. Part #3874271. $25
Rev-n-nator Coil and programmable ICU. $200
Vintage Cal Custom scoop style air cleaner. Includes often missing matching wingnut. $300
New in boxes QTP 2 1/2" electric exhaust cutouts #QTEC50, stainless y-pipes #10250 and remote controller #10900. $654 total price at Summit. $550
Prices do not include shipping. No Paypal
Email: gt340 @ yahoo.com
Re: For Sale - Small Block Tach drive distributor
[Re: moparts]
#3202980
01/07/24 01:27 PM
01/07/24 01:27 PM
Posts: 19,383 north of coder
moparx
SOLD ! Mopar Performance small block tach drive electronic distributor for sale. very lightly used piece. comes in original Mopar Performance box. asking $160.00 shipped anywhere in the lower 48 states. [offer?] contact me here, or : moparxz "at" comcast "dot" net. Thank you MOPARTS for the add !
Re: 340 Exhaust Manifold - 2863549 1968-70 RH
[Re: Mopar_Mike]
#3203094
01/07/24 08:30 PM
01/07/24 08:30 PM
Posts: 327 delhi,il
trw1982
delhi,il
SOLD. THANKS. small block b/e mounts. 40.00 each pair shipped. pp or usps m/o.
Re: 1960-1961 Dodge Dart,Plymouth v8 ,TUNE UP KIT
[Re: Rocket]
#3204622
01/14/24 01:36 PM
01/14/24 01:36 PM
Posts: 11,912 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
NORS USA MADE MAJOR TUNE UP KIT PLUS WILL FIT; 1960-1961 DODGE DART V8 , 318 ALUMINUM SINGLE POINT DISTRIBUTOR 1960-1961 PLYMOUTH V8 318 INCLUDES; BRASS INSERT HD DISTRIBUTOR CAP ROTOR POINTS CONDENSER NIEHOFF AL-331 VACUUM ADVANCE(REPLACES CHRYSLER/MOPAR#1881944 NIEHOFF DISTRIBUTOR PLATE WITH POINTS&CONDENSER(THIS WILL HAVE TO BE RE LUBRICATED AS ITS SAT IN A BOX ON THE SHELF FOR 50 PLUS YEARS 1 TEMP SENDING UNIT 1 OIL PRESSURE SWITCH 1 FLASHER 1 90 DEGREE ,METAL PCV VALVE(FITS 1961 &UP) 1 USA MADE ELECTRONIC VOLTAGE REGULATOR(FOR AN ALTERNATOR) 8 AUTOLITE S[PARK PLUGS(1 RANGE HOTTER THAN STOCK) 1 BLACK IGNITION WIRE SET
THIS KIT FITS A CHRYSLER ALUMINUM SINGLE POINT DISTRIBUTOR. #1838505, 2095836 WILL NOT FIT CAST IRON DISTRIBUTOR CATALOG SHOWS THIS ABOVE KIT FITTING
1959 PLYMOUTH SMALL BLOCK 1961 PLYMOUTH V8 STANDARD SAVOY,FURY,BELVEDERE WITH CHRYSLER ALUMINUM DISTRIBUTOR 2095647,1838505, 1889710 1960 DODGE DART,MATADOR,POLARA V8 SMALL BLOCK WITH ALUMINUM DIST#1838505 1961 DODGE V8 #2095836 1961 DODGE DART V8 SMALL BLOCK 1838505,2095647
IF YOU WANT TO KNOW IF THIS KIT WILL FIT YOUR CAR, GIVE ME YOUR CHRYSLER ALUMINUM DISTRIBUTOR TAG# TO CONFIRM$130 mailed insured/tracked large priority mail flat rate box
cowgerwilliam035@gmail.com
W-2 Small Block Throttle Cable Bracket
[Re: Memongo]
#3206847
01/21/24 01:53 PM
01/21/24 01:53 PM
Posts: 4,161 Fenton, MI
Memongo
Parts peddler
Parts peddler
Fenton, MI
W-2 Small Block Throttle Cable Bracket. New, $15 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only! Call Steve 810-629-1097
Factory Small Block Valve Covers 318,340,360
[Re: Memongo]
#3206848
01/21/24 01:54 PM
01/21/24 01:54 PM
Memongo
Parts peddler
Parts peddler
Fenton, MI
Factory Small Block Valve Covers 318,340,360, Used, $50 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only! Call Steve 810-629-1097
Note: All Harness, Wire Brackets Intact!
Mopar Performance P4120484 Fuel Pump Eccentric Small Block
[Re: Memongo]
#3206858
01/21/24 02:09 PM
01/21/24 02:09 PM
Memongo
Parts peddler
Parts peddler
Fenton, MI
Mopar Performance P4120484 Fuel Pump Eccentric Small Block 273, 318, 340, 360. Payment via US Postal Money Order Only!. Shipping: US Address Only! Call Steve 810-629-1097
Photo 1. Used, $20 + Shipping
Re: Used right side, E-body, SB engine mount bracket
[Re: moparts]
#3208162
01/25/24 08:07 PM
01/25/24 08:07 PM
Posts: 1,689 Edison, New Jersey
PHYSIXX
Edison, New Jersey
I have for sale a used right side, E-body, SB engine mount bracket. It’ll fit any of the SB engines. This bracket is straight, clean and painted. It comes with the 3 OEM attaching bolts, nuts but only 2 of the flat washers. I would like to get $8.00 for everything plus the shipping.
Edison, NJ rider1454 at aol.com
Re: OEM 360 cast crank, #3418640, .010/.010 & balancer,
[Re: PHYSIXX]
#3208164
01/25/24 08:15 PM
01/25/24 08:15 PM
PHYSIXX
Edison, New Jersey
I have for sale a really nice OEM 360 cast crank, casting number 3418640. This crank was in a 360 block with a 1971 casting date. This is very clean with the rods and main journals already cut .010/.010. The only thing that this might need is a very light polish. Other than that, it needs nothing. At some point though, this crank was balanced at the back of the crank as Mallory metal was installed in the last counter weight as seen in the pics. No heavy metal at the front though since the OEM balancer was used. Neutral balance converter and standard offset weight front balancer setup. Additionally, the oiling holes have been chamfered so better bearing oiling. In addition, the OEM balancer that was used for the original balancing is included. The hub is in decent shape but a slight groove can be felt so perhaps a repair sleeve might be in order. The balancer pulley bolts are also included. I would like to get $75.00 for everything plus the shipping. This is a heavy piece so the shipping will be crazy. Local pickup would be great or depending on location, I can meet part way for the cost of fuel and any tolls.
New BRC 4.030" Forged Pistons and pins for 3.79" Stoke Crank
[Re: 6PAX]
#3208696
01/28/24 11:17 AM
01/28/24 11:17 AM
Posts: 886 CT
Rocket
CT
I have a set of New BRC 4.030" forged flat top pistons and pins for a 3.79" stroke small block crankshaft. Compression height is ~ 1.57" and the ring lands are 1/16, 1/16 and 3/16. Pins are 0.984”. Approximately 6cc valve reliefs.
These pistons can be used in aftermarket race blocks or stock 360/5.9 magnum engine blocks.
Price is $475 shipped in the lower 48 states. I will ship elsewhere for the added cost.
Email me at procketrichard@hotmail.com with any questions or for more pictures.
340 motor mounts and new insulators
[Re: moparts]
#3211205
02/06/24 06:01 PM
02/06/24 06:01 PM
Posts: 1,547 Mattituck NY.
FJ6AAR
Mattituck NY.
**SOLD - Thank You Moparts**
Hi all, I have a set of 340 motor mounts and new insulators. These are correct for a 340 engine which I believe are 340 only? Asking $70.00 shipped. Good old fashioned postal money order only. Plese PM me here for fastest response. Thank you for the ad moparts!
1970 Hemi 'Cuda hard top clone
1971 Hemi 'Cuda Convertible clone
340 sixpack set up
[Re: moparts]
#3211917
02/08/24 11:23 AM
02/08/24 11:23 AM
xx29
For sale: 340 6 pack intake, carbs, air cleaner. Has 440 6 pack carbs. Air cleaner base plate looks new. $4500. Can deliver to Spring Fling show in Van Nuys, CA April 20th, 2024. Email: ebodycab @msn.com Phone: 818-426-8685
1970 340 block and crank
[Re: LSP]
#3213209
02/13/24 12:40 PM
02/13/24 12:40 PM
Posts: 147 waynesboro va
jonesboys
waynesboro va
1970 340 block and crank engine is from a 1970 Cuda Vin 0b212337 build date7,14,69 2780930,340,6 block has been pressure tested cleaned has no damage crank has been turned 10,10 and was in a stick car pilot bushing in place also has a 1969 318 for parts pictures are to large to load can text photos to interested buyers PRICE 2000.00
1970 340 4 speed carb
[Re: moparts]
#3214753
02/19/24 08:59 PM
02/19/24 08:59 PM
Posts: 631 Wisconsin
71duster414
Wisconsin
1970 340 4 speed carburetor
Good condition, rebuild or restore. Secondary throttle shaft is tight.
$400 obo
hoffmanhhr@gmail.com
1972 340 4 speed carb
[Re: 71duster414]
#3214895
02/20/24 12:53 PM
02/20/24 12:53 PM
71duster414
Wisconsin
1972 340 4 speed carburetor This carb is in good condition and moves freely.
$400 obo
Re: CROWER CAM&LIFTERS,ROLLER CHAIN &GEAR SET
[Re: 71duster414]
#3217049
02/29/24 01:52 PM
02/29/24 01:52 PM
Joesixpack
APACHE JUNCTION AZ
NEW 340-360 CROWER CAMSHAFT AND LIFTERS &MP DOUBLE ROLLER CHAIN&GEAR SET,CAM IS #31981 304HC, 501/304 114 LOBE SEP, .334 LOBE LIFT,238 DURATION AT .050, LIFTER#66031X3-16, BRAND NEW$400 cowgerwilliam035@gmail.com
Re: 360 MOROSO DEEP PAN,PU,PUMP,W TRAY NEW
[Re: Joesixpack]
#3217052
02/29/24 01:54 PM
02/29/24 01:54 PM
Joesixpack
APACHE JUNCTION AZ
360 A,B&E MOROSO DEEP OIL PAN,PICKUP, OIL PUMP,WINDAGE TRAY, ALL NEW ,WAS INSTALLED and removed from a fresh shortblock$250
Re:
[Re: Joesixpack]
#3217053
02/29/24 01:58 PM
02/29/24 01:58 PM
Joesixpack
APACHE JUNCTION AZ
340-360 mopar parts COATED 1 7/8S JR 340-360,MULTI PIECE HEADERS B&E STOCK/SUPERSTOCK ARE NEW NEW$500 TRAVELLLING FROM AZ TO PA IN APRIL CAN DROP OFF ANYWHERE ALONG THE ROUTE
Re:Chrysler Marine 360 front cover,pump alternator,pullies
[Re: WINGNUT]
#3217970
03/04/24 11:22 AM
03/04/24 11:22 AM
Joesixpack
APACHE JUNCTION AZ
360 chrysler marine Cast iron front timing cover,water pump, prestolite alternator& brackets, external mechanical water pump& brackets, pullies, belts, bolts, came off 75 chrysler marine 360 will fit 273 318 340 360 marine inboard engines. Also have a flywheel& exhaust manifolds if you want them. Package deal. ( included if you buy above parts)$300
EXPENSIVE TO SHIP HEAVY
TRAVELLING AZ TO PA IN APRIL CAN DROP OFF
[Re: Joesixpack]
#3217980
03/04/24 11:58 AM
03/04/24 11:58 AM
Joesixpack
APACHE JUNCTION AZ
1973 340 1974 360 ORIGINAL A-BODY SPOOL TYPE MOTOR MOUNT BOLTS,NUTS,WASHERS, INTAKE BOLTS, VALVE COVER BOLTS,OIL PAN BOLTS, AUTO TRANS FLEXPLATE TO CRANK BOLTS, TC BOLTS FLEX TO TC, FUEL PUMP BOLTS, USED, $60 cowgerwilliam035@gmail.com
Carter #9410s AFB Carbs 400 CFM (2)
[Re: moparts]
#3218042
03/04/24 03:46 PM
03/04/24 03:46 PM
Posts: 240 Northwest Indiana
19Coronet66
Northwest Indiana
For sale are a pair of Carter AFB carburetors. Carter part number #9410s. 400 CFM. Both carbs appear to be in good condition. Everything moves freely. Will need kits. $250 each plus shipping. Reasonable offer? Have a few additional pictures if needed.
PM if interested
1965 318 Poly/Auto
[Re: moparts]
#3220559
03/15/24 09:49 AM
03/15/24 09:49 AM
Posts: 4,053 ct.
moparlouie
ct.
I have an excellent running 318 poly with 70,000 miles with matching automatic trans. Complete, aircleaner to pan. In a parts car. Can hear run before I pull it. $1200. NO SHIPPING, located in Connecticut. lafrancebiglou@aol.com
Have been a member for years!
