For Sale - Small Block Engine - 1st Quarter
#3202068
01/03/24 08:45 PM
01/03/24 08:45 PM
Posts: 15,551 Norwich CT USA
moparts
Norwich CT USA
Re: For Sale - Small Block Engine - 1st Quarter
[Re: moparts]
#3202098
01/03/24 10:17 PM
01/03/24 10:17 PM
Posts: 5,632 Detroit area
6PAX
Detroit area
70 B-body voltage regulator mounting bracket. $15
New chrome coil cover & coil mounting bracket. $20
NOS Cal Custom chrome radiator cap. $20
NOS Cal Custom chrome battery hold down. $25
Four new extra wide chrome valve cover hold down clamps. $10 for the set
New exhaust manifold heat stove to air cleaner flexible hose. $20
NOS fan clutch 3769614 for 1974 all V-8 engines. $100
Factory warning light type oil pressure sending unit. $10
Gauge type oil pressure sending unit. $20
Vintage Cal Custom 14" finned aluminum air cleaner with filter. $100
1970 Style single nipple oil breather with hose. $30
New 12" oval 4 barrel finned aluminum air cleaner with filter. It measures 12" L x 8 1/4" W x 3" H and has a 5 1/8" carb opening. $55
New Mopar Performance chrome water neck. Was bolted on an engine but then taken back off before the engine was ran. $10
AC alternator bracket from a mid 70s 360. $10
New Mr. Gasket chrome oil filter cover. $15
9 Chrome t-handle valve cover bolts. $10
Factory starter, part/casting #3755259. This came off of my Dart about 10 years ago. Worked fine then, been sitting on a shelf ever since. $40
Two 318 driver side spool motor mounts pt#3642811. One is used and one is NOS. $20 for the used. $35 for the NOS.
Edelbrock Elite small block valve covers EDL-4295 with bolts, breather & PCV valve. Very nice condition. $200
NOS Cal Custom chrome dagger dipstick handle. $25
New Mopar Performance 5 blade radiator fan and clutch. $100
Pioneer Automotive cylinder head dowel pins. 21 pieces 1/4" x 5/8". $10
Howard's solid flat tappet cam for Mopar big blocks, part number CL722322-08. See links below for specifications. I bought this cam for my engine with the intention of taking the car to the track when the car was finished being restored along with the engine being built but I have changed my mind about racing the car and decided to go with a milder hydraulic cam instead. I had this cam installed in my engine on the engine stand only (engine is still on the stand) so it has never been run and is essentially new. $375
New set of COMP Cams 973-16 - Inner Valve Springs. $45
2 used Holley 450 cfm carbs, part number 9776, for dual quad set-ups. Carbs are in nice shape and worked fine the last time they were used. The only thing wrong with them is on one of them the small vacuum fitting that sticks out the side needs replacing as the tube broke off. $450 for the pair.
Chrome single groove alternator pulley. $15
1975 Date coded alternator. Part #3874271. $25
Rev-n-nator Coil and programmable ICU. $200
Vintage Cal Custom scoop style air cleaner. Includes often missing matching wingnut. $300
New in boxes QTP 2 1/2" electric exhaust cutouts #QTEC50, stainless y-pipes #10250 and remote controller #10900. $654 total price at Summit. $550
Prices do not include shipping. No Paypal
Email: gt340 @ yahoo.com
Re: For Sale - Small Block Tach drive distributor
[Re: moparts]
#3202980
01/07/24 01:27 PM
01/07/24 01:27 PM
Posts: 19,479 north of coder
moparx
SOLD ! Mopar Performance small block tach drive electronic distributor for sale. very lightly used piece. comes in original Mopar Performance box. asking $160.00 shipped anywhere in the lower 48 states. [offer?] contact me here, or : moparxz "at" comcast "dot" net. Thank you MOPARTS for the add !
Re: 340 Exhaust Manifold - 2863549 1968-70 RH
[Re: Mopar_Mike]
#3203094
01/07/24 08:30 PM
01/07/24 08:30 PM
Posts: 327 delhi,il
trw1982
delhi,il
SOLD. THANKS. small block b/e mounts. 40.00 each pair shipped. pp or usps m/o.
Re: 1960-1961 Dodge Dart,Plymouth v8 ,TUNE UP KIT
[Re: Rocket]
#3204622
01/14/24 01:36 PM
01/14/24 01:36 PM
Posts: 11,912 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
NORS USA MADE MAJOR TUNE UP KIT PLUS WILL FIT; 1960-1961 DODGE DART V8 , 318 ALUMINUM SINGLE POINT DISTRIBUTOR 1960-1961 PLYMOUTH V8 318 INCLUDES; BRASS INSERT HD DISTRIBUTOR CAP ROTOR POINTS CONDENSER NIEHOFF AL-331 VACUUM ADVANCE(REPLACES CHRYSLER/MOPAR#1881944 NIEHOFF DISTRIBUTOR PLATE WITH POINTS&CONDENSER(THIS WILL HAVE TO BE RE LUBRICATED AS ITS SAT IN A BOX ON THE SHELF FOR 50 PLUS YEARS 1 TEMP SENDING UNIT 1 OIL PRESSURE SWITCH 1 FLASHER 1 90 DEGREE ,METAL PCV VALVE(FITS 1961 &UP) 1 USA MADE ELECTRONIC VOLTAGE REGULATOR(FOR AN ALTERNATOR) 8 AUTOLITE S[PARK PLUGS(1 RANGE HOTTER THAN STOCK) 1 BLACK IGNITION WIRE SET
THIS KIT FITS A CHRYSLER ALUMINUM SINGLE POINT DISTRIBUTOR. #1838505, 2095836 WILL NOT FIT CAST IRON DISTRIBUTOR CATALOG SHOWS THIS ABOVE KIT FITTING
1959 PLYMOUTH SMALL BLOCK 1961 PLYMOUTH V8 STANDARD SAVOY,FURY,BELVEDERE WITH CHRYSLER ALUMINUM DISTRIBUTOR 2095647,1838505, 1889710 1960 DODGE DART,MATADOR,POLARA V8 SMALL BLOCK WITH ALUMINUM DIST#1838505 1961 DODGE V8 #2095836 1961 DODGE DART V8 SMALL BLOCK 1838505,2095647
IF YOU WANT TO KNOW IF THIS KIT WILL FIT YOUR CAR, GIVE ME YOUR CHRYSLER ALUMINUM DISTRIBUTOR TAG# TO CONFIRM$130 mailed insured/tracked large priority mail flat rate box
cowgerwilliam035@gmail.com
