Page 1 of 4 1 2 3 4
For Sale - Small Block Engine - 1st Quarter #3202068
01/03/24 08:45 PM
01/03/24 08:45 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
Re: For Sale - Small Block Engine - 1st Quarter [Re: moparts] #3202098
01/03/24 10:17 PM
01/03/24 10:17 PM
Detroit area
6PAX Online content
6PAX  Online Content
Detroit area
70 B-body voltage regulator mounting bracket. $15
New chrome coil cover & coil mounting bracket. $20
NOS Cal Custom chrome radiator cap. $20
NOS Cal Custom chrome battery hold down. $25
Four new extra wide chrome valve cover hold down clamps. $10 for the set
New exhaust manifold heat stove to air cleaner flexible hose. $20
NOS fan clutch 3769614 for 1974 all V-8 engines. $100
Factory warning light type oil pressure sending unit. $10
Gauge type oil pressure sending unit. $20
Vintage Cal Custom 14" finned aluminum air cleaner with filter. $100
1970 Style single nipple oil breather with hose. $30
New 12" oval 4 barrel finned aluminum air cleaner with filter. It measures 12" L x 8 1/4" W x 3" H and has a 5 1/8" carb opening. $55
New Mopar Performance chrome water neck. Was bolted on an engine but then taken back off before the engine was ran. $10
AC alternator bracket from a mid 70s 360. $10
New Mr. Gasket chrome oil filter cover. $15
9 Chrome t-handle valve cover bolts. $10
Factory starter, part/casting #3755259. This came off of my Dart about 10 years ago. Worked fine then, been sitting on a shelf ever since. $40
Two 318 driver side spool motor mounts pt#3642811. One is used and one is NOS. $20 for the used. $35 for the NOS.
Edelbrock Elite small block valve covers EDL-4295 with bolts, breather & PCV valve. Very nice condition. $200
NOS Cal Custom chrome dagger dipstick handle. $25
New Mopar Performance 5 blade radiator fan and clutch. $100
Pioneer Automotive cylinder head dowel pins. 21 pieces 1/4" x 5/8". $10
Howard's solid flat tappet cam for Mopar big blocks, part number CL722322-08. See links below for specifications. I bought this cam for my engine with the intention of taking the car to the track when the car was finished being restored along with the engine being built but I have changed my mind about racing the car and decided to go with a milder hydraulic cam instead. I had this cam installed in my engine on the engine stand only (engine is still on the stand) so it has never been run and is essentially new. $375
New set of COMP Cams 973-16 - Inner Valve Springs. $45
2 used Holley 450 cfm carbs, part number 9776, for dual quad set-ups. Carbs are in nice shape and worked fine the last time they were used. The only thing wrong with them is on one of them the small vacuum fitting that sticks out the side needs replacing as the tube broke off. $450 for the pair.
Chrome single groove alternator pulley. $15
1975 Date coded alternator. Part #3874271. $25
Rev-n-nator Coil and programmable ICU. $200
Vintage Cal Custom scoop style air cleaner. Includes often missing matching wingnut. $300
New in boxes QTP 2 1/2" electric exhaust cutouts #QTEC50, stainless y-pipes #10250 and remote controller #10900. $654 total price at Summit. $550
Prices do not include shipping. No Paypal
Email: gt340 @ yahoo.com
Re: For Sale - Small Block Tach drive distributor [Re: moparts] #3202980
01/07/24 01:27 PM
01/07/24 01:27 PM
moparx Offline
moparx  Offline
SOLD !
Mopar Performance small block tach drive electronic distributor for sale.
very lightly used piece. comes in original Mopar Performance box.
asking $160.00 shipped anywhere in the lower 48 states. [offer?]
contact me here, or : moparxz "at" comcast "dot" net.
Thank you MOPARTS for the add ! boogie
beer
Re: 340 Exhaust Manifold - 2863549 1968-70 RH [Re: Mopar_Mike] #3203094
01/07/24 08:30 PM
01/07/24 08:30 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
SOLD. THANKS. small block b/e mounts. 40.00 each pair shipped. pp or usps m/o.
Re: 340 Exhaust Manifold - 2863549 1968-70 RH [Re: trw1982] #3203117
01/07/24 10:22 PM
01/07/24 10:22 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
solid mounts. will take pp or usps m/o. 30.00 shipped.
Small Block Forged 4.060” Bore Pistons for 3.454” Stro [Re: trw1982] #3204565
01/14/24 11:50 AM
01/14/24 11:50 AM
CT
Rocket Offline
Rocket  Offline
CT
I have a new set of 8 Mopar Performance pistons and wrist pins Mopar part# P4876973 for a 3.454” stroke crankshaft. Specs are 4.060” bore, 1/16, 1/16, 3/16 ring set, 0.984” wrist pin, flat top with ~ 5 cc eyebrows, listed by Mopar as 10.5 compression ratio. Compression height is ~ 1.72” per my measurement.
Price for the set is $480 shipped in the lower 48 states. I will ship internationally for the extra cost.
Email me at procketrichard@hotmail.com with any questions or for more pictures.
Small Block Solid Roller Lifters For Race Block - New [Re: Rocket] #3204566
01/14/24 11:52 AM
01/14/24 11:52 AM
CT
Rocket Offline
Rocket  Offline
CT
I have 11 pairs (one complete engine set plus 3 spare pairs) of new Mopar Performance solid roller lifters for small block Mopar race blocks still in their packages. I took one pair to photograph. Part number is P5249584. See the included picture from the 1997 Mopar Performance catalogue for the description. The roller wheel size is ~ 0.80”.
The price for the 11 pairs is $650 shipped in the lower 48 States. I will ship internationally for the additional cost.
R Block Lifters 1.jpg (653 downloads)
R Block Lifters 5.jpg (655 downloads)
R Block Lifters 6.jpg (656 downloads)
R Block Lifters 8.jpg (650 downloads)
W2 Small Block Head Costings - New [Re: Rocket] #3204567
01/14/24 11:56 AM
01/14/24 11:56 AM
CT
Rocket Offline
Rocket  Offline
CT
I have two new W2 cylinder head castings for sale.
One new individual W2 race head casting number P5249769. This head has had some preliminary machining including to the valve spring seat and valve cover gasket rail. This head requires the use of T&D or Jesel rocker systems. Price is $580 plus shipping.
One new individual W2 race head casting number P4532693. This head has had no machining performed. As delivered by Mopar. This head requires the use of T&D or Jesel rocker systems. Price is $580 plus shipping.
Mopar Performance Roller Rocker Arms for W2 / W5 Heads [Re: Rocket] #3204569
01/14/24 11:58 AM
01/14/24 11:58 AM
CT
Rocket Offline
Rocket  Offline
CT
I have 12 new Mopar Performance 1.5 ratio roller rocker arms for W2 econo heads. This set has the 8 exhaust rockers and 4 left intake rockers. Left intake part number is P4532859 and the Exhaust part number is P4532860.I do not have any right intake rockers. $520 shipped in the lower 48 states
I also have 16 new Mopar Performance 1.5 ratio roller W2 exhaust rocker arms for the W2 & W5 Race heads using offset drilled blocks and shafts. I will sell individual rockers or sets of 2, 4,6 or 8 as needed. Individual rockers are $40 each plus shipping.
I will ship internationally for the added cost.
Small Block Roller Rocker Kit 1.6 Ratio - New [Re: Rocket] #3204571
01/14/24 12:00 PM
01/14/24 12:00 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a new PRW 1.6 ratio roller rocker arm kit containing all parts needed to install these rocker arms including steel bushed rocker arms, rocker arm shafts, spacers, shims, adjusters, steel shaft hold downs and hold down hardware. This kit is new in the box and is PRW part # 3231812.
Price is $500 shipped in the lower 48 states.
I will ship internationally for the additional shipping cost.
Small Block Edelbrock Torker II Intake Manifold - Used [Re: Rocket] #3204572
01/14/24 12:02 PM
01/14/24 12:02 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a nice used Edelbrock Torker II single plane intake manifold. All thread holes are good. No heli coils. No porting has been performed to the ports or plenum. No pitting on the intake faces or the thermostat housing.
Price is $210 plus shipped in the lower 48 states.
I have a couple other used single plane intakes available from Mopar Performance and Holley.
Torker II Pic 1.jpg (739 downloads)
Torker II Pic 2.jpg (738 downloads)
Torker II Pic 3.jpg (733 downloads)
Torker II Pic 5.jpg (741 downloads)
Mopar Performance Small Block Pistons - New Incomplete Sets [Re: Rocket] #3204573
01/14/24 12:04 PM
01/14/24 12:04 PM
CT
Rocket Offline
Rocket  Offline
CT
I have 12 new Mopar Performance forged flat top pistons and pins. There are 3 different part numbers. There is not one complete set. Here is what I have.
P4876976 – Quantity of 6. Specs are 4.060” bore & ~ 1.67” compression height. These pistons are for a 0.060” overbore 360 with the stock stroke crankshaft or a 0.020” overbore 340 using a 3.58 stroke crankshaft.
Price for the 6 new forged pistons is $260 shipped.
P4876978 – Quantity of 4. Specs are 4.030” bore and ~ 1.67” compression height, These pistons are for a 0.030” overbore 360 with the stock stroke crankshaft
Price for the 4 new forged pistons is $160 shipped.
P5007413 – Quantity of 2. Specs are 4.030” bore and ~ 1.47” compression height, These pistons are for a 0.030” overbore 360 with a 4.00” stroke crankshaft.
Price for the 2 new forged pistons is $80 shipped.
Re: 1960-1961 Dodge Dart,Plymouth v8 ,TUNE UP KIT [Re: Rocket] #3204622
01/14/24 01:36 PM
01/14/24 01:36 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
NORS USA MADE MAJOR TUNE UP KIT PLUS WILL FIT;
1960-1961 DODGE DART V8 , 318 ALUMINUM SINGLE POINT DISTRIBUTOR
1960-1961 PLYMOUTH V8 318
INCLUDES;
BRASS INSERT HD DISTRIBUTOR CAP
ROTOR
POINTS
CONDENSER
NIEHOFF AL-331 VACUUM ADVANCE(REPLACES CHRYSLER/MOPAR#1881944
NIEHOFF DISTRIBUTOR PLATE WITH POINTS&CONDENSER(THIS WILL HAVE TO BE RE LUBRICATED AS ITS SAT IN A BOX ON THE SHELF FOR 50 PLUS YEARS
1 TEMP SENDING UNIT
1 OIL PRESSURE SWITCH
1 FLASHER
1 90 DEGREE ,METAL PCV VALVE(FITS 1961 &UP)
1 USA MADE ELECTRONIC VOLTAGE REGULATOR(FOR AN ALTERNATOR)
8 AUTOLITE S[PARK PLUGS(1 RANGE HOTTER THAN STOCK)
1 BLACK IGNITION WIRE SET
THIS KIT FITS A CHRYSLER ALUMINUM SINGLE POINT DISTRIBUTOR. #1838505, 2095836
WILL NOT FIT CAST IRON DISTRIBUTOR
CATALOG SHOWS THIS ABOVE KIT FITTING
1959 PLYMOUTH SMALL BLOCK
1961 PLYMOUTH V8 STANDARD SAVOY,FURY,BELVEDERE WITH CHRYSLER ALUMINUM DISTRIBUTOR 2095647,1838505, 1889710
1960 DODGE DART,MATADOR,POLARA V8 SMALL BLOCK WITH ALUMINUM DIST#1838505
1961 DODGE V8 #2095836
1961 DODGE DART V8 SMALL BLOCK 1838505,2095647
IF YOU WANT TO KNOW IF THIS KIT WILL FIT YOUR CAR, GIVE ME YOUR CHRYSLER ALUMINUM DISTRIBUTOR TAG# TO CONFIRM$130 mailed insured/tracked large priority mail flat rate box
cowgerwilliam035@gmail.com
Electronic Ignition Parts – News & Used [Re: Joesixpack] #3204714
01/14/24 06:26 PM
01/14/24 06:26 PM
CT
Rocket Offline
Rocket  Offline
CT
I have several ignition parts for sale. Prices include shipping.
New MSD Digital 6AL ignition module part #6425 $300 shipped
Used chrome ignition box $60
Used Jegs coil $35
Jegs Coil.JPG (711 downloads)
Small Bolt Edelbrock TM5 intake [Re: moparts] #3205168
01/16/24 10:06 AM
01/16/24 10:06 AM
blewbyu Offline
blewbyu  Offline
Used intake $200.00 plus shipping from Florida blewbyu2bad@aol.ocm
tm3 1.jpeg (638 downloads)
2 Trap Door Snorkle 340 Air Cleaners [Re: blewbyu] #3205169
01/16/24 10:11 AM
01/16/24 10:11 AM
blewbyu Offline
blewbyu  Offline
I have 2 orginal air cleaners 1st one is $275.00 the 2nd one is $200.00 plus shipping from Florida blewbyu2bad@aol.com
360 Road Racing Oil Pan [Re: blewbyu] #3205174
01/16/24 10:15 AM
01/16/24 10:15 AM
blewbyu Offline
blewbyu  Offline
This is a home made road racing oil pan in good shape. Made well. $200.00 plus shipping blewbyu2bad@aol.com
rr oil pan.jpeg (637 downloads)
rr oil pan 1.jpeg (636 downloads)
rr oil pan 2.jpeg (632 downloads)
rr oil pan 3.jpeg (633 downloads)
Re: For Sale - Small Block Engine - 1st Quarter [Re: moparts] #3205715
01/17/24 06:17 PM
01/17/24 06:17 PM
Cannelton, IN
mike337 Offline
mike337  Offline
Cannelton, IN
Alternator Brackets Non-A/C small block 69 & earlier. $30
Can be reached at moparzone4@aol.com
Thanks for the ad Moparts
3-11-2023 11-56-14 AM.jpg (551 downloads)
Re: For Sale - Small Block Engine - 1st Quarter [Re: moparts] #3205716
01/17/24 06:18 PM
01/17/24 06:18 PM
Cannelton, IN
mike337 Offline
mike337  Offline
Cannelton, IN
1962 – 1976 Mopar small block coil mounting bracket $20
8-4-2022 2-59-43 PM.jpg (553 downloads)
Custom Small Block 3,4 Speed Throttle Cable Bracket [Re: Memongo] #3206842
01/21/24 01:43 PM
01/21/24 01:43 PM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Custom Small Block 3,4 Speed Throttle Cable Bracket. Used, $25 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Call Steve 810-629-1097
Note: Works with any high rise intake or carburetor spacer
Page 1 of 4 1 2 3 4
