Page 3 of 4 1 2 3 4
Re: NOS Weiand Valve Covers 70’S Vintage [Re: Memongo] #3208121
01/25/24 03:39 PM
01/25/24 03:39 PM
Valpo Indiana
SMILINJOE Offline
SMILINJOE  Offline
Valpo Indiana
Set of original Weiand small block valve covers. Original box with decals and baffles. 5 out of 6 mounting screws for baffles.
Packing material dated 12-79.
$450 shipped lower 48
Re: N Valve Covers small block [Re: SMILINJOE] #3208122
01/25/24 03:45 PM
01/25/24 03:45 PM
Valpo Indiana
SMILINJOE Offline
SMILINJOE  Offline
Valpo Indiana
Clean set of Small block valve covers.
Very clean. No rust.
$340 shipped. Lower 48
Re: Used right side, E-body, SB engine mount bracket [Re: moparts] #3208162
01/25/24 08:07 PM
01/25/24 08:07 PM
Edison, New Jersey
PHYSIXX Offline
PHYSIXX  Offline
Edison, New Jersey
I have for sale a used right side, E-body, SB engine mount bracket. It’ll fit any of the SB engines. This bracket is straight, clean and painted. It comes with the 3 OEM attaching bolts, nuts but only 2 of the flat washers. I would like to get $8.00 for everything plus the shipping.
Edison, NJ
rider1454 at aol.com
Re: OEM 360 cast crank, #3418640, .010/.010 & balancer, [Re: PHYSIXX] #3208164
01/25/24 08:15 PM
01/25/24 08:15 PM
Edison, New Jersey
PHYSIXX Offline
PHYSIXX  Offline
Edison, New Jersey
I have for sale a really nice OEM 360 cast crank, casting number 3418640. This crank was in a 360 block with a 1971 casting date. This is very clean with the rods and main journals already cut .010/.010. The only thing that this might need is a very light polish. Other than that, it needs nothing. At some point though, this crank was balanced at the back of the crank as Mallory metal was installed in the last counter weight as seen in the pics. No heavy metal at the front though since the OEM balancer was used. Neutral balance converter and standard offset weight front balancer setup. Additionally, the oiling holes have been chamfered so better bearing oiling. In addition, the OEM balancer that was used for the original balancing is included. The hub is in decent shape but a slight groove can be felt so perhaps a repair sleeve might be in order. The balancer pulley bolts are also included. I would like to get $75.00 for everything plus the shipping. This is a heavy piece so the shipping will be crazy. Local pickup would be great or depending on location, I can meet part way for the cost of fuel and any tolls.
Edison, NJ
Re: Set of main caps from a 1986 318 [Re: PHYSIXX] #3208167
01/25/24 08:19 PM
01/25/24 08:19 PM
Edison, New Jersey
PHYSIXX Offline
PHYSIXX  Offline
Edison, New Jersey
I have for sale a set of main caps that came from a 1986 318 engine. They are all in excellent shape with no spun bearings and have been cleaned. The bolts that were used on this engine were a mismatched set so I’m just including the correct ones that I found. These caps can be used on any of the 273, 318 or 340 engines but the original 340 caps were a bit beefier. These caps can also be used on the V-6 engines as can be seen cast into the caps. I would like to get $20.00 for the set with the bolts.
Edison, NJ
Re: For Sale - Small Block Engine - 1st Quarter [Re: moparts] #3208358
01/26/24 07:21 PM
01/26/24 07:21 PM
Detroit area
6PAX Online content
6PAX  Online Content
Detroit area
For sale are these crank (top two) and water pump pulleys. All are single groove except for the top left crank which is two groove. Some have legible part number, some don't. The top one on the right has the number printed on it but the 6th digit is not all there as it is partly printed over one of the holes. Most of them are pretty clean but there is some minor pitting on a few with the exception of the upper left crank pulley which has a fair amount of pitting on it. Prices do not include postage. I don't have Paypal so money orders, particularly postal are preferred. I will also accept personal checks but will not ship until they clear my bank. gt340 at yahoo.com
New BRC 4.030" Forged Pistons and pins for 3.79" Stoke Crank [Re: 6PAX] #3208696
01/28/24 11:17 AM
01/28/24 11:17 AM
CT
Rocket Offline
Rocket  Offline
CT
I have a set of New BRC 4.030" forged flat top pistons and pins for a 3.79" stroke small block crankshaft. Compression height is ~ 1.57" and the ring lands are 1/16, 1/16 and 3/16. Pins are 0.984”. Approximately 6cc valve reliefs.
These pistons can be used in aftermarket race blocks or stock 360/5.9 magnum engine blocks.
Price is $475 shipped in the lower 48 states. I will ship elsewhere for the added cost.
Email me at procketrichard@hotmail.com with any questions or for more pictures.
BRC 3.79 P1.JPG (1106 downloads)
BRC 3.79 P2.JPG (1106 downloads)
BRC 3.79 P3.JPG (1104 downloads)
BRC 3.79 P4.JPG (1110 downloads)
Re: For Sale - Small Block Engine - 1st Quarter [Re: moparts] #3209332
01/30/24 09:21 PM
01/30/24 09:21 PM
SE PA
cudaize Offline
cudaize  Offline
SE PA
Restored AVS carburetor for 1970 340 auto cars. Date Code L9. Linkages, screws, solenoid housing and bracket disassembled and zinc plated. Solenoid tested and works.
$750.00 + shipping for zip code 18929
cudaize@comcast.net
FRONT SMALL.jpg (1003 downloads)
340 motor mounts and new insulators [Re: moparts] #3211205
02/06/24 06:01 PM
02/06/24 06:01 PM
Mattituck NY.
FJ6AAR Offline
FJ6AAR  Offline
Mattituck NY.
**SOLD - Thank You Moparts**
Hi all, I have a set of 340 motor mounts and new insulators. These are correct for a 340 engine which I believe are 340 only? Asking $70.00 shipped. Good old fashioned postal money order only. Plese PM me here for fastest response. Thank you for the ad moparts!
1970 Hemi 'Cuda hard top clone
1971 Hemi 'Cuda Convertible clone
340 sixpack set up [Re: moparts] #3211917
02/08/24 11:23 AM
02/08/24 11:23 AM
X
xx29 Offline
xx29  Offline
X
For sale: 340 6 pack intake, carbs, air cleaner. Has 440 6 pack carbs. Air cleaner base plate looks new.
$4500. Can deliver to Spring Fling show in Van Nuys, CA April 20th, 2024. Email: ebodycab @msn.com
Phone: 818-426-8685
1970 340 block and crank [Re: LSP] #3213209
02/13/24 12:40 PM
02/13/24 12:40 PM
waynesboro va
jonesboys Offline
jonesboys  Offline
waynesboro va
1970 340 block and crank engine is from a 1970 Cuda Vin 0b212337 build date7,14,69 2780930,340,6 block has been pressure tested cleaned has no damage crank has been turned 10,10 and was in a stick car pilot bushing in place also has a 1969 318 for parts pictures are to large to load can text photos to interested buyers PRICE 2000.00
1970 340 4 speed carb [Re: moparts] #3214753
02/19/24 08:59 PM
02/19/24 08:59 PM
Wisconsin
71duster414 Offline
71duster414  Offline
Wisconsin
1970 340 4 speed carburetor
Good condition, rebuild or restore. Secondary throttle shaft is tight.
$400 obo
hoffmanhhr@gmail.com
1972 340 4 speed carb [Re: 71duster414] #3214895
02/20/24 12:53 PM
02/20/24 12:53 PM
Wisconsin
71duster414 Offline
71duster414  Offline
Wisconsin
1972 340 4 speed carburetor
This carb is in good condition and moves freely.
$400 obo
Re: CROWER CAM&LIFTERS,ROLLER CHAIN &GEAR SET [Re: 71duster414] #3217049
02/29/24 01:52 PM
02/29/24 01:52 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
NEW 340-360 CROWER CAMSHAFT AND LIFTERS &MP DOUBLE ROLLER CHAIN&GEAR SET,CAM IS #31981 304HC, 501/304 114 LOBE SEP, .334 LOBE LIFT,238 DURATION AT .050, LIFTER#66031X3-16, BRAND NEW$400
cowgerwilliam035@gmail.com
Re: 360 MOROSO DEEP PAN,PU,PUMP,W TRAY NEW [Re: Joesixpack] #3217052
02/29/24 01:54 PM
02/29/24 01:54 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
360 A,B&E MOROSO DEEP OIL PAN,PICKUP, OIL PUMP,WINDAGE TRAY, ALL NEW ,WAS INSTALLED and removed from a fresh shortblock$250
Re: [Re: Joesixpack] #3217053
02/29/24 01:58 PM
02/29/24 01:58 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
340-360 mopar parts COATED 1 7/8S JR 340-360,MULTI PIECE HEADERS B&E STOCK/SUPERSTOCK ARE NEW NEW$500
TRAVELLLING FROM AZ TO PA IN APRIL CAN DROP OFF ANYWHERE ALONG THE ROUTE
Re:Chrysler Marine 360 front cover,pump alternator,pullies [Re: WINGNUT] #3217970
03/04/24 11:22 AM
03/04/24 11:22 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
360 chrysler marine
Cast iron front timing cover,water pump, prestolite alternator& brackets, external mechanical water pump& brackets, pullies, belts, bolts, came off 75 chrysler marine 360 will fit 273 318 340 360 marine inboard engines.
Also have a flywheel& exhaust manifolds if you want them. Package deal. ( included if you buy above parts)$300
EXPENSIVE TO SHIP HEAVY
TRAVELLING AZ TO PA IN APRIL CAN DROP OFF
Re:Chrysler Marine 360 front cover,pump alternator,pullies [Re: Joesixpack] #3217980
03/04/24 11:58 AM
03/04/24 11:58 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
1973 340 1974 360 ORIGINAL A-BODY SPOOL TYPE MOTOR MOUNT BOLTS,NUTS,WASHERS, INTAKE BOLTS, VALVE COVER BOLTS,OIL PAN BOLTS, AUTO TRANS FLEXPLATE TO CRANK BOLTS, TC BOLTS FLEX TO TC, FUEL PUMP BOLTS, USED, $60
Carter #9410s AFB Carbs 400 CFM (2) [Re: moparts] #3218042
03/04/24 03:46 PM
03/04/24 03:46 PM
Northwest Indiana
19Coronet66 Offline
19Coronet66  Offline
Northwest Indiana
For sale are a pair of Carter AFB carburetors. Carter part number #9410s. 400 CFM. Both carbs appear to be in good condition. Everything moves freely. Will need kits. $250 each plus shipping. Reasonable offer? Have a few additional pictures if needed.
PM if interested
Re: For Sale - Small Block Engine - 1st Quarter [Re: mopars4ever] #3219621
03/10/24 09:47 PM
03/10/24 09:47 PM
Western,NY
JEJJ Offline
JEJJ  Offline
Western,NY
Casting number 2780998 interchanges with 2951995 P3690743 and 2463661. Fits Mopar Small Block 318-340-360. 90 degree oil filter adapter mount. excellent condition...........$125
Thank you
716-997-0070
bakurruda@aol.com
Page 3 of 4 1 2 3 4
