Re: Used right side, E-body, SB engine mount bracket
[Re: moparts]
#3208162
01/25/24 08:07 PM
01/25/24 08:07 PM
Posts: 1,689 Edison, New Jersey
PHYSIXX
Edison, New Jersey
I have for sale a used right side, E-body, SB engine mount bracket. It’ll fit any of the SB engines. This bracket is straight, clean and painted. It comes with the 3 OEM attaching bolts, nuts but only 2 of the flat washers. I would like to get $8.00 for everything plus the shipping.
Edison, NJ rider1454 at aol.com
Re: OEM 360 cast crank, #3418640, .010/.010 & balancer,
[Re: PHYSIXX]
#3208164
01/25/24 08:15 PM
01/25/24 08:15 PM
PHYSIXX
Edison, New Jersey
I have for sale a really nice OEM 360 cast crank, casting number 3418640. This crank was in a 360 block with a 1971 casting date. This is very clean with the rods and main journals already cut .010/.010. The only thing that this might need is a very light polish. Other than that, it needs nothing. At some point though, this crank was balanced at the back of the crank as Mallory metal was installed in the last counter weight as seen in the pics. No heavy metal at the front though since the OEM balancer was used. Neutral balance converter and standard offset weight front balancer setup. Additionally, the oiling holes have been chamfered so better bearing oiling. In addition, the OEM balancer that was used for the original balancing is included. The hub is in decent shape but a slight groove can be felt so perhaps a repair sleeve might be in order. The balancer pulley bolts are also included. I would like to get $75.00 for everything plus the shipping. This is a heavy piece so the shipping will be crazy. Local pickup would be great or depending on location, I can meet part way for the cost of fuel and any tolls.
New BRC 4.030" Forged Pistons and pins for 3.79" Stoke Crank
[Re: 6PAX]
#3208696
01/28/24 11:17 AM
01/28/24 11:17 AM
Posts: 886 CT
Rocket
CT
I have a set of New BRC 4.030" forged flat top pistons and pins for a 3.79" stroke small block crankshaft. Compression height is ~ 1.57" and the ring lands are 1/16, 1/16 and 3/16. Pins are 0.984”. Approximately 6cc valve reliefs.
These pistons can be used in aftermarket race blocks or stock 360/5.9 magnum engine blocks.
Price is $475 shipped in the lower 48 states. I will ship elsewhere for the added cost.
Email me at procketrichard@hotmail.com with any questions or for more pictures.
340 motor mounts and new insulators
[Re: moparts]
#3211205
02/06/24 06:01 PM
02/06/24 06:01 PM
Posts: 1,548 Mattituck NY.
FJ6AAR
Mattituck NY.
**SOLD - Thank You Moparts**
Hi all, I have a set of 340 motor mounts and new insulators. These are correct for a 340 engine which I believe are 340 only? Asking $70.00 shipped. Good old fashioned postal money order only. Plese PM me here for fastest response. Thank you for the ad moparts!
1970 Hemi 'Cuda hard top clone
1971 Hemi 'Cuda Convertible clone
340 sixpack set up
[Re: moparts]
#3211917
02/08/24 11:23 AM
02/08/24 11:23 AM
xx29
For sale: 340 6 pack intake, carbs, air cleaner. Has 440 6 pack carbs. Air cleaner base plate looks new. $4500. Can deliver to Spring Fling show in Van Nuys, CA April 20th, 2024. Email: ebodycab @msn.com Phone: 818-426-8685
1970 340 block and crank
[Re: LSP]
#3213209
02/13/24 12:40 PM
02/13/24 12:40 PM
Posts: 147 waynesboro va
jonesboys
waynesboro va
1970 340 block and crank engine is from a 1970 Cuda Vin 0b212337 build date7,14,69 2780930,340,6 block has been pressure tested cleaned has no damage crank has been turned 10,10 and was in a stick car pilot bushing in place also has a 1969 318 for parts pictures are to large to load can text photos to interested buyers PRICE 2000.00
1970 340 4 speed carb
[Re: moparts]
#3214753
02/19/24 08:59 PM
02/19/24 08:59 PM
Posts: 631 Wisconsin
71duster414
Wisconsin
1970 340 4 speed carburetor
Good condition, rebuild or restore. Secondary throttle shaft is tight.
$400 obo
hoffmanhhr@gmail.com
1972 340 4 speed carb
[Re: 71duster414]
#3214895
02/20/24 12:53 PM
02/20/24 12:53 PM
71duster414
Wisconsin
1972 340 4 speed carburetor This carb is in good condition and moves freely.
$400 obo
Re: CROWER CAM&LIFTERS,ROLLER CHAIN &GEAR SET
[Re: 71duster414]
#3217049
02/29/24 01:52 PM
02/29/24 01:52 PM
Posts: 11,912 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
NEW 340-360 CROWER CAMSHAFT AND LIFTERS &MP DOUBLE ROLLER CHAIN&GEAR SET,CAM IS #31981 304HC, 501/304 114 LOBE SEP, .334 LOBE LIFT,238 DURATION AT .050, LIFTER#66031X3-16, BRAND NEW$400 cowgerwilliam035@gmail.com
Re: 360 MOROSO DEEP PAN,PU,PUMP,W TRAY NEW
[Re: Joesixpack]
#3217052
02/29/24 01:54 PM
02/29/24 01:54 PM
Joesixpack
APACHE JUNCTION AZ
360 A,B&E MOROSO DEEP OIL PAN,PICKUP, OIL PUMP,WINDAGE TRAY, ALL NEW ,WAS INSTALLED and removed from a fresh shortblock$250
Re:
[Re: Joesixpack]
#3217053
02/29/24 01:58 PM
02/29/24 01:58 PM
Joesixpack
APACHE JUNCTION AZ
340-360 mopar parts COATED 1 7/8S JR 340-360,MULTI PIECE HEADERS B&E STOCK/SUPERSTOCK ARE NEW NEW$500 TRAVELLLING FROM AZ TO PA IN APRIL CAN DROP OFF ANYWHERE ALONG THE ROUTE
Re:Chrysler Marine 360 front cover,pump alternator,pullies
[Re: WINGNUT]
#3217970
03/04/24 11:22 AM
03/04/24 11:22 AM
Joesixpack
APACHE JUNCTION AZ
360 chrysler marine Cast iron front timing cover,water pump, prestolite alternator& brackets, external mechanical water pump& brackets, pullies, belts, bolts, came off 75 chrysler marine 360 will fit 273 318 340 360 marine inboard engines. Also have a flywheel& exhaust manifolds if you want them. Package deal. ( included if you buy above parts)$300
EXPENSIVE TO SHIP HEAVY
TRAVELLING AZ TO PA IN APRIL CAN DROP OFF
[Re: Joesixpack]
#3217980
03/04/24 11:58 AM
03/04/24 11:58 AM
Joesixpack
APACHE JUNCTION AZ
1973 340 1974 360 ORIGINAL A-BODY SPOOL TYPE MOTOR MOUNT BOLTS,NUTS,WASHERS, INTAKE BOLTS, VALVE COVER BOLTS,OIL PAN BOLTS, AUTO TRANS FLEXPLATE TO CRANK BOLTS, TC BOLTS FLEX TO TC, FUEL PUMP BOLTS, USED, $60 cowgerwilliam035@gmail.com
Carter #9410s AFB Carbs 400 CFM (2)
[Re: moparts]
#3218042
03/04/24 03:46 PM
03/04/24 03:46 PM
Posts: 240 Northwest Indiana
19Coronet66
Northwest Indiana
For sale are a pair of Carter AFB carburetors. Carter part number #9410s. 400 CFM. Both carbs appear to be in good condition. Everything moves freely. Will need kits. $250 each plus shipping. Reasonable offer? Have a few additional pictures if needed.
PM if interested
