1990 Ram....club cab #3156059
07/01/23 09:04 PM
07/01/23 09:04 PM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
https://denver.craigslist.org/cto/d/saint-francis-1990-power-ram/7638789830.html
If it was closer, I would be heading there right now...
Re: 1990 Ram....club cab [Re: dssaa] #3156077
07/01/23 10:42 PM
07/01/23 10:42 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Sounds like you are close already. NW Kansas is right on the border with Colorado, how much closer does something have to be..lol
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: 1990 Ram....club cab [Re: B3422W5] #3156080
07/01/23 11:15 PM
07/01/23 11:15 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Its just right down the road from my other farm if you need someone to look at it. Probably 20 miles from me now.
STOP POTATO HATE!
Re: 1990 Ram....club cab [Re: B3422W5] #3156087
07/01/23 11:53 PM
07/01/23 11:53 PM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
I know, I know. But its still a 3 hour drive each way. I do most of my running around within an hour or so from the house. I used to long haul for Mopars all the time. I don't know how many Chargers I pulled out of southern Texas, but those days are in my rear view mirror....
Re: 1990 Ram....club cab [Re: B3422W5] #3156093
07/02/23 12:25 AM
07/02/23 12:25 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
From the ad.......Pickup is located in NW Kansas could deliver if need be.
popcorn
John
Re: 1990 Ram....club cab [Re: SattyNoCar] #3156100
07/02/23 01:49 AM
07/02/23 01:49 AM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
Yep....for how much. I think I am going to go take a road trip. I sadly view it as a parts truck, but it could help complete 2 other Power wagons I am putting together.
Re: 1990 Ram....club cab [Re: dssaa] #3156155
07/02/23 10:42 AM
07/02/23 10:42 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Were the 1989 to 1992 Throttle Body injection systems trouble prone?
Re: 1990 Ram....club cab [Re: 360view] #3156490
07/03/23 11:07 AM
07/03/23 11:07 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
I had one and the only issue i had during the 200K it had was the idle motor needed to replaced. Fuel pump and filter also.
Re: 1990 Ram....club cab [Re: 360view] #3156510
07/03/23 12:08 PM
07/03/23 12:08 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Biggest / most common issue was the pan on the metal pan on bottom of the intake leaked oil
Re: 1990 Ram....club cab [Re: gtx6970] #3156527
07/03/23 01:04 PM
07/03/23 01:04 PM
SattyNoCar Offline
SattyNoCar  Offline
I thought that was only on '93 - up on the magnum?
John
Re: 1990 Ram....club cab [Re: SattyNoCar] #3156547
07/03/23 01:32 PM
07/03/23 01:32 PM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
Correct on the '94-up Magnums ("Kegger" intake): the stamped steel plate often lost it's seal, resulting in oil sukcing from the lifter valley- causing oil induced detionation, valve coking and whatever else. The 1st Gen TBI used a more traditional intake, which was a single piece casting.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
