1990 Ram....club cab
#3156059
07/01/23 09:04 PM
07/01/23 09:04 PM
Posts: 977 Colorado
dssaa
Colorado
Re: 1990 Ram....club cab
[Re: dssaa]
#3156077
07/01/23 10:42 PM
07/01/23 10:42 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
Sounds like you are close already. NW Kansas is right on the border with Colorado, how much closer does something have to be..lol
[Re: B3422W5]
#3156080
07/01/23 11:15 PM
07/01/23 11:15 PM
Posts: 9,554 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Its just right down the road from my other farm if you need someone to look at it. Probably 20 miles from me now.
STOP POTATO HATE!
[Re: B3422W5]
#3156087
07/01/23 11:53 PM
07/01/23 11:53 PM
Posts: 977 Colorado
dssaa
Colorado
Sounds like you are close already. NW Kansas is right on the border with Colorado, how much closer does something have to be..lol I know, I know. But its still a 3 hour drive each way. I do most of my running around within an hour or so from the house. I used to long haul for Mopars all the time. I don't know how many Chargers I pulled out of southern Texas, but those days are in my rear view mirror....
[Re: B3422W5]
#3156093
07/02/23 12:25 AM
07/02/23 12:25 AM
Posts: 16,839 Between Houston & Galveston TX
SattyNoCar
Sounds like you are close already. NW Kansas is right on the border with Colorado, how much closer does something have to be..lol From the ad....... Pickup is located in NW Kansas could deliver if need be.
John
[Re: 360view]
#3156510
07/03/23 12:08 PM
07/03/23 12:08 PM
Posts: 21,483 It's a dry heat
gtx6970
It's a dry heat
Were the 1989 to 1992 Throttle Body injection systems trouble prone? Biggest / most common issue was the pan on the metal pan on bottom of the intake leaked oil
[Re: gtx6970]
#3156527
07/03/23 01:04 PM
07/03/23 01:04 PM
SattyNoCar
Were the 1989 to 1992 Throttle Body injection systems trouble prone? Biggest / most common issue was the pan on the metal pan on bottom of the intake leaked oil I thought that was only on '93 - up on the magnum?
John
[Re: SattyNoCar]
#3156547
07/03/23 01:32 PM
07/03/23 01:32 PM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
Were the 1989 to 1992 Throttle Body injection systems trouble prone? Biggest / most common issue was the pan on the metal pan on bottom of the intake leaked oil I thought that was only on '93 - up on the magnum? Correct on the '94-up Magnums ("Kegger" intake): the stamped steel plate often lost it's seal, resulting in oil sukcing from the lifter valley- causing oil induced detionation, valve coking and whatever else. The 1st Gen TBI used a more traditional intake, which was a single piece casting.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
